22-04-2014, 06:27 PM | #1 | ||
hey guys my steering makes a cracking sort of noise when steering from lock to lock in a stationary position but fine whilst driving. I know this will probably be the rack on its way out but if it was the rack would the noise happen even with the engine off and steering manually?
23-04-2014, 04:46 PM | #2 | ||
LIFELONG DJR SUPPORTER
There was a recall on SERI and SERII to ensure the rack is secure.
I would seek professional advice if I was uncertain about what was going on with my steering!
23-04-2014, 05:15 PM | #3 | ||
Au Falcon = Mr Reliable
Hi there, like mnm96 said the au's 1/ 2 's had a recall on the steering rack. Hope this helps -
http://www.drive.com.au/editorial/ar...leID=5309&vf=1 http://www.fordforums.com.au/showthread.php?t=5681 cheers, Maka
08-01-2015, 02:09 PM | #4 | ||
Hi.
Hope that you already have worked out where the noise is comming/came from. My wife's S3 had a noise that I first thought was the steering rack, ended up being the D bushes on the sway bar where dry. A little bit of graphite grease and no more noise. Hope that may help you. |
