Prev Previous Post   Next Post Next
Old 09-01-2009, 11:16 PM   #11
#Russ#Es#
Hello Koni's!
#Russ#Es#'s Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: This member has made a few valuable contributions to the Forum in the Focus section, seems to know exactly what he is talking about with his posts, which are helpful and concise.
Originally Posted by AnthonyTDCi
yep im definatly going to have to do this mod. how much was the light from ford?
how is the light secured into the roof lining? or is it just sitting there?
It was a while ago that I got the quote from a dealer, but pretty sure it was over the $150 mark...
The fitting has little tabs on one side, and a metal spring clip that holds it in place - its going anywhere. The good thing is its still relatively easy to remove the clear lens if you need to change a bulb.
Since buying mine, I have seen upper-spec (UK) model fittings that have reading lights in each side.
2006 LX FOCUS SEDAN
Titanium Grey, factory bodykit, slightly debadged
CSA Motorvatr 17's/Kumho KU31's, Eibach Prokit/Lovells rear springs, Koni Sports Kit
Lower airbox removed, K&N Panel filter
Momo gear knob + boot + pedals, Ghia boot garnish, Zetec Chrome interior door handles
JVC KW-XR816 Headunit + more to come...
#Russ#Es# is offline   Reply With Quote Multi-Quote with this Post
