Old 29-11-2014, 04:13 AM   #1
Default 93 Telstar AX 2 Litre Thermostat Location
Can someone help here http://www.fordforums.com.au/showthread.php?t=11428869
Old 01-12-2014, 07:18 PM   #2
dirty hands
Over Thinker
dirty hands's Avatar
Default Re: 93 Telstar AX 2 Litre Thermostat Location
looks like some one has ... within hours
post 3 thermostat 15 -171 on a 4 cyl mazda 626
post 4 ford motor end of the head
different thermostats fitted to both
My car goes Brumm Brumm
dirty hands is offline   Reply With Quote Multi-Quote with this Post
Old 07-12-2014, 06:22 PM   #3
graham7773
dirty hands, I have the ford motor and the thermostat appears to be in the same place as the mazda 2l. I have to say, this is the first time I have seen the thermostat positioned at the end of the bottom hose. More usually at the end of the top hose (there is definitely no thermostat at the end of the head. ) where heated coolant occurs first. Thanks again to all members who have contributed to this thread. Just on the housing at the end of the head, it is square with no way of fitting a thermostat. I have it off and can see no evidence of a thermostat ever having been there.
dirty hands, re your quote "what is Bathurst without Ford and Holden", what's wrong with a bunch of Volvo's and Audi's trundling around Panorama? Except no spectators.
graham7773 is offline   Reply With Quote Multi-Quote with this Post
Old 29-12-2014, 08:10 PM   #4
dirty hands
Over Thinker
bathurst ..yes lets see volvos roll over
I see where the confusion is ..got me confused
y to the bottom w to the top
as mazda engineers see it that location works - for an east west motor -
just not sure why , Mazda
15-270 pipe is the thermostat bypass
my thoughts
1#the whole water flow is stopped inside the block till the thermostat opens
2#if I read the exploded view correctly that thermostat spring is to the block-- behind the water pump
I forget this bit
3#water flow and direction theory in a closed pressurised system
hot to cool physics in a radiator
