Old 12-10-2021, 04:44 PM   #1
inventiv
inventiv's Avatar
Default Focus MK1 - PCV Valve System - DIY Guide
Hey guys, I had a leak from the PCV area so I swapped my PCV Valve and gaskets and hoses. Check out the vid if you need some tips.
https://youtu.be/qyUOlSV-c3c
Mine was leaking from the rear hose. It seems that this collapsed under vacuum over time, causing a leak where the metal pipe connects to the rear hose.
Hope this helps someone out.
inventiv is offline   Reply With Quote Multi-Quote with this Post
Old 11-04-2022, 01:00 PM   #2
Focmachine
Default Re: Focus MK1 - PCV Valve System - DIY Guide
Hey Mr Horus works!
I've messaged you on your channel before, but couldn't PM you my details, lacking any social media.
Please look for my PM on this forum
Focmachine is offline   Reply With Quote Multi-Quote with this Post
