Old 18-08-2022, 12:50 PM   #1
Johnno.o
Default Au falcon dash lights
Hi, I have 2001 falcon xr8 and the dash lights do not come on, I put another cluster and it works fine, there is 1 light holder missing just a hole i cant get the light in ,with 1 missing will it cause the light circuit to not work. Thanks John.
Johnno.o is offline   Reply With Quote Multi-Quote with this Post
Old 26-08-2022, 12:55 PM   #2
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
Default Re: Au falcon dash lights
Do you have Forscan?
Old 02-09-2022, 06:25 PM   #3
Johnno.o
No I don't. Thank you.
Old 05-09-2022, 12:50 PM   #4
Uncle_Ken
Uncle_Ken's Avatar
search the forum for it. Its a free program and it could find an error to help with the cluster . Try cleaning the globe housing it might stop the currant. Also try looking at the board with a magnifying glass and look for fine breaks
Old 05-09-2022, 02:41 PM   #5
mad2
Regular...with metamusal
forscan
best to use a windows based laptop, but up to you what you actually use. with the free software you don't get to use everything but you can get a temporary license [for 2/3 months] that allows you to make full use of the program. hava good read about it 1st so you get an idea of what it's about. compared to the 'B' series cars you may not be able to read everything in the AU [didn't try it out on me 'Ol yella [AU wagooon]. but it should prove useful.
mad2 is online now   Reply With Quote Multi-Quote with this Post
Old 10-11-2022, 05:42 PM   #6
TS50AU
Red ones go faster!
TS50AU's Avatar
Originally Posted by mad2 View Post
forscan
Hey Mad. Wanted to suss out the body module on the TS50. Which cable did you buy? I found an Australian supplier (OBD-AUS FOR-USB) but they told me theirs doesn't work well with AU's.
Wayne
TS50AU is offline   Reply With Quote Multi-Quote with this Post
