Old 26-03-2017, 12:12 AM   #1
deeppocket
Default Wf front wheel bearing removal. A
Looking at replacing the right hand front wheel bearing & am concidering doing it myself. Is there any special tooling that I need for the job. Are they taper or roller bearings​. Method info would be handy too. Thanks for any help.
deeppocket is offline   Reply With Quote Multi-Quote with this Post
Old 26-03-2017, 09:12 AM   #2
russellw
Chairman & Administrator
russellw's Avatar
Default Re: Wf front wheel bearing removal. A
There are a couple of special tools required - one to remove the wheel hub, one to remove the wheel bearing outer and one to remove the wheel bearing itself.
They are available in two sets:
49 B026 1A0 Puller Set, Wheel Hub (or universal equivalents)
49 D017 2A0 Remover Set, Wheel bearing
Russ
Observatio Facta Rotae
