Old 14-04-2022, 11:20 PM   #1
fordbossxr8
Default 2012 mc mondeo saying immo active
Hi, I have a 2012 mondeo that says immo active on the dash. For the life of me I can't find a fault. Can bus wires are 60 ohms. Can talk to everything. I do need to rescan again for dtcs. Even managed to borrow pcm bcm barrel/key pats reader from another car no different. I'm at the point it's something in the wiring somewhere. Has anyone seen or heard of anything that will stop it from cranking and come up with immo active?
fordbossxr8 is offline   Reply With Quote Multi-Quote with this Post
Old 15-04-2022, 08:11 AM   #2
whitelion65
whitelion65's Avatar
Default Re: 2012 mc mondeo saying immo active
Is “immo” the immobiliser?
Sorry, have no answer for you.
Steve
Current rides
2012 Mondeo Titanium wagon (TDCI)
Moondust silver
2016 Focus Trend, 1.5ecoboost, 6sp manual.
Frozen white
Previous
2004 Berlina Wagon (LS1) Vespers Blue
1995 Camry 2.2, white
1971 Ford Fairmont wagon 302w, C4 Polar white
1971 TC Cortina, 2L 4sp, Ermine white
whitelion65 is offline   Reply With Quote Multi-Quote with this Post
Old 15-04-2022, 09:00 AM   #3
rondeo
ABS faults? DTCs? Jump started? Previous low battery?
Old 16-04-2022, 06:46 PM   #4
fordbossxr8
Had another quick today. Turns out I have no coms with pcm or tcm. Have coms to abs module. Is there a pcm pinout available? Want to check the powers and grounds at the pcm and also the com wires back to the underhood fuse box. Seeming like I'm missing one
Old 16-04-2022, 07:20 PM   #5
rondeo
I have a 2010.5 pcm wiring diagram not able to upload it here due to size - 1.5 mB.
Check integrity of connectors on the GEM ? I have heard about washer fluid creeping up from the sensor...
FYI I'm a DIYer not an expert.
Old 17-04-2022, 10:39 AM   #6
russellw
Chairman & Administrator
russellw's Avatar
The MC Mondeo wiring schematics are available in our tech portal.
Observatio Facta Rotae
Old 17-04-2022, 06:19 PM   #7
fordbossxr8
Hi, yes thanks but there's no pcm connector pin outs in them diagrams went through them all. Yes I did hear about water in the gem and I have checked it is OK.
Old 17-04-2022, 06:21 PM   #8
fordbossxr8
Wanted to check all my powers and ground for the pcm.
Old 18-04-2022, 03:15 PM   #9
fordbossxr8
Turns out I can talk to the tcm and pcm. But can’t talk to rcm module. This is the codes I pulled out
U015100-lost coms with rcm
U042268- invalid data received from bcm
U041568-invalid data received from abs
B10a202- crash input
B10a215- crash input
U045262- invalid data received from rcm
U041800- invalid data received from brake system control module
Turn ignition on still comes up with immobiliser active
My question is. Is the rcm apart of the immobiliser system?
Old 18-04-2022, 04:52 PM   #10
fordbossxr8
Turns out I’m getting this dtc now
Anyone got a flow chat for this dtc
B10DA:51-2F pats target identifier
Old 14-05-2022, 08:27 PM   #11
T-Pak Addict
Jim
T-Pak Addict's Avatar
Have you tried disconnecting battery for a few mins and reconnecting.
Worked\on my daughters car (MC Diesel)
The Daily. White 2017 ZG Escape TDCI AWD Wagon
The Wifes. Grey 2015 MD Mondeo TCDI Hatch
The Old Daily.......2003 Octane BA Taxi Pak Egas Falcon Build Thread
T-Pak Addict is offline   Reply With Quote Multi-Quote with this Post
