Old 02-08-2005, 03:08 PM   #1
b2tf
not here much anymore
b2tf's Avatar
Default What's the point of.........
The Resonator Box for the Focus Airbox? I'm talking about the tall plastic box directly next to the airbox, has a very small intake from the box and from what I can see it serves absolutely no purpose.
Anyone know why its there?
RAM 1500
Old 02-08-2005, 03:41 PM   #2
melbzetec
Old enough to know better
melbzetec's Avatar
I remember reading somewhere that it is designed to lower the intake sound of the system. ie. if it was just the airbox, it would be louder. But I'm no acoustic engineer so can't explain it any further.
Old 02-08-2005, 03:55 PM   #3
Racecraft
they call me Tibbo
Racecraft's Avatar
Here is a blurb i kept in my bookmarks when I wondered why the E0series V8's had the donut tube on the air intake
"Resonant RPM: The airbox and inlet tube will resonate at a certain RPM. This will allow it to pass air better at this RPM and increase power there. In an airbox system the airbox itself acts as an air spring. The mass of air in the inlet pipes act on this air spring. The system resonates and passes air easier when the inlet pulses are timed just right (similar to pushing somebody on a swing. It is easy if you time the pushes just right).
Resonant RPM =19,100 *square root ((116.5 *Inlet Cross-Sectional Area))/(Air Box Volume)(Inlet Pipe Length) this is for a 4 cylinder 4 cycle engine."
If you are mad keen on understanding the science go here
http://motorcycleinfo.calsci.com/Airboxes.html
Racecraft is offline   Reply With Quote Multi-Quote with this Post
Old 03-08-2005, 02:17 PM   #4
zetec
Zoom Zoom
zetec's Avatar
Nice. Simple but effective. The only thing is if you change you filter to a High-flow does that affect this "spring" rate at all?
2012 Mazda3 MPS
Old 03-08-2005, 06:04 PM   #5
b2tf
b2tf's Avatar
Hmm well I took it off at the dealers today for the drive home - cold day so plenty of cold air around but as i expected it didnt make any noticable difference.
Im thinking it might be a good spot to get more air into the box - the standard intake really has me puzzled as to how it gets any air at all into there. Its a tiny entry into the box from the side but I might try making the entry bigger, putting a flexible pipe in there and running it to well, somewhere, to get more cold air. I know it probably wouldnt do much but I'll probably give it a go anyway.
RAM 1500
Old 04-08-2005, 01:38 AM   #6
Resty
Amon of Focus
Resty's Avatar
Mines out, soudns louder. No gains, just there to muffle sound.
Resty is offline   Reply With Quote Multi-Quote with this Post
