Old 15-08-2013, 08:55 PM   #1
sednwol
sednwol's Avatar
Default Whinning noise AU Ghia
Hi All, My AU series 2 Auto Ghia sedan is making a whinning noise which seems to be coming from under (or just behind) the centre console. Cant hear anything until 40KPH and them the noise starts and increases as speed increases. Auto issue perhaps? Ant ideas? Anyone had this sound in there AU. THX.
sednwol is offline   Reply With Quote Multi-Quote with this Post
Old 18-08-2013, 09:33 AM   #2
sednwol
sednwol's Avatar
Default Re: Whinning noise AU Ghia
Hmmm, looks like no one has had this issue. Off to the mechanic then.
Old 18-08-2013, 02:36 PM   #3
mik
mik's Avatar
Noises are a tuff call over the internet old mate, and can be deceptive at the best of times, good luck , let us know what you find.
Old 18-08-2013, 03:13 PM   #4
revcore
revcore's Avatar
Could be a whining diff.
My Ride...
2005 BA2 XR6 Magnet Ute.
revcore is offline   Reply With Quote Multi-Quote with this Post
Old 18-08-2013, 04:10 PM   #5
BHDOGS
My blue au had that whine it was a ****** trans
BHDOGS is offline   Reply With Quote Multi-Quote with this Post
Old 18-08-2013, 06:43 PM   #6
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
I'm so glad no one posted get your partner to move to the back seat and see if it helps...oh no I just did.. bugger
UK
Old 18-08-2013, 06:50 PM   #7
SSD-85
Id say one of 2 things; the diff or a wheel bearing.
Wheel bearing whine is very distinct, sounding like an old prop driven aircraft. And its loud as hell at highway speeds.
SSD-85 is offline   Reply With Quote Multi-Quote with this Post
Old 18-08-2013, 07:26 PM   #8
SPArKy_Dave
Too many Fords........ :)
SPArKy_Dave's Avatar
Was the missus in the passenger seat?
Current Projects
97 EL V8 wagon - cool cruiser, or street bruiser? CLICKY
93 XG panel van - at your door in 60 secs, or the first hr is FREE........ yep, that's the goal.
95 XG ute - awaiting a head gasket...... grrrrr.
74 XB GS pano..... factory optioned with all the good stuff..... not much there now. ........long term resto.
XB Coupe and Van TV Ad
you know........ there's a little bit of Bathurst in every Ford Falcon.... think about it
SPArKy_Dave is offline   Reply With Quote Multi-Quote with this Post
Old 19-08-2013, 12:07 AM   #9
sednwol
sednwol's Avatar
Yes, sounds more like a dentists' slow drill..a drone sound really.
Old 19-08-2013, 12:41 AM   #10
SPArKy_Dave
It's likely the oil pump on the auto trans.
Been there and done that.
In my case, a trans service and flush, solved the problem.
(clearly hadn't been serviced in a very long time!)
Current Projects
Old 22-08-2013, 06:52 PM   #11
sednwol
sednwol's Avatar
Turns out its the diff. Needs to be a reconditioned. Ouch lots of $'s
Old 22-08-2013, 08:52 PM   #12
SPArKy_Dave
Recommend Agmech in Boronia for diff rebuilds.
They just did my old mans VS commodore ute diff.
Cost $700.00
Current Projects
Old 22-08-2013, 09:05 PM   #13
sednwol
sednwol's Avatar
Thx, SPArKy Dave, I was quoted $1800+, due to the type of diff in the AU. Would this be right? Will ring Agmech tommorow.
Old 22-08-2013, 09:25 PM   #14
SPArKy_Dave
Depends...... maybe you have an IRS rear end?
Keep us posted!
Current Projects
Old 22-08-2013, 11:22 PM   #15
sednwol
sednwol's Avatar
Yes, its has an IRS rear end.
Old 22-08-2013, 11:30 PM   #16
XRGhia
meh.
XRGhia's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Contributions in the technical arena.
Still, being an IRS rear end it isn't that hard to drop the center, once the axles, 4 or 5 bolts, and driveshaft is all out/disconnected, it should drop straight down.
Previous - BF XR6T - 325rwkw, 6 Speed Auto, Process West, X-Force and Turbosmart gear
XRGhia is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2013, 08:09 AM   #17
sednwol
sednwol's Avatar
My mechanic told me it takes 5 hours to get the diff out?
Old 23-08-2013, 02:09 PM   #18
XRGhia
meh.
XRGhia's Avatar
I doubt it, even with removing the entire cradle, removal shouldn't take more then an hour, unless your mechanic doesn't know what he's doing.
Old 23-08-2013, 09:32 PM   #19
dieseltrain79
5 hours to get it out ??? Wow , maybe 1.5 tops . It's a simple IRS rear end .
I would get a 2nd opinion mate .
1998 AU VCT Ghia - Stock as a rock - Wifes car
1991 Toyota Soarer TT - 11.72 @ 116.7mph
2004 Ford Escape XLT V6 - Family Ride .
dieseltrain79 is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2013, 10:07 PM   #20
sednwol
sednwol's Avatar
Iam getting a second opinion, taking the car to Agmech in Boronia on Monday for them to test drive.
Old 26-08-2013, 07:18 PM   #21
sednwol
sednwol's Avatar
Took the car to Agmech in Boronia today, the guy test drove the car and tells me its the left front wheel bearing! Who to believe?
Old 26-08-2013, 07:32 PM   #22
blueoval
Critical Thinker
blueoval's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Well thought out and constructive posts.  A real credit to this forum.
Go with the cheapest option first.
In saying that, the AU wheels bearings are a sealed, all in one unit. Fairly rare to see them pack up, but if it is a bearing, it is and will be a complete bearing assembly. Not cheap, but still cheaper than the option of the diff. That time frame is stupid. Its clear the guy has no idea.
If it were me, I'd get the trans serviced first. Full flush and service. If it turns out not to be that, so be it, its cost you what? $120? and you know the trans is serviced for another 20,000km. Then move onto the wheel bearing suggestion, and so on.
Like others have said, too hard to know over the net, and it's basically speculating.
"the greatest trick the devil pulled, is convincing the world he doesn't exist"
2022 Mazda CX5 GTSP Turbo
2018 Hyundai Santa Fe Highlander
1967 XR FALCON 500
Cars previously owned:
2021 Subaru Outback Sport
2018 Subaru XV-S
2012 Subaru Forester X
2007 Subaru Liberty GT
2001 AU2 75th Anniversary Futura
2001 Subaru GX wagon
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1984 Datsun Bluebird Wagon
1975 Honda Civic
blueoval is offline   Reply With Quote Multi-Quote with this Post
Old 27-08-2013, 08:22 AM   #23
sednwol
sednwol's Avatar
Thx Blueoval, I have had the same idea, have had the transmission done full flush and service, all ok, tommorow will get the bearing done.
When I swerve hard to the left the noise momentarily stops, when I swerve to the right the noise is constant. Think it is a bearing...I hope lol.
Old 27-08-2013, 11:15 AM   #24
blueoval
Critical Thinker
blueoval's Avatar
Sounds plausible that its a wheel bearing then mate. Let us know the outcome.
1967 XR FALCON 500
2018 Subaru XV-S
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1975 Honda Civic
Old 27-08-2013, 11:33 AM   #25
Dave_Obsession
Resident AFF detailer
Dave_Obsession's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Helpful and detailed posts on car care.
Yep sounds like a bearing. Have had both ones at the front replaced in the last few years, sounded exactly as you've described.
No longer an 'active' detailer.
Dave_Obsession is offline   Reply With Quote Multi-Quote with this Post
Old 28-08-2013, 06:52 PM   #26
sednwol
sednwol's Avatar
Update, its was the front left wheel bearing. All is now nice and quite. I hope this thread helps others who start to hear this difficult to identify noise/issue. The whining noise actually sounded as if it was beneath the centre consol and sounded (as someone earlier stated) like a droning propeller.The noise obviously travelled through the chassis. Hopefully this will help others who (as I did) do a search for "whining noise AU".
Old 28-08-2013, 11:08 PM   #27
ronwest
All Bran = Regular Member
http://www.fordforums.com.au/vbporta...?articleid=222
Old 30-09-2013, 09:58 AM   #28
XT UTE 68
GIVIT Rally 84 BARRA XE
XT UTE 68's Avatar
Can confirm this same issue, sounds like a diff is gone, but I consider my AU3 ghia at only 140000 genuine kms it hasn't done enough to be diff yet. I thought something wasn't right when the other night I rode in the passenger seat, and just sitting on the other side of the car the noise sounded to be coming from a different place in the car. Left front was the issue.
Thanks ron, your pictures and story make it look easy.
XT BF2 SZ BA
XG E Outback Ute
XE BARRA - http://www.fordforums.com.au/showthread.php?t=11382891 - 2007 GER Via Birdsville, 2008 via Broken Hill, 2009 via Cape York, 2012 via Karumba, 2014 via Innamincka, 2016 GIVIT RBR, 2017 via Boulia, 2018 Via Mighty Murray, 2019 Via Dig Tree, 2020 Via Thargomindah, 2021 Via Lawn Hill Gorge, 2023 Westmar - Gunnedah
Sponsors, London Fire & Safe www.fireextinguisher-and-safes.com, G&D exhausts and suspension Beenleigh , Beenleigh Bob Jane
XT UTE 68 is offline   Reply With Quote Multi-Quote with this Post
