Old 23-02-2005, 04:33 PM   #181
Tornado
AKA MYTE8
Tornado's Avatar
Originally Posted by Casper
your A/F ratio is the bottom line. It should be up near the 13 line (yours goes from mid 12's to low 11's) to be optimum. To be honest, its not all that bad really, better than a lot of AU V8 ratio's I've seen.
Theres not too much you can do about it though, maybe try a stock fuel pressure regulator, or get a Chiptorque chip for about $600 that will flatline it in the optimum area. Unichip will do it too... but at $1200 its a bit more expensive.
The AFR on my graph looks pretty bad then..
Tornado is offline   Reply With Quote Multi-Quote with this Post
Old 23-02-2005, 04:41 PM   #182
FTE217
T3/Sprint8
FTE217's Avatar
yours isn't too bad at all Goran, bugger I'm having trouble getting my attachment up but yours is close to 12.6, once I get mine up you'll see I'm on 12.8.
Tickfords T3/TS50 '02
Sprint8 manual Sept 24 '16
Daily Macan GTS
Old 23-02-2005, 04:53 PM   #183
Tornado
AKA MYTE8
Tornado's Avatar
It starts off close to 14 then drops right down ????
Old 23-02-2005, 07:28 PM   #184
Casper
Contributing Member
Casper's Avatar
This is Bluedrivers dyno chart:
Older, wiser, poorer.
Old 23-02-2005, 08:00 PM   #185
Mark351
Built Ford Tough
Mark351's Avatar
Or wait for AU-Edit
Black on white '83 SWB F100 C6 auto 351C on gas and on the ground --> Project Thread
'55 F100, just a roller at the moment, new project
Silver MY12 Volkswagen Amarok
Mark351 is offline   Reply With Quote Multi-Quote with this Post
Old 24-02-2005, 10:04 PM   #186
Stav
Smile
Stav's Avatar
any more dyno sheets?
Old 24-02-2005, 11:41 PM   #187
davocol
davocol's Avatar
Thanks for the responses guys, it appears the chip would definitely be the way to go. I think I will hang out for edit though, I had a long chat to Danny on the day from SCT and I think this is definitely the path I am going to go down. Combined with a decent exhaust it should be good for at least 175 at the wheels.
SZ Territory Titanium
davocol is offline   Reply With Quote Multi-Quote with this Post
Old 26-02-2005, 12:28 AM   #188
buickman
buickman
buickman's Avatar
Well I have the lowest by .6 of my 2 runs LOL. The only complaint is the car ran a rich A/F mixter as I didn't expect it to run above 120KW at the wheels I'am to worried on the Dyno figs. Iam having a spot of bother to upload the sheet.
buickman
buickman is offline   Reply With Quote Multi-Quote with this Post
Old 26-02-2005, 01:50 AM   #189
FRDGAL
GT-P #0336
FRDGAL's Avatar
buickman
What are the mods on your car?
2003 FULLY OPTIONED MERCURY SILVER BA GT-P BUILD #336
REVERSE CAMERA - SAT NAV - PIONEER SUB & AMP - SUNROOF - DVD PLAYER - CUSTOM DUAL EXHAUST
~Tuned By Bluepower Racing~
FRDGAL is offline   Reply With Quote Multi-Quote with this Post
Old 26-02-2005, 07:31 AM   #190
Stav
Smile
Stav's Avatar
Those dyno sheets look wierd!!!! I have never seen 2 dyno sheets with those bumps??!! Something funny there! :
Old 26-02-2005, 12:14 PM   #191
jonbays
TL40 Wagon?
buickman odd dyno result what happened at 160k?
weird stuff
jonbays is offline   Reply With Quote Multi-Quote with this Post
Old 26-02-2005, 12:55 PM   #192
dansedgli
dansedgli's Avatar
here is mine for you guys to peruse.
http://members.optusnet.com.au/~dansedgli/mypic51.jpg
Turbo AU ute ~ Nice legs, shame about the face. 282rwkw at 15psi.
dansedgli is offline   Reply With Quote Multi-Quote with this Post
Old 26-02-2005, 12:56 PM   #193
dansedgli
dansedgli's Avatar
From the speed do you think mine was done in 3rd gear?
Old 26-02-2005, 01:21 PM   #194
Casper
Contributing Member
Casper's Avatar
What diff was in it at the time?
If its the original diff its been done in 2nd. A 3.45 will run to about 130kph in 2nd, well past 160kph in 3rd. So if thats a stock falcon diff (3.08 or 3.23) than the kph say 2nd gear.
Old 26-02-2005, 01:43 PM   #195
dansedgli
dansedgli's Avatar
Ive got 3.45's.
I thought 3rd gear went to about 190km/hr?
Old 26-02-2005, 01:52 PM   #196
Casper
Contributing Member
Casper's Avatar
Nah, 3'rd wont go to 190 with 3.45's. Maybe 170, 180 tops. I've never ran third right out and looked at its shift point. At that sort of speed I'd be keeping my eyes on the road.
Old 26-02-2005, 04:18 PM   #197
dansedgli
dansedgli's Avatar
Meh I dont know whats up with it. The 4th gear does wierd stuff when accelerating but that only happens after Im off the clock so I cant be sure what speed it starts to happen. In the northern territory of course.
Old 26-02-2005, 05:53 PM   #198
jonbays
TL40 Wagon?
Well I have tried to run third right out (on a private test track of course)
AND interestingly although I can hold 2nd to the rev limiter at 150k at 180k in third it changes into fourth and then stops at the speed limiter. Slightly more gracefully then the rev limiter at 150k in second.
Old 26-02-2005, 06:43 PM   #199
Casper
Contributing Member
Casper's Avatar
Well, this is mine. Run in 3rd gear and the lesser of the 2 runs (I asked for run 2, unfortunatly I forgot I had 3 runs because of the auto shift spiking the first run) so its 1rwkw less than what I had run but thats minor.
I think the main thing with it is the A/F ratio. An almost flat line across the page.
Old 26-02-2005, 07:26 PM   #200
buickman
buickman
buickman's Avatar
The only mods from factory are Pacemaker4499 extractors redback centre muffler 21/2 pipes with my old standed rear muffler fitted back as the noise of the hotdog resinator made to much noise and a BMC A/filter which I personally think are a wast of money a total cost of about $700. The car gives good highway performance but average of the mark.
buickman
Old 26-02-2005, 08:30 PM   #201
buickman
buickman
buickman's Avatar
weird stuff
I forgot to deactivate the Traction Control. It might of sensed a loss of traction on the Dyno?
buickman
Old 26-02-2005, 09:06 PM   #202
Mr. CVE
If it aint Blown it Sucks
Mr. CVE's Avatar
buickman
you will find the dyno opertare did deactivate it as the car wouldn't go 40 kph with it on on the dyno !
i know cause i forgot to turn it off on the BA once.
Australia's fastest 3V n/a Ghia 13.52 @ 102 mph
@235 rwkw !!
Now turbo 11.77 @114 mph
320 rwkw, 810 nm torque, 280rwkw @3000 rpm !! :thebirds:
Now for sale
http://www.fordforums.com.au/showthread.php?t=11296772
Thanks to Snort Performance, Headsex and CVE
Street car DeTomaso Pantera
Drag car 1995 Mustang, Haleys Comet ( It's back !)
Power by CVE
Melbourne's first SNIPER Tuner :
Now tuning E series
Mr. CVE is offline   Reply With Quote Multi-Quote with this Post
Old 27-02-2005, 10:51 AM   #203
buickman
buickman
buickman's Avatar
Then the answer might be in the ECU?
By the way Paul that V8 BA Ghia of yours really sounds the goods on the dyno. The new Gen of Ford V8 mtrs sound a lot louder in the rev dept than the windsors.
buickman
Old 27-02-2005, 12:09 PM   #204
Mr. CVE
Mr. CVE's Avatar
buickman
mine only sounds like that cause i have taken the single 2" system and made a twin 2 1/2 mandrel system for it !
@235 rwkw !!
Now for sale
Power by CVE
Now tuning E series
Old 23-03-2005, 03:41 PM   #205
brenx
brenx's Avatar
Of course they were ROFL.
74 XB Fairmont (street car) 11.07@123.02mph. 08 LV Ford Focus XR5 (daily).
Tuned by Hallam Performance
brenx is offline   Reply With Quote Multi-Quote with this Post
Old 23-03-2005, 07:21 PM   #206
Casper
Contributing Member
Casper's Avatar
Guys...were the cars sttrapped down for the dyno?
Yep, all strapped down tight.
Old 24-03-2005, 05:23 PM   #207
buickman
buickman
buickman's Avatar
At a car club meet earlier this month and showed a few of the guys there my dyno sheet. One of the guys thinks that by looking at the sheet the ecu has had the tranny shift up a gear at approx 160kmh as the dips in the readout look as if its changing between gears?
buickman
