Old 18-05-2021, 09:22 AM   #31
NZ XR6
Default Re: OBD2 adapter to use with Forscan
Checked a few things in Forscan. The delay is 16 ms, which the app says is good. Forscan IDs it as V2.2, confirmed by the ELM Identifier app. I have also setup Forscan to connect automatically.
Old 18-05-2021, 10:33 AM   #32
T3rminator
T3rminator's Avatar
Brilliant! Thanks! Think I'll get myself one.
Forscan takes a bit longer to sync than others, because Forscan will scan all trouble codes at the start. If you read the logs as it connects at the start, it will go through the DTCs for PCM, BEM etc. Thats why it takes a bit longer.
T3rminator is offline   Reply With Quote Multi-Quote with this Post
