Old 05-10-2010, 11:22 PM   #1
WineAnt
WineAnt's Avatar
Default Ford TX5 (1993) - idling speed & possible damage
Hi Ford fans
I'd like to try something new regarding my car's REV counter which falls so quickly after each gear change (it's a manual, '93 model).
Two questions which involves the idling speed of the engine:
1) is there any risk in making the car idle too fast? Any possible reason that it can't be good for the engine?
2) and finally, what should the correct idling speed be for a '93 TX5? I know this is a hard question to answer, since it's basically a screw you need to turn.
Thanks everyone. I just want to find out from you guys (& girls) if there's any risk of damaging my car in changing the idling speed of the engine.
Regards & thanks,
WineAnt
WineAnt is offline   Reply With Quote Multi-Quote with this Post
Old 20-10-2010, 10:53 AM   #2
Wallie
The Red Rocket
Wallie's Avatar
650 to 700 rpm idle speed.
Wallie is offline   Reply With Quote Multi-Quote with this Post
Old 03-12-2013, 03:22 AM   #3
Waris93
Default Re: Ford TX5 (1993) - idling speed & possible damage
There is no damage on just adjusting your idle speed high, only thing is it will drink more fuel on parked(idling more then you should) if its automatic you can possibly damage your transmission if you idle it more then 1200-1300, it's best never to touch factory idle settings if your udles are low or high there is something wrong with your car, pull some codes and it will save you so much time on pointing out where your problem is.
Waris93 is offline   Reply With Quote Multi-Quote with this Post
