Old 19-01-2021, 10:42 PM   #1
Default Top 10 Experimental Australian engines / abandoned programs
Found this interesting article, most of which are probably known to many here.
Top 10 Experimental Australian engines / abandoned programs.
https://performancedrive.com.au/top-...98W-6puQfnUBok
PX MK II Ranger
FG XR6
FG X XR8
Mustang GT
7 users like this post:
Old 19-01-2021, 10:47 PM   #2
Franco Cozzo
Franco Cozzo's Avatar
Default Re: Top 10 Experimental Australian engines / abandoned programs
Ford 3.7L Cyclone V6 is in early model Mazda CX9 I believe.
204KW/6250rpm 367NM/4250rpm - Ninety percent of torque from 2800rpm (330NM).
How does that compare to FG Barra?
Power: 195 kW (261 hp) @ 6000 rpm
Torque: 391 N⋅m (288 lb⋅ft) @ 3250 rpm
So basically Ford 3.7L Cyclone V6 is much more technologically advanced, but it sucks because it puts out less torque at 1000 RPM later than our home grown dinosaur
Old 19-01-2021, 11:31 PM   #3
b0son
Engines built elsewhere in the world might be more interesting too if they hadnt been hamstrung by fuel economy, NVH and emissions. What would the 4.0 be like if it had been developed by BMW for the european market....
b0son is offline   Reply With Quote Multi-Quote with this Post
Old 20-01-2021, 02:29 AM   #4
oldel
Have you heard of the BMW s38? The S38B38 (3.8L) was 250 kW (335 hp) at 6,900 rpm and torque was 400 N⋅m (295 lb⋅ft) at 4,750 rpm.*
That was back in 1991, so before variable valve timing etc. I'll give ford one thing, at least they didn't put vanos on the barra. What ford have with their VCT, barra etc is a lot more reliable than what BMW have done since with regards to vanos, fuel and timing chains/guides.
*But they build them for top end power, not torque, they usually run twin pipes (inc twin cats and twin resonators) all the way to the rear muffler. E: 1,2,3 on one pipe, 4,5,6 on the other.
e: Anyway, BMW dropped the large i6 and went back to v8s after and it wasn't just for euro reasons, the new king was the s62 4.9L v8 with 294 kW (394 hp) at 6600 rpm and 500 N⋅m
oldel is offline   Reply With Quote Multi-Quote with this Post
Old 20-01-2021, 07:13 AM   #5
Franco Cozzo
I think if I was going to buy another BMW I'd like either an E32 750iL or E34 M5
https://www.whichcar.com.au/features...30-years-later
E34 M5 has the S38 3.8L 250KW I6
Old 20-01-2021, 09:00 AM   #6
Dr Terry
Isn't Vanos just VCT by another name.
Dr Terry
Dr Terry is offline   Reply With Quote Multi-Quote with this Post
Old 20-01-2021, 09:10 AM   #7
Franco Cozzo
Dr Terry
VANOS/VTEC/VVTI/VCT are all variable valve timing with different names and various methods of implementation is all
Old 20-01-2021, 01:13 PM   #8
Vesper Martini
Vesper Martini's Avatar
Torque performance of the cyclone would have been better if it were a 4.0 like the big bad Barra.
this was in 2008 which is when they should have introduced the diesel to the Falcon and territory for those after Torque and better economy. Instead it made its way 3 years later in only territory. some were calling it an old engine already.
______________________________
2015 Territory Titanium RWD Diesel - SOLD
2016 BMW X5 xdrive 30D Msport
Seadoo Challenger 210SE 310HP
Vesper Martini is offline   Reply With Quote Multi-Quote with this Post
Old 20-01-2021, 01:19 PM   #9
Vesper Martini
BMW have a pretty good 3.0 diesel IL6 for those after Torque which it has loads of, and doesn't sound like a Massy Ferguson.
as you say the Petrol I6s are built for top end power, not torque.
Old 20-01-2021, 01:57 PM   #10
Peuty
Afterburner + skids =
Peuty's Avatar
Disappointing the prototype BA V10 GTHO test program wasn't included in this list
If you know, you know....
Oo\===/oO
Old 20-01-2021, 02:03 PM   #11
Franco Cozzo
Wasn't the work for diesel Territory mostly done then Tom Gorman canned it? The reason the old clunker was revived later was continuing the work done previously?
How fitting - he's now the CEO of Sims Metal
https://www.simsmm.com/leadership/tom-gorman/
He knows how to destroy things
So many expensive qualifications but couldn't tell **** from clay.
Old 20-01-2021, 02:15 PM   #12
Dingo
Ford T3 Partsologist
Dingo's Avatar
The Sarich Orbital engine, did Ford put this engine in a WB Festiva at one stage for testing I recall there may have been 30 prototypes.........
2002 Blueprint T3 TE50 Manual Koni Suspension # 161
T-Series Club of Australia - www.tseriesclub.org
Dingo is offline   Reply With Quote Multi-Quote with this Post
Old 20-01-2021, 02:15 PM   #13
whynot
whynot's Avatar
A diesel Barra would have been very interesting. Taxi drivers would have fallen over themselves to buy one. So too would have government departments in the period 2000 to 2015.
With 650Nm of torque it would have been a great tow vehicle in either the Falcon or the Territory.
Alas, not to be. Too busy focusing limited development dollars on squeezing a turbo into the Territory. Oh well, 20-20 hindsight is a wonderful thing.
whynot is online now   Reply With Quote Multi-Quote with this Post
Old 20-01-2021, 02:30 PM   #14
Vesper Martini
650Nm.. dangerous cab driver drags.
diffs in bits
Old 20-01-2021, 04:20 PM   #15
Bossxr8
Peter Car
Bossxr8's Avatar
The Barra still had plenty of life left in it. The DI engines could pass Euro 5 and 6. Actually I think they could pass Euro 5 with port injection as well. Just needed development to get them to be able to pass the tests over the 160,000km service life the tests require the emissions to pass for. Which involves a lot of work with oils, and certain additives like zinc they put in them. Zinc is good for part protection, but bad for cat convertors. So it was all a balancing act.
There was also the time they tried machining alloy barra blocks in the engine plant. The soft alloy wasn't good for the tooling. Clogged it up. Would have needed a lot of tooling changes for it to work. Can't use tooling for hard cast iron to machine aluminium.
There was also the prototype LPI Turbo ute that went like sheet off a shovel. Never got off the ground though. Just wouldn't have been enough demand for it.
Old 20-01-2021, 04:30 PM   #16
oldel
Dr Terry
They're not the same parts every manufacturer bolts on. There's different ways of doing it and only BMWs vanos has a reputation for death rattle when the thrust washer (or the surface it sits against) wears out.
Old 20-01-2021, 06:56 PM   #17
Just to add to your post, the Barra on premium would top the Cyclone V6 on power and smash it for torque.
https://www.fordforums.com.au/vbport...?articleid=432
"Additional performance and efficiency benefits can be obtained from using a higher octane, 95 RON unleaded fuel, liberating even more power and torque from the I6 engine, with peak power and torque outputs rising to 198 kW and 409 Nm respectively.
Courtesy of the engine's dual knock sensors and individual spark control, customers can obtain even further performance benefits from using 98 RON premium unleaded fuel."
I remember at the time a Ford engineer was quoted in the media stating that on 98 RON, power would be over 200 kW.
PX MK II Ranger
FG XR6
FG X XR8
Mustang GT
Old 20-01-2021, 07:09 PM   #18
Mechan1k
Mechan1k's Avatar
Guzzled petrol worse than the Barra as well.
Old 20-01-2021, 07:11 PM   #19
One of my main motivations to buy a FG Falcon in 2008 was to make sure I got one with the Inline 6.
With the news of the Geelong engine plant to be closed, I did NOT want a Falcon with the imported V6. Now I'm sure there would have been incremental improvements afforded by vastly newer design, but a Falcon without a inline 6 wouldn't have been a Falcon. (I say that as the owner of a V8 Falcon but you know what I mean.)
Ford's news in November 2008 that the engine plant would remain open seemed like great news at the time. In my opinion, it was at this moment the fate of Ford's Australian factories was determined, we however found out about it in 2013.
https://www.fordforums.com.au/vbport...?articleid=938
All Hail the mighty BARRA!
PX MK II Ranger
FG XR6
FG X XR8
Mustang GT
Old 20-01-2021, 08:20 PM   #20
oldel
Yeah, even the dirty ones!
Old 20-01-2021, 08:30 PM   #21
ivorya
Mad Scientist!
ivorya's Avatar
I quite like the OHC Holden V8.
I remember reading about it. very hush hush, only a hand full of people knew about it, good aussie engineering to get it to work properly and blew everyone away with how well it ran!
A shame the bean counters ruin everything!!!
ivorya is offline   Reply With Quote Multi-Quote with this Post
Old 20-01-2021, 11:40 PM   #22
hayseed
A Diesel 186 & a Powerglide Auto would've ben the Drivetrain of Choice for every Taxi in the country throughout the '70s & '80s..
hayseed is offline   Reply With Quote Multi-Quote with this Post
Old 20-01-2021, 11:54 PM   #23
Franco Cozzo
LS1 was around the corner I guess
Old 20-01-2021, 11:57 PM   #24
Franco Cozzo
Zinc is an interesting one, no oils has high zinc content anymore except for a few specialist applications for oldskool cars.
A lot of VN-VS 5L with rounded hydraulic flat tappet cam lobes
Old 21-01-2021, 12:14 AM   #25
XR Martin
XR Martin's Avatar
There was a photo in Wheels of a prototype EF with a DOHC I6, I think they said Jaguar had a hand in developing it.
I'd love to know more about it.
2004 BA wagon RTV project.
Old 21-01-2021, 01:22 AM   #26
blue sleeper
blue sleeper's Avatar
Was that the 3 valve one they never made?
Had: ED Fairmont AU engine 5 speed exhaust extractors, 17" mags, miss the old girl....
Have: 1JZ Soarer dump pipe, exhaust, coilovers , 17" mags
blue sleeper is offline   Reply With Quote Multi-Quote with this Post
Old 21-01-2021, 08:45 AM   #27
Dr Terry
i realise that, I work on this stuff.
My point was that Vanos was just BMW's version of VCT, it did nothing different or better. It was just a crappy design.
Dr Terry
Old 21-01-2021, 03:23 PM   #28
xb74_black
The Leyland V6 prototype still exists, I know the bloke that owns it. He used to own a Force7 coupe as well. I know he sold the Force7, not sure about the v6. I dont believe its ever been fitted to a car since leaving Zetland.
It would have been very competitive if released, the old 2.6 straight 6 Leyland used was 50's technology.
xb74_black is offline   Reply With Quote Multi-Quote with this Post
Old 21-01-2021, 04:11 PM   #29
Bossxr8
Peter Car
Bossxr8's Avatar
That's why I use the Penrite oil with the extra zinc. Although my Windsor has a roller cam, but my cam designer recommended oil with extra zinc to protect the lobes.
This was developed for the EA. But they chose the SOHC over it due to cost reasons.
Old 21-01-2021, 07:51 PM   #30
ivorya
Mad Scientist!
ivorya's Avatar
https://drive.google.com/file/d/176z...-2C0-TZtM/view
