Old 09-10-2012, 08:36 PM   #1
tim_pato
tim_pato's Avatar
Default s1 three pin into s2 2 pin
plug in three pin plug join the 2 yellow/white wires together and then join 2 yellow wire on harness, then grey wire goes to yellow/red wire on harness. yay or ney?
tim_pato is offline   Reply With Quote Multi-Quote with this Post
Old 09-10-2012, 08:58 PM   #2
FGII-XR6
FGII-XR6's Avatar
Default Re: s1 three pin into s2 2 pin
sorry you're not giving enough info here to give an answer what is the wiring for?
[SIGPIC][/SIGPIC]
Rides:
Old 09-10-2012, 09:05 PM   #3
tim_pato
tim_pato's Avatar
sorry, altenator. I have a s2 ute with a 2pin altenator and the altenator light has been come on and off at random until today when it came on and stayed on. I have an s1 three pin altenator in the shed.
Old 09-10-2012, 09:14 PM   #4
bartsau
bartsau's Avatar
Came across this issue recently when converting my 6 to an 8. The 3 pin plugs only actually use 2 wires and they are the same colours as the 2 pin plugs! To use a 3 pin alternator you will need to simply change the connector on your main loom on the car side.
AU III Forte wagon - V8, 5spd man, lowered, 18" Honeycombs, Stock diff rebuilt with TruTrac LSD, Leather Ghia interior/dash, custom twin 2.5" into single 3" exhaust.
Wagon Build
AU I Forte Sedan - No longer
Toy Car Build
bartsau is offline   Reply With Quote Multi-Quote with this Post
Old 09-10-2012, 09:17 PM   #5
FGII-XR6
FGII-XR6's Avatar
ford actually do an adaptor for this
[SIGPIC][/SIGPIC]
Rides:
Old 09-10-2012, 09:17 PM   #6
tim_pato
tim_pato's Avatar
thanks bartsau, i just wanted to double check before i went ahead.
Old 09-10-2012, 09:21 PM   #7
tim_pato
tim_pato's Avatar
thanks for the tip, unfortunatly im to tight to pay through the teeth for a part at ford that can be done with a pair of crimpers and 2 joiners
Old 09-10-2012, 10:04 PM   #8
tim_pato
tim_pato's Avatar
perhaps 1 for the useful au threads?
Old 12-10-2012, 11:57 AM   #9
FGII-XR6
FGII-XR6's Avatar
as far as I know they are quite cheap
[SIGPIC][/SIGPIC]
Rides:
