24-12-2019, 09:32 PM | #1 | ||
Hi guys/girls my ford capri 1600 4 cylinder won’t start, not sure where to connect wires, all the wires are connected and it goes click when I turn the key to start it,I have got interior light, reds, radio and front lights all work but just won’t start, wondering if anyone has got a capri 1600 and if I could have a pic of the wires In the engine bay or if anyone has got a diagram that would be much appreciated,
Thanks 😊 |
24-12-2019, 09:47 PM | #2 | ||
Was it running before. Is the battery fully charged.
24-12-2019, 10:58 PM | #3 | ||
formerly ford3000gt
I've cropped the wiring diagram for the 1600GT which should be the same as your '72 XL?
You could have a suspect solenoid on the starter motor, but I'm no expert! Sorry the diagram is so small but that's the largest I can post.
Current ride: '83 Mk.3 Capri, 2.8i, 5-spd |
25-12-2019, 03:01 AM | #5 | ||
Hi mds69 yeah it’s got a brand new battery and the motor was running before
25-12-2019, 03:04 AM | #6 | ||
Looking for clues...
Does the starter motor work? You'll need a multimeter to test voltages at the solenoid, and the starter motor.
A small amount of power to the solenoid provides a lot of power to the starter, through the solenoid.
Swanny’s Fundraiser for the 2024 MS Brissie to the Bay 100km Bike Ride 2016 Ford Falcon FG/X XR6 Turbo you beaut ute 1985 XR4Ti Sierra - Build Thread 1971 Fairlane 500 and... a collection of Jeep Towpigs and... two collections of rust and some new plastic bits roughly shaped like an F-Truck and.... some spare metal bits with holes in them |
26-12-2019, 01:15 AM | #7 | ||
hi swanny yeah the starter motor works
26-12-2019, 07:59 AM | #8 | ||
Does it turn over?
How long since it last ran? Has the distrib been removed/replaced? Is there spark at the plugs? Is the timing correct? Is there fuel at the carb? Is fuel getting to the cylinders? How old is the fuel?
Our FORD Stable 2008 FG GT-E - Lightning Strike 2007 BFII Fairmont Ghia - Seduce 2007 BFII Falcon ES - Ego |
26-12-2019, 08:10 AM | #9 | ||
BA/F6 BF/F6 SSV/R TTG
I had a 78 escort. One day a small wire came of at the + battery terminal and the car stopped. Wouldn't start until I reconnected the wire. cant really remember exactly . It was 40 years ago.
BA BF FPV starter button repairs. PM me. Nizpro equipped and Tuned by the BEST in the west Xtreme Ford Tuning 479RwKw Fuel limited, more pumps and power too come. F6#0507 & #0639 Pro racer and Tech expert NIZPRO modifying falcons like Premcar can only dream of , see VIDEO below. https://youtu.be/oa4IfguGQ-A |
26-12-2019, 08:12 AM | #10 | ||
Check the coil wiring.
26-12-2019, 10:36 AM | #11 | ||||
This is like pulling teeth, anyway onward & upward.
Cranking is different to the engine actually starting. All my old Escorts had bendix starters and sneaky contacts in the solenoids to by-pass the coil ballast, do you know what your's has? Anything you don't know how to answer just ask. |
28-12-2019, 05:47 PM | #12 | ||
Hi mate sorry for the late reply mine hasn’t got a solinoid on the starter motor mine seperate, it used to turn the engine
27-04-2020, 08:20 AM | #13 | ||
If its a manual put in 4th and rock the car the starter could be jammed in the ring gear
had it happen to me a few times |
27-04-2020, 08:26 AM | #14 | ||
Get the battery load tested. A click can indicate a sad battery...
27-04-2020, 09:24 AM | #15 | ||
27-04-2020, 12:42 PM | #16 | ||
NOTE; 12v is loosely termed as battery voltage - easier to wright multiple times
If it hasn't got a solenoid on the starter then there will be a standalone one follow the battery pos+ cable till you find were its mounted and give it a tap and see if it starts. if not- If you have a multimeter check if you have 12 volts to the small wire on the solenoid when cranking , there should be 4 wires to the solenoid 2 x battery pos + power in and out. 2 x small wire 1 x exciter 12v from key which pulls in the solenoid allowing the battery pos + to "flow" through the solenoid when cranking. 1 X small wire to earth or battery neg - . Note some standalone solenoids are earthed through the mounting and will only have 1 x small wire = exiter wire 12v from key if you have 12v to exiter wire then you should get 12v coming out of solenoid to starter motor . if not then solenoid is U/S and replace . If you are getting less than 12v to exiter wire then you can fit a relay in line to boost the voltage . If you are getting no voltage to exiter wire you will need to back trace exiter wire to find out ware you are loosing power. if you have 12v coming out of solenoid then remove starter and bench test by neg -jumper cable to body of starter and pos + jumper cable to pos + lead pole Note if the starter is good it will jump when it spins. You need to watch the sprocket at the end to make sure it throws out and spins as if it only does one its U/S Hope this helps
XC GS OLD SCHOOL MUSCLE Audi A4 S-line quttro Xc falcon Previous fords- xc falcon 500 ,250 x flow 3 speed xc gs worked 250 x flow 4 speed xa Fairmont 302 auto wagon xb falcon 250 log auto 4 door xb falcon 200 log auto ute xc gs project - had to sell :-( xc gs 302 4 speed 4 door xc gs 351 auto 4 door zf fairlane 302 auto zk fairlane 250 x flow carb auto zl fairlane 250 x flow EFI auto xg ute , BA falcon dedicated gas xd, xf x 3 ,ea,eb,ef,au x 3,telstar tx5 |
03-01-2021, 12:11 PM | #17 | ||
For whats its worth I have a 1600 powered Mk 1 esky, for 4 years had trouble starting if left for more than a week or so, tried all the usual ,new battery solenoid new starter motor various advice from those lot more savy than me. Auto electrican tried various fixes then recalled had problems similiar with first corollas, fixed by putting a relay to the starter motor, tried it and problem solved. Starts every time now, a cheap easy try
