17-08-2011, 01:16 PM | #1 | ||
Hey guys and girls,
Recently went to get some new tyres on my AU111 only to find out that I can't find my locknut key The tyre shop said they can't get them off without wrecking my rims. Ford said they wont give me a new one unless I have the serial number off the old key and if I want a wheel repair place to get them off they need my car for a whole day which I can't commit to with my work schedule. So what can I do? Does anyone in QLD (Gold Coast area) have the standard AU111 XR lock that I can try? Are they all the same? Cheers for any help.
AU111 XR6 Ute, VCT, Leather, Manual. |
17-08-2011, 01:33 PM | #2 | ||
Petro-sexual
I broke my locknut key ages ago when a tyre shop did them up too tight.
I ended up having to drill the studs out. It worked and I only damaged one wheel when the drill went off course a little a gouged into the tapered seat a little. Do you still happen to have the packaging the locknuts came in? That might still have the code on it. |
17-08-2011, 01:40 PM | #3 | ||
Go buy a cheap socket that close to fitting but slightly smaller
Hammer it on and undo Put socket in vice and use a punch to get the wheel nut out Repeat for each nut |
17-08-2011, 01:43 PM | #4 | ||||
Back to Le Frenchy
If they can't get locknuts off without damaging the rims they don't know what they are doing and have no business running a tyre shop. I've had the same issue, tyre shop said not an issue we'll use a socket and hammer it on. It cost me an extra $20 plus a new set of lock nuts but it did not damage the rims.
17-08-2011, 01:44 PM | #5 | ||
Silky Smoothe
Yeah, the only thing you can do is put a similar size socket, and hammer it on nice and hard and then take it off.
[R1XSTA] - 2003 BA XR6; Blood orange. Sports Leather. -SOLD - MY12 Holden Cruze SRI-V, 6spd man, sunroof, leather. - SOLD - 2006 Ford Territory Turbo; Silhoutte, Leather, Plazmaman CAI. |
17-08-2011, 01:50 PM | #6 | ||
Petro-sexual
I had these ones. http://www.barrinut.com.au/home.html
Socket trick doesnt work. |
17-08-2011, 02:03 PM | #7 | ||
Have had to do this a few times. Always managed to get them off by smashing on a bit smaller 12 point socket. Can be time consuming but works
17-08-2011, 02:14 PM | #8 | ||
you might try drilling it out and using an easyout
[SIGPIC][/SIGPIC]
17-08-2011, 03:23 PM | #9 | ||
I have used an air chisel to undo the nut. this obviously wrecks the nut but if careful you dont hurt the rim. EG you use the chisel to loosen the nut.
17-08-2011, 05:59 PM | #10 | ||
rexnet
there are a few different shape ford lock nut shapes. if you have any friends that have genuine for lock nuts borrow one of theirs and see if it fits.
on the key it'll have a code that can be used to reorder a new one. i broke mine and re ordered it was $25 for memory came in over night. |
17-08-2011, 07:34 PM | #11 | ||
Thanks for all the help guys, looks like I might have to try the cheap socket trick if I cant find the original key or someone who has one by the weekend.
17-08-2011, 07:39 PM | #12 | ||
Fixing Ford's **** ups
Problem with tyre shops (and I speak from experience), is we can get locknuts off, but we don't like doing it, because we don't want to run the risk of damaging rims and having to replace them.
Personally I have been blamed for scratching the paint inside the wheel nut area, being Mr niceguy, removing locknuts for a customer. Of course, this was done free of charge to the customer, yet I cop a mouthful of abuse for scratching this area. IMA, it was already scratched in all the wheel nut areas, but Mr huffy puffy wouldn't have a bar of it. Now, a customer wants locknuts removed, they sign a piece of paper, wavering any damage caused as a result of removing the locknuts. (This includes paint chipping inside the wheel nut area of the rim.)
A wheel alignment fixes everything, when it comes to front end issues. This includes any little noises. Please read the manual carefully, as the these manufacturers spent millions of dollars making sure it is perfect.....Now why are there so many problems with my car, when I follow the instructions to the letter?....Answer, majority rules round here Lock me up and throw away the key because I'm a hoon....I got caught doing 59 in a 60 zone |
17-08-2011, 07:43 PM | #13 | ||
depending upon the rim, i dont know new cars but locking pliers will get em off sometimes. as junky and chinese as it sounds , I also have a inch socket that is filled with about 100 little metal pins and ya push it on a nut and it "forms" its own shape around the socket. I can't explain it so I try find a pic. my point being it also grips rounded stuff.
edit, here tis ! http://www.ebay.com.au/itm/Gator-Gri...item2311759635 ok so i lied about the 100 pins.......... but 52 is closer to 100 than it is to zero Last edited by JG65TE; 17-08-2011 at 07:50 PM. |
17-08-2011, 07:55 PM | #14 | ||
I have a spare one for an AUII XR but I doubt I can get it to you by the weekend from Vic. Are AUII & III the same? Some ****** damaged it using a rattle gun so I got a new one. Still works on the nuts though...
Oh...are we talking about the special socket or is there another set of wheel nuts that came out on the AU? |
17-08-2011, 10:36 PM | #15 | ||||
17-08-2011, 10:38 PM | #16 | |||
26-08-2011, 01:00 PM | #17 | ||
Just thought I would say thanks for all the suggestions. Today I had time to try the old cheap socket and hammer trick and it worked a treat.
Now just waiting to get my new Pirellis on!
27-08-2011, 12:45 AM | #18 | |||
24-06-2014, 09:09 PM | #19 | ||
Can you get a replacement lock nut from ford if you have the socket?
25-06-2014, 10:11 AM | #20 | ||
Exactly what I had done. I lost my lock nut key a few years ago. I went to the Bob Jane in Werribee and asked what they could do. They have a special socket that screws onto the lock nut with a reverse thread. Then they simply rattle gun the nut of, the thread getting tighter as they unscrew it. Took them about 10 minutes to do all 4. New lock nuts from them and I was away.
