Old 21-05-2012, 04:12 PM   #1
spliceMk1
spliceMk1's Avatar
Default Pinto; Mechanical fuel pump.
Backyard mechanic problem #2.
I am trying to re-install my mechanical fuel pump from the Pinto 2 litre but it seems like a part is missing as it just will not pump. Is there a secondary pushrod that is needed apart from the spring-rod attached to the fuel pump itself? I ask this because when bolting the pump on, there is just no way that the sprung rod can reach the auxillary shaft lobe that is supposed to push it.
Have I lost a small pushrod extension piece or something? . I definitely have plenty of fuel available and the pump is in good working order.
Any suggestions would be much appreciated as I am about to go and spend another $100.00 on an electric fuel pump just from the frustration of trying a million times with no result.
Thank you Ladies and Gents.
I love my Escort.
spliceMk1 is offline   Reply With Quote Multi-Quote with this Post
Old 22-05-2012, 07:04 PM   #2
JimStone
Default Re: Pinto; Mechanical fuel pump.
Yes, you are missing a pushrod that sleeves into the block and runs of a lobe on the auxilary shaft
JimStone is offline   Reply With Quote Multi-Quote with this Post
Old 23-05-2012, 11:29 AM   #3
spliceMk1
spliceMk1's Avatar
Thanking you very much Jim, what a relief. I thought I was going mad. So obviously when I stripped the motor down the rod must have fallen to the side and I have completely missed it when cleaning up.
Time to chase one of these down!
I love my Escort.
Old 06-11-2012, 05:05 PM   #4
spliceMk1
spliceMk1's Avatar
So I went to strip down my old Pinto the other day. I had it sitting on a dollie with a section of rug underneath to catch any oil. Guess what was folded up inside a crease in the rug?
Yes, the original pushrod
I love my Escort.
Old 06-11-2012, 09:02 PM   #5
JimStone
Been there, done that - that's pretty much how I found about about the little beastie when I did the first rebuild of the RS engine few decades ago....
