Old 20-08-2011, 04:49 PM   #1
boss62
Default 2001 AUII 6 Stacker problems
Hi,
Recently purchased an AUII Falcon, Radio works great...however when I tried to use the CD player it just started clicking and whirring..no lights are on anywhere. It does this everytime I start the car...makes the noises in 6 times, as if it's trying to change the CD. Would you have any idea what the problem may be? Thanks!
boss62 is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2011, 12:19 PM   #2
richo77
richo77's Avatar
Default Re: 2001 AUII 6 Stacker problems
Disconnect the battery, reconnect, it should correct itself. Good luck with it!
richo77 is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2011, 12:30 PM   #3
boss62
Thanks for that...it worked a treat!
Tried using CD player again and the same thing happened...do you know what the problem might be as to why it keeps doing it. I don't want to replace it with an aftermarket player. Thanks!
Old 21-08-2011, 03:32 PM   #4
richo77
richo77's Avatar
When mine did it I used one of those CD cleaners and then it came good again. I think as long as you are gentle with it, press the load button, don't change through CDs often, there's no reason it won't last. If it does eventually pack it up, ASL sell reconditioned units.
Old 21-08-2011, 08:23 PM   #5
AU Mont
why not?
get a double din player with front usb connection, buy the necassary ISO connectors and it will sound better, work better, and look better !!
AU Mont is offline   Reply With Quote Multi-Quote with this Post
Old 22-08-2011, 08:42 AM   #6
FADI75
Sponsor
Hi,
hi
we can offer you a changeover unit with 12 months warranty $335.00 all included.
cheers
ASL
AUTHORISED FORD REPAIR CENTRE
email: info@aslautomedia.com
