23-09-2014, 09:06 PM | #1 | ||
Hey guys, mums xr8 has the 6 stacker headunit and wiring in the parcel shelf for the sub, chucked a premo shelf in and my working ltd sub and no go, it wouldnt work, does it need the amp?
23-09-2014, 09:59 PM | #2 | ||
FG XR50 TURBO
i think so as the sub runs from the amp but i could be wrong
23-09-2014, 10:00 PM | #3 | ||
Yes. If installed you will find it in the boot behind the right hand covers .
BUILD AU II FAIRMONT GHIA HERS AU II Fairmont Ghia 7" DVD/GPS Radio 19" Wheels HIS FG XR8 Ute Lux Pack Tech Pack Touch Screen GPS |
24-09-2014, 02:36 PM | #4 | |||
5.6L x 2 pilot
You will see the amp on the right hand side of the boot behind the lining of your LTD. Not sure if the wiring will all be there in the XR as some of the amp wiring looks like an afterthought - not necessarily loomed. Cheers Stu
2002 AU II LTD 5.6L 342ci T3 Short, AFR165 heads, Comp XE270HR-12 Cam, Brembo 4/4s(355/330), T3 5 spokes, LC-1 wideband, Whiteline HD swaybars, TCE 3K Hi Stall, PWR Auto Trans Cooler, Koni shocks, King Low Springs, Hurricane headers, 100 cpsi cats, Twin 2.5" exhaust. Quarter Mile: 13.73 @ 105.86mph Runner Up NA/DA to BF Fairlane/LTD Geelong AFD 2024 2002 XR8 pursuit 250 Custom twin 2.5" exhaust w Herrod modifed extractors, Tuned with Moates QH
24-09-2014, 06:13 PM | #5 | ||
Next upgraded Mk1 Leopard
my XR8 wasn't
UK Sad Face ..LOL
27-09-2014, 02:18 PM | #7 | ||
Just a thought, if you power up the amp, will a standard sound system work? And will it pick up the sub woofer?
UK
