#211 | ||
hrmm the boost graph is a little disheartening.. but good results tho....
#212 | ||
nothing a pulley change wont fix tho.. right
#213 | ||
Are there any picks of it installed?
#214 | ||
yeah theres pics. head over to www.raptorsc.com.au then click on gallery at the top and theres some in there on the bottom right
#215 | ||
Irregular Member
Ok ive just read through 9 pages of comments lol.
Just wanted to say good job Death351 for keeping us all informed and its great to see another Go Fast option for currently N/A 4.0 Litre guys. |
#216 | |||
assuming i am reading the graph correctly... 3250rpm and 2.5psi? and doesn't hit 5psi till 5000rpm? |
#217 | |||
Sly like a G6
The Frankenfalcon... AU1.5 Wagon, BA brakes, AU2 booster, BA2 XR6T engine, stock from airbox to turbo, 8psi/98 octane tune 240RWKW, BF XR6T cat, quiet 3" zorst, Pex BSO660 & BSO439 mufflers, 84 db, built BTR box, 3.08 LSD, Emer SVI LPG, AU1 XR8 alloys, Momo wheel, JVC KDR746BT head unit, Aerpro steering wheel control wiring. Sleeper, anyone? |
#218 | |||
Sly like a G6
Thing is, in the midrange where the old longstroke donk is most efficient, it doesn't take a lot of boost to muscle up the torque curve, that's why the outputs are still encouraging. I'd still like to see a chart for a manual car though starting at about 2000rpm. I wonder how it would compare with this Landcruiser? At 2000rpm with just 1psi of boost it's making almost 40% more power than stock... ![]() More detail at http://www.turbofast.com.au/supercharger.html
The Frankenfalcon... AU1.5 Wagon, BA brakes, AU2 booster, BA2 XR6T engine, stock from airbox to turbo, 8psi/98 octane tune 240RWKW, BF XR6T cat, quiet 3" zorst, Pex BSO660 & BSO439 mufflers, 84 db, built BTR box, 3.08 LSD, Emer SVI LPG, AU1 XR8 alloys, Momo wheel, JVC KDR746BT head unit, Aerpro steering wheel control wiring. Sleeper, anyone? Last edited by sly; 08-12-2007 at 07:47 PM. |
#219 | |||
Built Ford Tough
Black on white '83 SWB F100 C6 auto 351C on gas and on the ground --> Project Thread '55 F100, just a roller at the moment, new project Silver MY12 Volkswagen Amarok |
#220 | ||
Sly like a G6
...and a couple of us who were sceptical at first have come around...
#221 | ||
I'm still sceptical, I doubt this unit would last long if the boost was cranked up. Given the size of the unit, I'd be suprised if it lasted long between rebuilds on 9psi
#222 | ||
oh yeah there sweet pics, one hell of an ugly Au thou, Tim said they can make pulleys to suit each application to raise booost, im still awaiting a email on the price and stuff. i would think a new pulley is required get it going,
#223 | ||
i believe it was mentioned earlier possibly in this thread that the charger will only take about 11psi before it reaches it's limits...
certainly a cheap and effective way of increasing power tho... with the pure ease of bolting on and away you go.... no turbo setup will be this easy i think i'd like to drive one or even see a vid before i decided to spend the cash tho.... |
#224 | ||
Irregular Member
What was the unit above this one in the kit? I think its a pretty good value kit and like others have said a relatively easy upgrade.
Especially for just an every day driver. |
#225 | ||
would also like to see a vid of the kit on a falcon
but then look at the commodore item.. cant be too bad theres a few vids on youtube of it stock VZ .. fryed its tyres pretty easily
#226 | |||
Sly like a G6
He is a site sponsor on http://www.brisbanecommodore.com/ as he has been doing Commodore kits for a while. Not sure how far from Brissie he is, is Mt Pleasant near Mackay? You should be able to find a Commy owner nearby with one to take you for a spin. Had another email from Tim couple of hours ago, he's looking to buy a non-VCT AU ute ASAP to get the non-VCT kit tuned & ready to go.
#227 | |||
Sly like a G6
#228 | |||
Irregular Member
#229 | |||
Built Ford Tough
#230 | ||
well you will still only want to run it to 11 if they aren't going to warrant it.. and 11 psi on a standard motor is more then enuf.....
#231 | ||
Irregular Member
Just a quick observation,the top radiator hose appears to go pretty close to the s/c bracket.
#232 | ||
The psi on forced induction is really only a measure of an engines restrictiveness, ie eg ;
two I6 falcons with with the same pulley ratios wil have different boost if one of them has a free flowing exhaust and the other had a stock exhaust set up, the one with stock set up will be showing more psi, this would include factors like head work type of manifold etc.My point well, I'm not sure???? 11 PSI with mods will see good power, or if you want more then use a different head unit, Vortec, Paxton.
Losing my patients with unfinished threads ![]() Did the ideas people helped you with work or not! ![]() |
#233 | |||
Teh Baest
Hybrid will offer more low end response than the standard raptor V, but it could be 4-6 months away
1999 Liquid Silver AU Show: XR6 Kit, Low, RDA Slotted's F&B, Fully Tabouli Sound System, Altezza Tailights (Good ones!) Go: K&N Pod w/ 3" intake, XR6T Snorkel, Pacie Comp 4480's, 2.5" Cat Back, CMS Stg2 Cam, Custom Tune, Tranny Cooler Coming..CMS Stg2A Cam, 68mm TB Later.. 4.5L w/ BOOOOOOOOOOST or XR6T or AUIII XR8 220 Currently: 151kW (165 on other dynos ![]() |
#234 | |||
Spr Jenkins
You find me someone that has a stock AU falcon pushing out 127rwkw and i'll show you a dodgy dyno graph. So that obviously puts 197rwkw in doubt. Sure there have been indicitative prices posted in this thread but the price for the complete kit with tuning started out at $3500 and it now up to $5000. As for these things take time apparently 4 1/2 months ago everything was complete except for tuning, I know these things take time but Maztech can build a new national dyno record holding RX3 from scratch in 8 weeks. As posted these guys have done heaps of cars here and in the US and there is no reason why tuning should take more than 4 months.
-Before Chuck Norris visited them, they were called "The Virgin Islands" Now, they're just "The Islands" -Mathematicians have found that due to the excessive amount of women Chuck Norris has slept with, it is guaranteed that he appears in your family tree a minimum of three times -Chuck Norris doesn't sleep. He waits. -Chuck Norris once worked as a weatherman for the San Diego evening news. Every night he would make the same forecast: Partly Cloudy with a 75% chance of Pain. |
#235 | ||
Built Ford Tough
Mine was 123rwkW stock.
That aside, it's not the 127rwKW nor the 197rwkW that matters - it's the 70rwkW increase relative to the baseline figure. $3500 did not include the flash tuner in the price, nor the injectors that were added to the kit. As has been said already that you've conveniently ignored, the kit is actually quoted on application so anyone with a flash tuner wouldn't pay for one again. Enjoy your RX3, Raptor do other kits for other vehicles and no one knows what kind of staffing the company has or how they manage resources and for you to make a comparison like that is rather juvenile - since a one off 8 week job differs greatly for a engineered kit to suit a general application.
#236 | ||
Dyno's aren't out by KW's, if they are out it is by a percent. So if the 127 and 197 are wrong, so is the 70rwkw gain
#237 | ||
Sprjenkins, mine was 136.7rwkw and backed up a year later with 137.2rwkw (only cat back exhaust.)
Who cares that Maztech can pull out a record car in 8 weeks, they are spending all there time focused on that one car to make it the best they can. 1 car, 1 set up, 1 record. Fair enough. The boys doing these Raptor kits are building them for many different cars not just the AU6. If they put every other R&D car aside and just solidly worked on an AU6, like Maztech did with the RX3, Im sure they can have a kit on the market in 2 months aswell. Death is right though, its the gain that you should be more interested in. |
#238 | ||
But it's not about KW's gained, if the dyno is out by a margin of 13% then the gain would only be 60.9rwkw's. But either way, no matter how much the dyno is out by, it is still a 55% gain over stock power, and for $5k thats not a bad improvement.
#239 | ||
Back on the road
Are you guys serious? 127rwkw doesnt sound at all like a high reading for an AU XR6 VCT with extractors and aftermarket exhaust.
The results are pretty much what you would expect for a blower of that size (like a powerdyne BD11a), although it would be really good to know what the impeller speed of the blower is so that we know just how close to capacity it is running. Not much point changing pulley size if the blower is already at or near its peak impeller speed at engine redline. Intake temps would be nice to know as well.
------------------------------------------------------------------------- AU XR8 Ute 13.90 @ 100mph - http://www.aufalcon.com/xr8ute 5L Windsor, GT40X heads, Crane 2030, Pacey 4-1s, Lukey 3", 3.91:1, auto. Tuned by me w/Quarterhorse and BinaryEditor. Coming Soon: Ported lower intake, Tickford "Premium" Brakes, and a good wash. |
#240 | |||
Sly like a G6
