Old 15-06-2013, 12:55 PM   #1
russxr67
I hate ricers
russxr67's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Always seems to post good advice and is pretty helpful.
Default Split mono leafs vs conventional leaf springs
Gotta buy some springs real soon and am looking for feedback on what works.
Car is an XR Fairmont and will see some strip action but mainly street .
russxr67 is offline   Reply With Quote Multi-Quote with this Post
Old 15-06-2013, 03:16 PM   #2
Roo2
Roo2's Avatar
Default Re: Split mono leafs vs conventional leaf springs
I just bought the calvert front & rear shocks plus the mono split leafs. Have not had a chance to fit them yet Russ so I can't give any practicle feed back but come September
The feed back I have received has been all good even for street use. But I will have a different set of shocks for the front when I'm not racing as I think the 90/10 may be a tad of a compromise for street cruising.
Roo2 is offline   Reply With Quote Multi-Quote with this Post
Old 15-06-2013, 04:27 PM   #3
russxr67
I hate ricers
russxr67's Avatar
Cool mate, I'll see you tomorrow and chat about it.
Old 15-06-2013, 04:51 PM   #4
Windsor
If it's mainly a street car, why bother?
Cheers,
Steve.B
Windsor is offline   Reply With Quote Multi-Quote with this Post
Old 15-06-2013, 09:20 PM   #5
russxr67
I hate ricers
russxr67's Avatar
Well, if they can do the job of a multi leaf setup without having the extra weight associated then I'm all for it.
If they can't then that's a different story.
Old 15-06-2013, 11:42 PM   #6
ToddZC
Thunderbolt driver
ToddZC's Avatar
I ran a set on my old ZC, in combination with a set of Caltracs. No problems with them on either the street or strip. I'm not sure how well they'd work without the bars at the strip. Suspect they'd suffer a bit of wrap on launch without the bars.
Thunderbolt Racing Team
You can't spell FEar with out an FE.
ToddZC is offline   Reply With Quote Multi-Quote with this Post
Old 16-06-2013, 01:15 PM   #7
greencapri408
greencapri408's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Simon is a worthy recipient, his willingness to share  knowledge here for Forum Members and his wealth of knowledge. He has made himself available not only through the Forums but allowing members to contact him by mobile as required
iv got them in my xt only ran them on the street so far
im using competition engineering slide a links with them
iv havent noticed anything bad about them compared to multi leafs
cant wait to get it to the track
FORD because nothing compares
greencapri408 is offline   Reply With Quote Multi-Quote with this Post
Old 16-06-2013, 10:32 PM   #8
Windsor
You are worried about a few pounds of weight in a street car?
Cheers,
Steve.B
Old 17-06-2013, 02:59 PM   #9
XT302
Cheers,
Steve.B
In theory less upsprung weight should assist in better handling.
It's my call pizzoff, and I just called it
XT302 is offline   Reply With Quote Multi-Quote with this Post
Old 17-06-2013, 03:28 PM   #10
63futura
63futura's Avatar
Russ i had my springs redone by WA suspension
There was and old guy there that used to be into drag racing and he shorten some leafs and added one and since then ive never had axle tramp and is good enough to do 1.5 60ft on 235s and all up cost around $400
63futura is offline   Reply With Quote Multi-Quote with this Post
Old 17-06-2013, 06:35 PM   #11
prasac
prasac's Avatar
just a plain jane, low $ setup under the Capri. 15 year old leaf springs, Strange Shocks ($600) and a custom Caltrac setup. consistent 60's pass after pass, even with the old 15 year old Pedders shocks it ran a 1.30 60's, new Strange run 1.2's on slicks or radials. when it was a 10-sec NA ran a 90/10 front, has 60/40's now. drives so smooth on the street.
prasac is offline   Reply With Quote Multi-Quote with this Post
Old 17-06-2013, 07:40 PM   #12
russxr67
I hate ricers
russxr67's Avatar
Did you get them from competition engines Simon?
Old 17-06-2013, 08:04 PM   #13
greencapri408
yes mate
Old 17-06-2013, 08:37 PM   #14
russxr67
I hate ricers
russxr67's Avatar
What did he slug you for a set if you don't mind me asking?
Old 17-06-2013, 08:58 PM   #15
greencapri408
i got the mono leafs and the front and rear calvert shocks for $900
Old 17-06-2013, 09:27 PM   #16
russxr67
I hate ricers
russxr67's Avatar
You gonna put 90/10s up front?
Old 17-06-2013, 09:49 PM   #17
greencapri408
yeah mate
i had them in the front of my xy for yrs with no issues
if its no good ill put 12 way adjustable qa1 s in it
Old 17-06-2013, 10:34 PM   #18
russxr67
I hate ricers
russxr67's Avatar
What about adjustable konis on the front? The 90/10 shocks wouldn't be much good for cornering would they?
Old 18-06-2013, 11:09 AM   #19
prasac
prasac's Avatar
90/10 is fine for cornering if the car is setup right.
Old 23-06-2013, 11:03 AM   #20
noosacuda
noosacuda's Avatar
Just a quick point,(i'm not being a smart "A", Know-it-all or anything) you'd be better off having the clamp on the front of the leaf springs and no clamps on the rear section of them.
noosacuda is offline   Reply With Quote Multi-Quote with this Post
Old 23-06-2013, 02:31 PM   #21
prasac
prasac's Avatar
been there done that, this worked better for us.
Old 23-06-2013, 09:49 PM   #22
greencapri408
my capri was the same needed the rear clamp i had a pic here some where of mine leaving on a 9.0 pass with the rear of the springs seperated about 300mil
looks crazy in the pic
Old 24-06-2013, 12:21 PM   #23
prasac
prasac's Avatar
100% agree it looks crazy.
Old 06-09-2013, 08:59 PM   #24
azza11
azza11's Avatar
we have a HG in town where i live, he ran a 8.1 something last week at Willowbank, he has leaf springs, he is also a suspension guy guru in setting up rear ends, he has done Stu Henrys Capri, but he runs altra dear shocks in rear, but low 7’s. His HG is relevant due to its weight compared to a XR. He has a take on the Calvert System, one of the mags has a feature on him, its in the Performance Garage mag. I keep up to date by reading what they are doing overseas, especially leaf springers running in X275 class, this is the closest class to what most larger cars can run with drag radials etc and run the tyre. Also have a look at what the Trick Manswetto falcon was running, i know his setup is in a Street machine Ford’s issue. He has bigger perches with lowering block built in, every thing is bigger, but runs a full pack of leaf springs, i like the look of the mono leaf, as you can change the set up easily. Designed to use the Calvert adjustable shocks.
1967 XR Falcon Wagon, Super Pursuit…….for now.
*****XR PARTS WANTED*******
azza11 is offline   Reply With Quote Multi-Quote with this Post
