20-07-2010, 08:22 AM | #1 | ||
Can anyone help with:
the temp gauge shows hot when initial startup from cold. temp does not reset to normal. Any help appreciated. |
20-07-2010, 09:04 AM | #2 | ||
Formally kotevski22
Remove whirring plug at sender to see if that will drop the gauge.
20-07-2010, 09:40 AM | #3 | ||
sender is at the back of the head, you can see it from the drivers side
