#211 | |||
Location: Under the bonnet, trying to keep as clean as above!
I was more thinking if there was a later model telstar that had a better fan setup and bigger output current alterator, that can be fitted to my 87 telstar. Also if anyone has or knows of someone with a 86/87 telstar that has cruise control, electric windows and the cluster that has the tacho on it, and they aren't using it or want to wreck it i really want these parts. I have been searching for them for a long time now and will pay well and have no problem paying postage, or if they are close(SE Queensland) removing the parts. thanks |
#212 | ||
Over Thinker
[QUOTE=shiftybugger]I recently bought an 85 AR Telstar (TX5, 2.0L, Manual) and I have a few questions:
1. Is it made for leaded fuel? but will run on unleaded with lead additive you may need to retard the timing a fraction 2 are the vaccume dashpots working on the carby ? all done and good - Plugs - all clean - Leads, distributor - all appear to be in good nick - Air filter - fairly clean, not far off new - Carby - only a cursory check, fuel level in the clear window is good,
My car goes Brumm Brumm |
#213 | ||
Over Thinker
the AR head gasket or valve regrind set
should be a 2 ltr motor not the 1.6 or 1.8 those motors may be in the lasers ![]()
#214 | ||
Over Thinker
you will find in the first two pages of this post
![]() data /specifications and tuning data for the 2 ltr engine
#215 | ||
Im new to this site... I have a Telstar TX5 ghia... it was built in december 87 but released in 88... I had to replace the gasket between the manifold and the block but it still sounds as tho it is leaking??? also the car idles at around 1500 - 2000rpm in park and nutural but when put into reverse it drops back to around 1000rpm, then tonight i took it for a run up and down the street and when i got back i put it in nutural and the revs built up to 200rmp then dropped back to 1000rpm then back to 2000rpm etc etc, it takes about 5 seconds to get from 1000 - 2000, does any one know wat could be wrong? it is a 2.2L injected automatic.
#216 | ||
Over Thinker
I dont have any info on EFI motors
could be a problem with the idle control motor or timing
#217 | ||
do you know how to pullout the power window motors? in the rear doors
#218 | ||
Over Thinker
nope I dont
#219 | ||
just wondering if you would have a pic of the layout of the underdash fuse box as my parker lights and instrument cluster are not working... i have found a blown fuse and replaced it but it blew again i want to make sure it is the parker light fuse... also would you have the scamatic diagram of the parkerlight setup so i can trace the wires if that is the case, cheers.
#220 | ||
Over Thinker
I only have the australian model 1987 wiring . carby only
and the wiring diagramms dont scan very well if your car is non australian the next year up with EFI is stuff I dont have
#221 | ||
no it is the australian model. i live in sydney.
#222 | ||
i really just need the layout of the fuse box so that i know what each fuse is for and what size fuse should be in there, i would imagine that the carby one would be similar to the EFI one
#223 | ||
any advice for removing front engine mount? i got the bottom 2 nuts off just cant get the nut off that goes through the centre of the rubber. ive pulled out the thermo fan to give me more room as i cannot get at the nut from underneath but there still isnt much room. any tricks that could help?
#224 | ||
Over Thinker
lost this post it really need a sticky
#225 | ||
I know you are talking about the earlier model but I am trying to get hold of the wiring diagrams etc for an AX tx5 1992 v6. The ones I have in the Haynes book are wrong. Any ideas?
Thanks |
#226 | ||
Over Thinker
havent seen one for sale
but you need the factory manual
#227 | ||
I have an AS (1985) telstar tx5 with AR (mazda FE) engine fitted. not knowing the full engine history, I'm changing the timing belt, but there appears (at least in the gates catalogue) to be two with the correct tooth shape ("square" / trapezoidal) and width (19mm) - 106 teeth (gates T077 dayco 94085) or 109 teeth (gates t088 dayco 94096, dayco kit KTBA146). the gates catalogue lists both, while the dayco guide doesn't list the 106 teeth as applying to this model, so erring towards the 109 teeth. but can anyone confirm the expected number of teeth? (preferably without counting!)
#228 | ||
Over Thinker
AR
you have to use the one suited for the engine you have in the car now
#229 | ||
My daughter as a 1959 Telstar. I have tried lifting the windscreen rubber and applying silicon sealer and leaving a bead of sealer on the outside of the rubber.
After a shower of rain the passenger seat is quite wet. I cannot see where the water is coming in Any Ideas regards klo7 |
#230 | ||
WOW a 1959 Telstar! Lol sorry its off topic but WOW!!!!
****el's drive Rotaries, Four in-line is a waste of time, Six in-a-row just won't go, If you really want something great, drive a great big Ford V8! God made Holden's to keep w*****'s out of Ford's, and yes I'd rather push my Ford than drive a Holden! |
#231 | ||
Over Thinker
the outer door rubber seal at closure
there may be a gap at the chassis there might be a rust spot further along the windscreen other option is to get a professional replace the rubber seal
#232 | ||
not sure if this is still monitored? anyway, my 1985 tx5 ghia, with FE engine, died suddenly while doing approx 90km/h on a qld summer day. having had issues which I believe are early head problems, got it towed home and left it to think about what it had done. convinced myself i should check it out. It seems to have no spark (using plugs from car - so not absolutely certain they are good, but figure they can't all fail at once) from either side of distributor, and checking resistance between centre and spade terminals of ignition coil gives about 7k ohm. between two spade terminals, just slightly > 0 - is this coil bad or could it be something else? don't want to just throw parts at it given age / potential head issues, but no spark i thought should be generally quick / inexpensive on the vintage of car
#233 | ||
Over Thinker
bump because i am back
#234 | ||
Isn't it obvious?
![]() Join Date: Nov 2009
another bump
the misses and i are going to look at a 85 telstar ghia with 93 tho on the clock with the owners books i know nothing about these cars, nothing apart from the similarity to the early mazda 626's anyway for 700 bucks it looks pretty clean in the two exterior photos on gumtree if it runs ok and is nt blowing a cloud of smoke and idles fine and most of everything inside works might be a good chance we'll grab it who knows its only 50 mins away and its a nice day for a drive its white, auto, 4 door, ghia and has a towbar lol http://www.gumtree.com.au/s-ad/felix...985/1035113955 would be perfect for the misses to drive the 30 odd kms round trip for work daily
08 Strike G6E T. 10 Ergo G6E Sept 75 XB Falcon in mushroom beige, 3 on the tree 200cid for sale, offers in the teens |
#235 | ||
Isn't it obvious?
SO WE HAD A QUICK DRIVE OF THE LITTLE GHIA
LOOK FOR 600 COINS (WHAT HE SAID HE WOULD LET IT GO FOR) ITS NOT A BAD LITTLE RUNNER ding in the rear qtr down the bottom another one up the front nothing overly stuffed but a decent scuff/ding interior was dead stock still even the tape deck and was in good nick, few marks here and there but blimey what do you expect for something that old looked reasonable under the hood was only one prob only prob was the digital speed fuel and temp gauge didnt work on the test drive owner said it wouldnt work on a cold day when he nipped to the shops in it a few weeks ago but went out in it on one of the hot days we had last week and it started working but still its just heresay huh maybe it hasnt worked for ages? didnt seem dodgey or full of **** but hey he needs it gone as it was sitting there taking up space son had a blown something or other on a vectra and needed a runner while they dropped 2500coins on the vectra now thats fixed he just needs it gone steered fine stopped well accelerated fine misses passsed (its for her anyway) as shes worried about that speedo had a quick look around the dash for a fuse area but didnt see nothing
#236 | ||
Over Thinker
ok still have the repair manual 83 -87
just not the pictures up on photo tube and cant replace them is this an unleaded model first replace the timing belt what ever you do speedo/instrument panel problems is the printed circuit and dry solder you have to pull the instrument panel out and inspect and recheck circuits copper contacts if not a cable speedo operated then transducer at gear box member vdo knows something about instrument problems contact him by through the forum active in the post classic forum this month jan 2014 you knowing mazdas should have no problem anyway the mazda 626 of the same year is exactly the same in every way specs /parts everything just badging different did a lot to one recently swap from 626 hatch to telstar sedan head gasket blew because the thermostat had been put in backwards the housing has eneough room to do this so be mind full vrs kits are the same the drive shafts you can just undo the circlip and refit the three bearing tree type on the same shaft that fits the ball bearing race the gearbox input hubs are both the same specs so refit the inner boot as normal the cv outer splines are the same any questions post again
My car goes Brumm Brumm Last edited by dirty hands; 16-01-2014 at 11:19 PM. |
#237 | ||
What Do You Expect for peanuts , log books and warranty . 1985 you would not be considering Km just condition , and 600 bucks .
Meet the buyer from hell , now ready and willing to stuff you around . Plenty out there . |
#238 | ||
try moving the positive cable around and re tighten it worked with my mazda 323
phat ltd in the making very lowly ![]() ![]() ![]() |
#239 | ||
Over Thinker
back on line ..lost count of how many computers -- my current one got stolen while at the computer repair shop -- only a year old-- still have not had it replaced by that shop
#240 | ||
long time no chit chat haha
