A wise man once said it is easy to learn from your mistakes - but better if you learn from some one else's mistakes.
So share your repressed experiences so others can beifit from your "mis-steps". in my case it was a loud exhaust. For years i flew below the radar then i decided to basically put a 3" straight pipes (one resonator at the rear) on my fg xr6 ute (running 460rwkw). It sounded great to me - but even driving normally people would be thinking i was a hoon. Neighbours started to complain i was driving too fast (I wastnt), police always looked twice and less desirable types also started to notice my car as it sounded modified). So now i am going to quiet it back down and once again become the grey man in a nondescript white ute. |
Have Boost, will use it..
Yep, a cheap exhaust on my old XR8. I hoped it would sound good, but it didn't. And the more I tried to "fix" it, the worse it got. Should have stayed with stock.
Now in the G6ET, I like the quietness. Maybe I'm just getting old. |
2 users like this post: |
Experienced Member
Spending big money on engine modifications for more power only to discover it not much better than stock standard.
11 users like this post: |
Had a s teep driveway at our old place lowered my eb xr6 stupid low would scrape the crap out of everything underneath and make a heap of noise scraping also the exhaust would hit one of the watts link bars constantly as I had a 2.5 inch exhaust on it as well
Had an LC gtr with a 253 with a mild cam and 30thou bore and braided hoses and battery in the boot and 4 point roll cage rolling on stockies (deep dish rears) and it was flawless, not 1 ripple, wobble, dint or scratch, my brothers ex gf decided to mod it for me by taking it out (without permission) and parking it into an xf.. By far the worst mod on any of my cars
BLUE OVAL INC.
Chopped springs on an XF.
Angle Grinder Racing...FTW |
irregular member
Rang up to book my VY SS ute in for a full exhaust system and dyno tune, they said they could do it the next day, so I dropped it down and had everything done and had completely forgot that I had added octane booster to that tank of fuel.
Took me a few weeks to work out why it stopped running properly.......... |
Next up?
Umm, you're talking XR6 Turbo right.
If it ain't a Ford you're bored. Blue blooded to the core. ![]() |
Worst mod I did was modify the existence of my XE falcon. Man I miss that car. Trying to find a new one now is proving more difficult than I imagined.
Now- AMG W211 E55 Then - BFII F6 Coming - 84 XE S-pac |
worst mod was i put 350+cfm race heads and large solid cam on a standard from 1970 engine short motor and spin it to 7500rpm.. needless to say, busted rod, block, etc.
but damn it pushed me in the seat while it lasted.... my standard short motor racing no longer works on old school v8's like it did back in the 1990's, because all of the old school v8's are now too thrashed |
Gees i've done a quite a few stupid things when i was a youngster like:
Cut the exhaust of the cl chrysler 265 to try make it sound a bit better. Connecting the output of the air-conditioning compressor to the intake thinking it would give me psi this was on a xd. lol. Putting a 2litre izusu engine and gemini 5 spead in a suzuki sierra, had issues with cooling as i could only fit a thermo-fan in it but that sucked and modified bonnet latch that would fail every now again, modified sump would smack front diff if going over big bump, rear driveshaft was only 170mm long. Though i used to do near on around 700km's to and from work a week in it. |
3 users like this post: |
#12 | ||
Add my name to list of exhaust regrets...
I had extractors and a custom twin 2 inch system put on my XB and I lost a heap of torque and the sound above idle is an embarrassing loose, loud noise.
1976 XB Falcon 500 Wagon - BUILD THREAD Sherwood Green | 3spd/250CI | Running Whitewalls on a 2.5" Drop |
I cut a hole in a sealed subwoofer enclosure I had in my first car, thinking "ports add more bass"...suffice to say it sounded terrible afterwards.
Oh and on the same car (1996 Ford Mondeo), the original owner had fitted hideous 15" 3-spoke rims and some sort of CAT-back exhaust...but anyway, when I had new rotors or pads or something fitted the brakes were rubbing on the spokes so the guys fitted wheel spacers...it got to the point that if I felt the steering wheel vibrate I needed to pull over and tighten the wheel nuts... |
#14 | ||
#15 | ||
Pity the fool
Sometimes I regret fitting an LPG system to my BA, not because I am against LPG (obviously I'm not) but because I was talked into fitting a below-average system by a mob who werent really good at it. The car has never been the same since.
Fords I own or have owned: 1970 XW Falcon GT replica ![]() Proud to buy Australian and support Ford Australia through thick and thin |
#16 | ||
Fiat POWAAH!
I bought a jeep.
Holden: If you cant beat them, buy them. |
28 users like this post: | Blue Roo, Dauphin, deesun, Franco Cozzo, frankie86, irish2, jimt3te50, JK47, KurtisEBear, M&Ms, Mechan1k, meteoriTE, MNM96, Mr Brooksy, MrMaestro, n0name, n0ngie, Paull, PridenJoy, Rastas, Sam_Boss260, sd1800, sleek7, Storme93, Thunderchild, Trek, tut0r, XD 351 Ute |
#17 | ||
I've had a few, thankfully nothing expensive:
-checker plate rear parcel shelf, acted like an oven in summer. -turbo whistle, clips on exhaust, just makes it sound like a VW bettle -neons in the car, flashed to the sub mounted in the checker plate parcel shelf ![]() |
#18 | ||
Interior neon lighting system in my old Familia
1987 Fairmont Ghia - Sahara Gold |
#20 | |||
Boss 335
#21 | ||
Parts bin special
My blue checkerplate floormats... I don't miss one bit!
For me, I loved the loud exhaust on my EA. With the manual, extractors, cam etc. it sounds alright for a 6... but now everytime I drive it, I just wait to be pulled over or receive a nice letter from the EPA. I'm also now in the "must quieten it down" boat.
Weekender 1964 US Falcon Futura convertible - Rangoon Red 260 Windsor V8, 4 speed manual, LHD, Electronic ignition, Mustang wheels https://fordforums.com.au/showthread.php?t=11470868 Daily 2014 SZII Territory diesel - basic runabout Previous Cars 1990 EAII Fairmont Ghia - Tickford engine, 5 speed, SVO wheels, bodykit, much more 2000 AUII Fairmont - XR wheels, Ghia interior 2010 FG XR50T ute - XR8 bonnet, Streetfighter intake |
#22 | ||
When I was in my late teens a long time ago I fitted an A9X bonnet scoop to my TD Cortina . I thought it looked scmick at the time but then came to my senses and bought a new v8 XD .
#23 | ||
Where to next??
I decided to add a 'kill switch' to my 180B....
Not knowing anything about car electrics I just stripped one of the wires out of a piece of 3 core house wire and extended one of the cables running to the starter. Looped it through the firewall and into a nook between the transmission tunnel and the centre console. Didn't work the first time. Switch got real hot. Oh, the switch was a regular house light switch, just popped out of the plastic housing. Hmm I think I went through a few hours of trial and error - mostly error. Ended up going to Jaycar and buying a much heavier gauge wire. Worked a treat.
#24 | ||
(1983) First car I had - XC GXL 302 auto. Didn't like the auto so teamed up with a mate and swapped the 351 manual from his XB van into the XC and the 302 went into the van (his missus couldn't drive a manual)
One day I blew the snotter out of the single rail and got a top loader fitted - no probs there but only found out when I sold the car (a very irate buyer of said car rang) and wanted to know who had smashed up the transmission tunnel?? The top loader had come with a hurst shifter, so, to make the linkages fit, whoever did the job smashed the floor up and once it all worked, hid it all by refitting the carpet and modifying the console to fit around the shifter. Hand on heart, I had to tell him that it was done before I left Melbourne to return to Adelaide - poor bloke had no come back at all!!
476 EF XR6 Wagons - 198 were Manual 2010 Anniversary XR50 in Sunburst - 6spd Manual My Gallery Photos Here |
#25 | ||
Jacked up the *** end of my M111 Zephyr and painted the diff yellow
2016 SS-V Redline LS3 Previous Rides. BA XR8, 5M FG GT-P 315 6A FG F6 310 6A HSV Maloo LS3 6M GT 335 6A 300 SRT8 Hemi 6.4 PX Ranger XLT Commodore SS-V Redline LS3 2017 Triumph Speed Triple R Triumph Street Triple RX |
#26 | ||
I thought my mk111 Zepher would look cool as a convertible, didnt know anything about cross bracing etc so one day out came angle grinder and viola =convertible few days later it started falling apart.
'68 Mini Cooper S removed exhaust pipe from 2" below the head......hells bells it got noisy and fumes thats another story............
Dont p i s s off older people. At our age the term Life in Prison is not a deterrent |
#27 | ||
![]() Join Date: Dec 2010
I bought a I6 barra and started modding it......That or buying my ute that came with a 3inch pipe, hollowed out cat and one straight through muffler.....Drone city.....Now I replaced it with a 400cell cat to stop the BF code and triflow muffler....Quieter but she stinks to high heaven when I give it the beans then come to a stop shortly after....sullllpphhaaaarrrr
Ride 2007 Ripcurl BF Xr6 Ute Mods to Date Ceramic Coated Pacemaker 4495s 2.5" Dual Venom exhaust, Bluepower CAI Eaton True Trac with 3.9s 20% Underdrive EcoLpi Motor RWKW: 200.0 Nm: 394 Mods to Follow Supercharger |
#28 | ||
Cutting the dash on a pristine XP Futura to fit a Eurovox stereo
I also hacked up the parcel shell for some 6X9's and stuffed the front doors for some 6" speakers It was the early 90's sorry :( I also Hacked the dash on my XC GS to fit in a Pioneer head unit :(
Pariahs C.C. What could possibly go wrong I post images with postimg.cc (so I don’t forget) |
#29 | ||
Critical Thinker
added stickers and chev badge to a commodore expecting power increase..... :P
![]() But in all seriousness, worst mod was cutting springs to lower a vehicle. I did this to one of the first cars I owned. XE Spak. Because I couldn't afford new springs. Gave it that fully sick look. But rode like poo....
#30 | ||
fitting fuax suede to my door panels with cheap spray glue...I have done it twice now because i'm a tightarse and didn't want to buy 3M glue.
now i'm going out to buy 3M glue to do it right. also wanting more sound from an AU XR8 so fitted hotdogs and no balance pipe against the exhaust guys recommendations, went back the week after for a balance pipe, went in the week after that for new mufflers.
CURRENT RIDES BA GT Mk1 #0009 - Narooma Blue SY Ghia AWD Black VZ LX8 Adventra Holden HX 50th Anniversary AU Saloon Car racecar 1980 GS1000ST - Wes Cooley Rep
