Old 15-12-2013, 07:22 PM   #1
POELWYK
Lost Boost Gained Class
POELWYK's Avatar
Default Au series 1.5 fairmont traction control
I'm asking on behalf of a mate and my old fairmont. He's the owner of the car and wants to know what is required to install the traction control. The loom for the button is in the dash and we have the button, but don't know what else is needed.
2006 BF Fairmont Ghia
2001 AU Falcon
POELWYK is offline   Reply With Quote Multi-Quote with this Post
Old 15-12-2013, 11:29 PM   #2
FGII-XR6
FGII-XR6's Avatar
Default Re: Au series 1.5 fairmont traction control
replacing the brake pipes to the rear brakes and the ABS unit as a starting point
[SIGPIC][/SIGPIC]
Rides:
Old 16-12-2013, 06:34 PM   #3
POELWYK
POELWYK's Avatar
are car is fitted with ABS... what more needs to be done
2001 AU Falcon
Old 16-12-2013, 10:50 PM   #4
FGII-XR6
FGII-XR6's Avatar
the abs unit is different it has an extra rear brake outlet for the extra line to the rear . normally there is one brake line to the rear and it splits at the diff , with TC there are 2 lines all the way from the ABS to the callipers. the electronics are housed in the ABS unit but they interact with the ECU as far as I know if you fit the switch the TC ABS unit and the right brake lines it should work
[SIGPIC][/SIGPIC]
Rides:
Old 17-12-2013, 12:18 PM   #5
BHDOGS
Does the diff Have the tone wheels fitted on the axles that the traction control needs on his car?
Old 22-12-2013, 11:07 PM   #6
GasoLane
Former BTIKD
GasoLane's Avatar
Wheel spin...slightly lift right foot........ Bingo, retro traction control !
