06-10-2005, 11:11 PM | #1 | ||
hay fellas
what tource are e-series roller rockers set too, 40 - 50 or higher currently tourced to 40, think it was 50 is highest or sumthing and nything over 50 would strip the bolts was there difference between Gli and Tickford roller rockers? this is the tickford ED XR rollers and these off an EBII S anyone know? cheers |
06-10-2005, 11:18 PM | #2 | ||
In the Forced 'lane
Torque?
to bolt rocker assembly to the head is only 20 - 25nm you wouldn't want to go any higher than that
XE S-Pack 4 Runner XH11 Longreach |
07-10-2005, 06:45 AM | #3 | ||
Does Steve have a car?
lol i was thinkin what the hell torce meant :P Personally i have never bothered using a torque wrench and have always done them up till I felt it's tight enough...
AKA Mr Silver Chasing reliability....: "When Chuck Norris jumps into water, he does not get wet, the water gets Chuck Norris..."
07-10-2005, 08:36 AM | #4 | ||
seem's like most ppl are on that track
i torque internale engine bolts like head bolts, botom end bolt others i tighten to tight |
07-10-2005, 11:50 AM | #5 | ||
HA SPELLING JOE YA DUMBAZZ
07-10-2005, 11:54 AM | #6 | |||
seems everyone just tightens up here till tight : i gues it shouldnt make much of a difference unless its really been "torqued" (lol) in like over 50 or something |
07-10-2005, 12:47 PM | #7 | ||
Make sure to retighten the lot until their well and truly tight. Once you tighten the last ones the first will be lose again...
07-10-2005, 12:51 PM | #8 | ||
Last warning
you don't wanna do em too tight coz you'll strip the thread and/or crack the pedastools.
but as rmyers said, just do em all up with the ratchet first as they'll keep going loose until they're all down nicely. then torque them up appropriately.
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer |
07-10-2005, 01:26 PM | #9 | ||
PM me if you want
ALL e-series rockers are 2:1 ratio (even tickford).
07-10-2005, 01:30 PM | #10 | ||
i read the manual, it says touque to 50
they all seem to be sittin down fine, no huge or small gaps, everythings even i guess if its all done there shouldnt be a problem to much but like john said might strip the thread, but they wernt tight as in never-move-again tight but just till that indication that its tight enought on the bolts |
07-10-2005, 04:53 PM | #11 | ||
Hey Joe, tourqe it up to 25 nm, start from the middle and work your way out. also how come you used your EB rockers and not the ones that came with it?
07-10-2005, 08:08 PM | #12 | |||
07-10-2005, 08:12 PM | #13 | ||
Last warning
they're actually later model rockers.
ED's and EF/EL's had them. just the smaller hole. the lifters are hard to get out, but they do come out.
07-10-2005, 08:25 PM | #14 | |||
all i know is the ones i pulled out wernt ment to be in there there shouldnt be a differenance between the EBII rollers i have in there? |
07-10-2005, 10:33 PM | #15 | ||
OzECruisers Treasurer
old there a difference
07-10-2005, 11:34 PM | #16 | |||
Either ones will work, but EF/EL ones tend to be quieter. |
07-10-2005, 11:40 PM | #17 | ||
so do u loose powere or not?
08-10-2005, 12:57 PM | #18 | ||
you wont lose power but if you don't want the rockers that came with it ill grab em back they were very quiet....
