12-11-2019, 02:32 PM | #1 | ||
Hi Guys.
I am currently compiling a model code list for Aussie Fords & am having difficulty finding model codes for Cortina, especially TC to TF. The codes that I'm referring to are the 5-digit codes stamped on the body ID plate. For example a 1968 240 2-door has the code 12814, while a 1969 GT has the code 12938 & so on. Most of this info is in Ford parts catalogues & other Ford literature, badly sadly usually not in workshop manuals. Does anyone on here have a list of these codes or have access to the relevant manuals ? Thanks in advance. Regards Dr Terry. |
12-11-2019, 05:03 PM | #2 | ||
Cabover nut
Do these help sorry about the size. From TE TF fiche.
12-11-2019, 05:34 PM | #3 | ||
Here you go, from 1962-1982..
Cortina 62-65 Model Codes.pdf Cortina 65-67 Model Codes.pdf Cortina 80-82 Model Codes.pdf Cortina 71-74 Model Codes.pdf Cortina 74-77 Model Codes.pdf Cortina 77-80 Model Codes.pdf |
13-11-2019, 04:05 PM | #4 | ||
Thanks guys, that will fill quite a few blanks.
While I'm at it, does anyone have these numbers for late XF, XG & XH commercials. Dr Terry |
13-11-2019, 05:21 PM | #5 | ||
13-11-2019, 05:54 PM | #6 | ||
Thanks again you guys are great.
There seems to be some anomalies in the TC model numbering. Ive recorded a few codes from later series TC Cortinas that don't appear on that list. When you look at them, there must be a series of missing models numbers in 1972 & 1973 but the above list has all TCs using a 1971 code. This doesn't happen with any other Cortina. Does the parts catalogue agree with the above list (Cortina 71-74) ? Dr Terry |
13-11-2019, 06:21 PM | #7 | |||
Dr Terry |
14-11-2019, 03:48 PM | #9 | |||
Cabover nut
XF GL panel van model code 45683 My 93 XF GL panel van model code is 45018 !!
14-11-2019, 04:00 PM | #10 | ||
15-11-2019, 08:48 AM | #12 | ||
Cabover nut
15-12-2019, 02:34 PM | #13 | ||
Some more codes that I have found Dr Terry..
89 XF Commercial: 45671 Std ute, 45681 std van, 45674 GLS Ute. 90 XF Commercial upgrade: 45071 GL ute, 45081 GL Van, 45074 S ute. What else are you still missing? |
17-12-2019, 09:34 AM | #14 | ||
Left off XG:
GLi Ute: 45371, S Ute: 45374, XR Ute: 45375 and Gli Van: 45381. Have we covered everything? |
18-12-2019, 08:22 AM | #15 | ||
That looks like it for now.
Thank you Dr Terry |
