Go Back   Australian Ford Forums > Ford Australia Vehicles > Small and Mid Sized Cars > Cougar and Probe
Old 22-09-2011, 02:13 PM   #1
baz
Default Diagnostic scan tool
Does anyone know if its possible for a diagnostic scan tool to show, NO CODES,even though your car seems to have a problem with the TPS or vacume, I have a CAN OBD11 MEMOSCAN.diagnostic tool. see rpms getting stuck
baz is offline   Reply With Quote Multi-Quote with this Post
Old 22-09-2011, 02:20 PM   #2
Russ
Russ's Avatar
Contributor: For members who make a contribution worthy of recognition. - Issue reason: Very helpful and gracious with photoshop work to help others..
Default Re: Diagnostic scan tool
I don't think that would be unusual as vacuum leaks are more of a air / mechanical problem and will probably not show an error code, much like some fuel related issues won't show either. Unfortunately it may be a case of trial and error and searching for leaks that way, first thing I'd be doing is looking for hoses that may have come off or been left off when servicing :(
Russ is offline   Reply With Quote Multi-Quote with this Post
Old 22-09-2011, 02:31 PM   #3
ratter
ratter's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Shares his in-depth tuning knowledge with the forum, very helpful. Contributor: For members who make a contribution worthy of recognition. - Issue reason: For his indepth tutorial on adding borders to photographs
Many of the cheaper scan tools only check generic OBD2 codes, they do not check manufacturers codes, it is possible there are faults in the system that your scanner may not be reading, but it is also possible that a sensor can not be operating correctly and not give a code
Pit Lane Performance
20 Rosella St Frankston 03 9783 8122
Authorised Streetfighter, Pcmtec , SCT & HP Tuners Tuning Agent,
ratter is offline   Reply With Quote Multi-Quote with this Post
Old 24-09-2011, 12:39 AM   #4
REDDYZ
REDDYZ's Avatar
Cougars have OBD-II interface. However, it depends on the scan tool you are using. Unless that tool is specifically made for that make and model its really a tricky job to get codes out of cougar. I have used Snap-on and Launch tools. There are about 5 to 6 different options to get into the system. I mean by selecting Oz Ford, or Euro Ford, or Mercury or Mazda. Tricky part was most of them gives you simplified options with no codes and I remember only 1 or 2 gives you lot of diagnostic options, display live data and comes up with codes.
There is another possibility that you can look into. Since you mentioned in other thread that rpms are going high when you engage clutch, there is a possibility that throttle body is getting stuck at times. Check the throttle cable and butterfly operation and see if there is any build up in throttle body. You might think how can rpm go high if throttle is stuck. With manual cars say for example if are cruising at 3000rpm and throttle is stuck. Now when you press clutch you are taking load off the engine which will automatically increase engine rpm at the same throttle position. Hope you got my point. Its worth checking the butterfly and throttle cable operation.
Ex Cougar - 00' MTX 2.5L (Limited edition Eibach Cougar); Dark Green Tourmaline; Lowered with Eibach tuned suspension from factory; SVT UIM, LIM & Throttle body; Supercat 2.5" dual exhaust with twin pipe quad outlets; Custom headers; Custom coloured instrument cluster; K&N Apollo CAI kit; Calibre oil catch can.
Now driving a Lexus RX 450h. Your guess is correct that I am a family man now.
REDDYZ is offline   Reply With Quote Multi-Quote with this Post
Old 24-09-2011, 08:56 AM   #5
baz
I did think about the throttle body because its only happened twice in about 12 months. I have got a PTS on its way from rockauto but might give the throttle body a clean. Any easy ways of doing the clean?
