08-02-2017, 07:41 AM | #1 | ||
Hi everyone!
Last week I bought a 2012 build Mc Mondeo wagon LX tdci. 84500kms. Really happy with it so far apart from the crappy Chinese tyres. Which will be changed soon. I have a question regarding the power steering reservoir. I have googled but can't find an answer. I can't find the damned power steering reservoir!!! It's not next to the coolant overflow bottle like the manual says and I've poked around with a torch to no avail. Next step is to put it on the hoist on the weekend. I'm probably missing something really simple but this had really got me stumped lol. |
08-02-2017, 09:20 AM | #2 | ||
My guess is it doesn't have one because it's electrically driven, don't know for sure though.
My 2011 has the fluid reservoir in the expected place. My best tyre so far: Michelin Primacy ST3, they seem to grip well and are quiet, road noise is a little high on these cars I'd say. Last edited by rondeo; 08-02-2017 at 09:25 AM. Reason: addition |
08-02-2017, 12:03 PM | #3 | ||
Thanks Rondeo, I was thinking maybe an electric system has been fitted. Vehicle is ex fleet.
Was thinking of fitting either those Michelins or pirelli P7s (which I had fitted to our old camry before we traded it) |
08-02-2017, 07:58 PM | #4 | ||
The reservoir isn't next to the coolant tank - it's on the RH side of the engine. All Mk 4 Mondeos had an electro hydraulic system as far as I'm aware.
Very happy with the Primacy 3. Just be aware that it's not exactly a sports tyre. Sent from my iPad using Tapatalk Pro
08-02-2017, 10:28 PM | #5 | ||
I will upload a picture tomorrow as the net is not behaving itself tonight.
09-02-2017, 07:02 AM | #6 | ||
Ok here's the engine bay.
Btw the current tyres are tracmax f1-06, not as bad as some reviews suggest, but what price do you put on your family's safety. Edit: Part of engine bay.... |
09-02-2017, 01:13 PM | #7 | ||
No wonder you couldn't find it ... Have a look here: http://www.talkford.com/community/to...r-where-is-it/
09-02-2017, 01:27 PM | #8 | ||
Oh ffs!!! I thought it might have been on the right hand side due to left hand-right hand conversion. You'd think they could have updated the damn manual
Cheers for that mate. |
09-02-2017, 03:11 PM | #9 | ||
Might pay to see if there is a fluid level warning for the power steering. Then you'll never need to check it!
Sent from somewhere using Tapatalk
19-02-2017, 07:05 PM | #10 | ||
Ok just thought I'd add this pic for reference. The drivers side head light assembly has been removed, fairly easy process. The min/max level on the reservoir is easily visible.
the fluid level was on the low mark so topped up with penrite LDAS fluid. |
19-02-2017, 08:59 PM | #11 | ||
Challenge Accepted!
dayum! under the headlight?!?
Oh glad mine is out in the open...
Undecided replacement... [SOLD] -2009 MB Mondeo Zetec TDCI- [SOLD] |
20-02-2017, 01:52 AM | #12 | ||
That's well buried. I hope it never needs to come out!
20-02-2017, 07:25 AM | #13 | ||
There is reasonable access via the wheel arch.
Off topic, but does anyone know if the transmission heat exchanger on these mondeos need replacing with an air/oil cooler like the falcons? |
20-02-2017, 02:52 PM | #14 | ||
Challenge Accepted!
no, not needed on the mondeos they've got their own water cooled cooler, but you could if you wanted to use a larger air cooler.
Undecided replacement... [SOLD] -2009 MB Mondeo Zetec TDCI- [SOLD] Last edited by cobrin; 20-02-2017 at 03:00 PM. |
20-02-2017, 04:19 PM | #15 | ||
Just to continue veering off topic:
Transmission has a temperature sensor. DTC code for over temp is P1783. Probably a warning but don't know. My transmission was around 75 degrees C last time I looked. Recently at outside temps of 43 deg C made no difference to the engine coolant temp (LX). As Cobrin says, the tranny is cooled by a separate heat exchanger using same coolant as engine. Make sure the fluid and filter is done regularly (60000km usually, I DIY at 45000km). I don't think temp is an issue, better to change the fluid. |
21-02-2017, 09:19 PM | #16 | ||
Thanks for your help, so no "milkshake" issues? The trans cooler looks similar to the one on the falcons that's why I ask.
Was planning on changing trans fluid every 45k. |
23-02-2017, 08:53 PM | #17 | ||
Not something I've heard of, but that's not saying much. My Mondeos have have been very reliable.
Before I had an ef falcon on gas, it was going well at 500000km + (two head gaskets) when I handed her in. I wanted more airbags. 1200km diesel Mondeo fill ups and handling is superb. Glad to be rid of spark plugs and coils, but electronics and wiring seem weak points . . . |
