05-07-2005, 06:07 PM | #1 | |||
No longer driving a Ford.
Just a quick question, what is the best way to paint plastic surfaces?
I want to colour code the taillight surrounds, number plate surround and the grill on the XF, but I'm not sure about the best way to paint them. Should I just get the correct paint, pull off the items to be painted, give them a good clean, allow them to dry and paint them, or should I apply some undercoat before painting? Thanks in advance.
05-07-2005, 06:10 PM | #2 | ||
Lucifer's Angel
I was told that the plastics require some kind of "elasticiser" be added to the paint, so as to avoid cracking and peeling. Primer and undercoat is always a good idea though.
SINISTER BA XR6 Blueprint, manual, 4490's, Redback 2.5" dual exhaust, BA Typhoon rims, tint, fog light covers, BF tailights, blue illuminated window switches, Ghia bootlid carpet, lower grille, FPV door spears, steering wheel & interior bits, XR6T + F6 intake, K&N filter, Typhoon spoiler, tuned, sway bars, custom angel eyes & plates..YUM!
If there's one thing guys in Holdens hate more than being beaten by a Ford... It's being beaten by a girl driving a Ford |
05-07-2005, 07:01 PM | #3 | ||
Troy if you use a product called bumper etch it will help the paint to stick to the plastic better. Just make sure the you clean it all with wax and greas remover. If you like i could do it for you for a small cost.
05-07-2005, 07:05 PM | #4 | ||
they call me Tibbo
It is called adhesive promoter, gives the plastics a nice surface to stick too.. It can also help with 'some' flex and heat distortion, similiar to the product Feathers described.. Goes on first, before primer and top coat.
05-07-2005, 07:22 PM | #5 | ||
Barra Turbo > V8
if ur only paintin wat u said just rub them back and prep them very good then paint them thats all i did on my XF if ur painting bumpers etc rub them back thn apply primer then rub back with wet and dry paper then apply collour the clear
2011 XR6 Turbo Ute - Manual - Lux Pack - Twin 2.5" Stainless Exhaust - Antz Turboside Intake - CCForged Phatlux wheels |
