Old 31-05-2011, 04:00 PM   #1
b2tf
not here much anymore
b2tf's Avatar
Default AU V8 Handy Part Numbers and references
Purpose of this thread is to compile all the part numbers for the various common parts the Windsors use. Talking things like the Cam Position Sensor etc.
If you have purchased a part, please post it up using the following format:
Part Name (what it is)
Part Number (from the supplier you got it from)
Supplier (where you got it)
Price (if you prefer not to say that's ok)
Example:
K&N Panel Filter to suit AU V8 Airbox
P/N KN33-2015
Supplier - Autobarn
Price - $50
I will add a couple I know of but if we all pitch in we should be able to create a handy list.
RAM 1500
Old 31-05-2011, 04:08 PM   #2
b2tf
b2tf's Avatar
Default Re: AU V8 Handy Part Numbers and references
Yella Terra 'Street Terra' Adjustable Roller Rockers - 1.72:1 Ratio
PN: ST2027
Supplier: Yella Terra direct or any good auto store
Price: $?
Crow Cams Valve Springs to suit GT40P Heads
PN: 7738-16
Supplier: Crow direct or any good auto store
Price: $unsure - been a while since I bought some
NOTE: Suits cams UP TO .550 lift
MSD Ignition Coil Packs to suit AU V8 (direct fit)
PN: MSD8241 (you need 2)
Supplier: Most good auto stores, summit online etc.
Price: $varies on supplier but you should get change out of $300
ARP Header bolts - replaces the standard hex key bolts on the standard headers and can also be used to fit aftermarket ones
PN: ARP-100-1202 - pack of 16
Price: varies but about $30 or so
RAM 1500
Old 31-05-2011, 10:44 PM   #3
b2tf
b2tf's Avatar
Replacement Camshaft Synchroniser to suit AU V8
PN: STANDARD MOTOR PRODUCTS Part # PC350
Supplier: Rock Auto Parts www.rockauto.com
Price: will vary on AU$ strength
Replacement MAF to suit AU V8
PN: MOTORCRAFT Part # AFLS155
NOTE: Check the application as MAF's differ between series and XR/non XR
Throttle Position Sensor to suit AU V8
PN: DELPHI Part # SS10387
Spark plugs to suit AU V8
PN: NGK BPR6EFS13 or NGK TR55IX (Iridium)
Price: Around $4-5 per plug, iridiums closer to $20 per plug
NOTE: NGK recommend the Iridium ONLY, the BPR6EFS13 is actually for the Holden 304 V8 but will work quite well in an AU V8 and is cheaper than the Iridiums. I'm using BPR6EFS13 in an AU3 XR8.
RAM 1500
Old 01-06-2011, 12:56 AM   #4
InfernoSR
Sales Representative
InfernoSR's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: For research and posted write up on cooling system care and repair in AU.COM and offering help where possible
AU P/S Pump Top Hose Connector
PN: FO-BA3F656B
Supplier: Genuine Ford
Price: $11.88 RRP
Note: OEM Desc - CONNECTOR PWR STRG
AU P/S Pump Top Hose Connector O'Ring
PN: FO-388898S
Price: $6.94 RRP
Note: OEM Desc - SEAL O-RING
InfernoSR is offline   Reply With Quote Multi-Quote with this Post
Old 01-06-2011, 05:49 PM   #5
auIILTD
5.6L x 2 pilot
auIILTD's Avatar
PN: ST2027
Price: $?
Small correction, the ST2027 are not the adjustable version. The ST2027 is non-adjustable and fit under the existing rocker covers.
2002 AU II LTD
2002 XR8 pursuit 250
auIILTD is offline   Reply With Quote Multi-Quote with this Post
Old 02-06-2011, 06:48 PM   #6
Boza
Boza's Avatar
does anyone have any part numbers for extractors I wanna finish off my exhaust and would like some part numbers on extractors.
Mines a series 1.5 late dec 99 au1 xr8 ute so unsure which heads i'm runnig
Boza is offline   Reply With Quote Multi-Quote with this Post
Old 04-06-2011, 10:11 AM   #7
b2tf
b2tf's Avatar
Shall dig some up at work today.
RAM 1500
Old 04-06-2011, 11:43 AM   #8
auIILTD
5.6L x 2 pilot
auIILTD's Avatar
Pacemaker - PH4000
Hurricane - HU354STM
To be confirmed - these were part number supplied as a part of a quote as idea as to costs of AU V8 exhaust headers.
Stu
2002 AU II LTD
Old 02-12-2020, 12:33 PM   #9
Climaxxx
Smile Re: AU V8 Handy Part Numbers and references
If anyone is chasing passenger airbag clips which are now obsolete, i have some sets of 4 for $50. Ford number AU F04B26A.
Climaxxx is offline   Reply With Quote Multi-Quote with this Post
