Old 12-01-2021, 11:48 AM   #1
pv5150
Default AU3 weird instrument cluster behaviour
Hello brains trust
Long time lurker, first time poster ��
Recently had my coil pack turn up its toes and die. My dash cluster had weird characters showing up on the digital display. Have replaced with brand new coil pack and digital display works properly again. However, my temperature gauge and RPM display are now exhibiting weird behaviour. The temperature gauge needle starts as normal and then very quickly goes all the way around beyond hot (it's not overheating), and the RPM needle heads all the way around beyond the readout and touches the raised part of the cluster.
I have tried a known good dash with significantly higher km's and both the temperature, and RPM's work as normal (RPM's are probably a tad low at idle but that may just be the older dash cluster). Penny for your thoughts...
https://www.dropbox.com/s/tnbm31p7ry...94843.mp4?dl=0
Can I reset the dash? Or can I send it away to get fixed?
TIA
Matthew
pv5150 is offline   Reply With Quote Multi-Quote with this Post
Old 25-01-2021, 08:42 PM   #2
FGX008
FGX008's Avatar
Default Re: AU3 weird instrument cluster behaviour
Originally Posted by pv5150 View Post
Hello brains trust
TIA
Matthew
Hi Matthew
Did you get this issue resolved?
Cheers, Brent
FGX XR8 Sprint Auto Sedan - Colour "Kinetic Blue" Build Number 410 (7 June 2016 build date).
FGX XR6 Auto Ute - Colour "Kinetic Blue" (9 November 2015 build date).
FGX008 is offline   Reply With Quote Multi-Quote with this Post
Old 25-01-2021, 09:33 PM   #3
pv5150
Originally Posted by FGX008 View Post
Hi Matthew
Cheers, Brent
Hi Brent. Thank you for taking the time to reply. No, the issue still exists and I'm wondering if it may be the result of electrical noise/ interference. Unsure where to go from here
Old 25-01-2021, 10:43 PM   #4
FGX008
FGX008's Avatar
Hi Matthew
Have you thought about getting your car battery load tested or if that is okay getting the regulator in the alternator tested. I cant think of anything else other than to suggest you probably will need to see an auto electrician. Lets us know how you go.
Cheers, Brent
Old 25-01-2021, 10:49 PM   #5
PG2
#neuteredlyfe
PG2's Avatar
Did you reconnect the thingy (I can't for the life of me think of the name of it as I type this) back on the side of the coil when you put the new coil back on?
From memory, it should connect up under the rear bolt that holds the coil on.
PG2 is online now   Reply With Quote Multi-Quote with this Post
Old 25-01-2021, 11:37 PM   #6
pv5150
Hi Matthew
Cheers, Brent
Hi again Brent. I've booked the car into the auto electricians on Wednesday to see what they can come up with. Hadn't thought about load testing the battery as it's only 3 months old, but it may have an issue. The regulator on the back of the alternator had slipped my mind. I'll get the auto electrician to check that on Wednesday.. Thanks for the input, I'll keep you posted 🙂
Old 25-01-2021, 11:42 PM   #7
pv5150
Hi PG2. Yes I did reconnect the thingy (is it the noise suppressor) back when installing the coil pack. Just saying.... Whoever decided that it was a good place to stick a coil pack, is a moron. You need to be half contortionist to install it.
