29-12-2014, 09:44 AM | #1 | ||
Hello guys,
My son's away in training and has left his XR8 with me to care for. I've had it sitting for almost 5 weeks, tried starting it up but went...click click click click. Seems like the battery is flat. I'm not to familiar with V8. Should I simply jump it up? Should I remove battery and get it charged for few hours? |
29-12-2014, 12:59 PM | #2 | ||
It needs to be charged, I use a trickle charger permanently connected so I don't have this occur as I use it infrequently at times. These cars are sensitive to low voltage so once you charge it try and un it once a week. Good luck.
GT450 |
29-12-2014, 04:23 PM | #3 | ||
Thanks for your advice GT450...got the battery on charge since morning and will put it back on bout 4ish...it's looking good.
30-12-2014, 09:50 AM | #4 | ||
Oh I should have mentioned , never ever leave the keys in the ignition, even when off, as it's a sure way of flattening the battery to a level where you will need a jump battery to even get it to take a charge.
I forgot to remove them at one time and flattened a nearly new battery, hence why i now leave the trickle charger permanently connected. GT450 |
30-12-2014, 03:48 PM | #5 | |||
DJR Fan
30-12-2014, 04:05 PM | #6 | ||
If you don't remove the key completely it will keep some of the modules alive which I can assure will drain your battery if you do not use it for some time. the key needs to be removed to shut down entirely.
GT450 |
01-01-2015, 04:23 PM | #7 | ||
Thanks...had the battery on charge for approx. 8 hours (was a new battery that when flat) and it's back on all systems working ok.
