Old 06-02-2008, 07:25 AM   #1
GAW
Default power stear fittment
HI ALL , has anyone fitted a power stearing unit in a 88 laser before ? my daughters car was not power stear but i want to fit one into it for her . i can purchase the complete unit from a wreakers for $150. is it a huge job ?
GAW is offline   Reply With Quote Multi-Quote with this Post
Old 06-02-2008, 09:44 PM   #2
dirty hands
Over Thinker
dirty hands's Avatar
spare bolts
this unit may have a smaller filler tin or straight in to the pump
just need the powersteering pump
holding bracket for the pump
the belt and tensior if it needs one or runs off the alternator tensioner
use the right powersteering oil for the ford
the two pipes (the end of the pipes may have very small 0 rings)
any clips to hold the pipes in place against the chassis
these joins and threads strip easily so hand start every one then tighten
to fit rack
the powersteering rack bolts up the same spot as the original
undo the spline bolt at the base of the steering column spead the spline a little
both tie rod ends to undo
wheel alignment needed after :
My car goes Brumm Brumm
Old 07-02-2008, 06:51 AM   #3
GAW
Thanks ill give it a go on the weekend .
Old 11-02-2008, 12:51 PM   #4
GAW
got the power steer in no drama , now the alignment is way out ,the pasenger side wheel is very toe in and sitting on the tyre sholder . dont know why , i guess an alignment may rectify ???? hope so
Old 11-02-2008, 02:26 PM   #5
dirty hands
Over Thinker
measure the distance from the middle of the front tyre each side
then measure the distance from the middle of the back of the front tyre
undo the tie rod end locking nuts
and adjust the rods of the rack with stilsons (thread in or out )
so both of the meausrements front and the back of the front tyres
are almost the same
this willl do untill you get a propper wheel alignment
