#181 | |||
P6 LTD
#182 | ||
P6 LTD
I did not get much done today as other jobs had to be done. However, I managed to get a few things done.
First of which was the battery tray. As usual, first job was to tap out all of the paint filled threads ![]() Old and the new (well, recon bracket but new solenoid) ![]() And fitted to the car ![]() ![]() I couldn't help myself. It is a bit too early to get the tyres out of storage as I still need to do a bit more work on the front end but hey, I was keen on breaking them out and fitting them as it has been as long 8 year wait!!!! ![]() I also got the headlights back today as well ![]() So the grille is mostly finished now. A few too many pics of the car but hey, why not??? I think it looks great and it is nice to see it finally coming together ![]() ![]() ![]() ![]() ![]() ![]() Last job was to start on the AC & dash, didn't get far though ![]() The focus now though will be on getting this damned dash in though. Much as I hate the idea of having to do it. So hopefully, next update will show all of the dash in. |
#183 | ||
P6 LTD
Some more progress
The dash is now in, well mostly. All of the HVAC system in ![]() New light switch ![]() And now it is in ![]() ![]() ![]() ![]() ![]() Certainly not a job I hope to have to do again any time soon. I still need to get the hand brake and steering coloumn sorted. At least now, the interior can go in. All of the engine bay work has now been completed. Hand brake cable is in, speedo cable is in, bonnet release cable is in, accelerator cable is in, earth lead is bolted to the firewall and the only thing remaining is the emissions cannister. After that, the engine can go in (need to assemble it first though of course). ![]() Hand brake 'front' cable is also completed, bar the spring ![]() Now, a small probelm. I think my front tyres are too clsoe to the upper control arms. Anyone have a solution for this, other than putting skinny tyres on???? ![]() ![]() |
#184 | ||
They should clear the top arm when the vehicle is back on the ground ....if not 1/4 spacer will fix that..
#185 | ||
I'm so envious of you at the moment - the car is getting closer to completion and is looking great. Brute 33 has just posted before me but I was wondering that once you get the motor / gearbox etc in, will the top arm be in a different position?? As Brute has said a spacer should give you that little bit extra clearance but would the tyre still rub under normal driving conditions??
476 EF XR6 Wagons - 198 were Manual 2010 Anniversary XR50 in Sunburst - 6spd Manual My Gallery Photos Here |
#186 | ||||
P6 LTD
If I do require a spacer, are these legal as I will need to get it registered? Quote:
And yes, it is getting very close now. Once the wheels went on, it really started to make a big difference. Now that the dash is in (really crap job that I was not looking forward to), things are going to move along quite quickly now. |
#187 | ||
Will you have it on show @ All Ford day this year 30/10/11?
XB coupe fairmont 351. BA mk11 something old, something new :eclipsee_ |
#188 | ||
[QUOTE=Paull]Excellent, hadn't thought of that. Thanks
If I do require a spacer, are these legal as I will need to get it registered? /QUOTE] I would think those type of spacers are legal as they are sandwiched between the rim and the brake rotor - it's the bolt-on spacer / adapters that seem to cause the problems with the authorities. (But that would only be my reasoning - maybe someone could confirm it) Couldn't help myself had to look again but with the photo of the dash looking out of the windscreen to the scoop - didn't the stripes on a Cobra have a lighter blue Pin stripe to finish them off? Probably one of those little jobs still to do hey??
#189 | |||
P6 LTD
And then ........ Rego!!!!! |
#190 | |||
P6 LTD
![]() ![]() I have also picked up the engine today, sorry no pics as yet. Assembly will start tomorrow (I got the XD engine as well, wasn't planned for but it will be done at the same time as well). Hopefully by early next week it and the gearbox wil be in. |
#191 | ||
You can see the finish line Paul!
Keep it up mate - love it |
#192 | |||
#193 | ||
T3 TS50 075
Will be great to see this back on the road as its hasnt been there since about 1997
Cheers John My car T3 TS50 #75 Blueprint manual 1/4 mile 13.38 @ 102.97 mph ![]() |
#194 | ||||
P6 LTD
http://falconcobraclubofaus.com/stripes.html I was thinking where I had got the info from and all that I could think of was the write up in AMC. Here is an on-line version of it http://cobra.jfpresentations.com/cobra.html I have taken the section of the article and shown it here; Quote:
#195 | |||
P6 LTD
#196 | ||
Moderator Ford Coupe Club
Hi Paull. Regarding your front tyre clearance issue, have another look when the engine is in and the car is on the ground. You will find that the top balljoint will pull away slightly from the sidewall once the vehicle is weighted.
What size tyre are you running on the front? Anything bigger than a 235 may be the issue. I've got 16x8 Simmons with 4+1/2" backspace. The outer balljoint flange is in line with the inside rim of the wheel. Up on stands when I rotate the wheel the wheel weight will catch on the balljoint flange. It doesn't touch when the car is on the ground although it is very close. There is no scraping on the inside of my front rims so it just clears.
Mitsubishi ASX Auto, White - Daily Commuter XC Fairmont Coupe, 351 4spd, Graphite Grey - The Antidote http://www.fordcoupeclub.org "If you don't know where you're going, any road will take you there" George Harrison 2001. |
#197 | ||
Please don't put retreads on this car, or are they just to roll it around on?
#198 | ||
looks fantastic! give a jelly fish a horn.
#199 | ||
injection is nice, but...
as far as im aware, wheel spacers are not legal in NSW ,(i know your in WA) unless they are screwed to the wheel hub, the wheel boss engages as per factory and the original amount of wheel stud is still able to be used, ie longer wheel studs are needed and track is not increased by more than an inch over factory.
I believe the intention is to make it impossible to install a wheel without a spacer where one is required, ie to clear suspension. Also, i think i remember hearing that all XY owners who were given the original globes for their HO's, were also supplied with spacers. Anyone know if this is correct? if it is, it could be argued to your rego people, that it is a factory spacer..... Just some thoughts. Love your build too, some excellent work going on.
Proud member of the Clevo Mafia Limetime Green '74 XB Coupe- Classic not Plastic. Blueprint '02 Pursuit 250- Plastic not Classic (yet) Venom '01 AUII Rebel- RIP. Gone to a better place. Winter White '12 FG GT 335 R-Spec - something the wife thrashes daily '05 CRF450X- For getting dirty in the, um, dirt. ![]() |
#200 | ||
74xbkoop
Looking FANTASTIC!!!! cant wait to see pictures of it finished. Well done on the build.
#201 | |||||||
P6 LTD
#202 | |||
#203 | |||
P6 LTD
#204 | |||
#205 | ||
Yeah that picture, but maybe they are the old tyres...if so sorry my mistake..
Car looks awsome by the way.... I would love a Cobra to go with the Cobra.... |
#206 | ||
P6 LTD
The tyres were bought new in about 2003/2004 from my local tyre supplier. I would have to find the receipt to see what the cost was, but they were not cheap. At the same time, I also asked for the 2x265 & 2x295 tyres, of which I had to wait 3 months to get: they had to make them (in Japan) and then send them out. Lastly, I bought 4 new 245 Yokohama's from Bob Jane T marts (circa 2001) for my ZH Fairlane that I had at the time.
All of these tyres (I have just checked - I still have the 245's from the ZH) all have the same ribbing along the upper side wall of the tyre?????? AS far as I am aware, they are all new and not retreads. At any rate, it is far too late to make a claim but what I will do is to take a few pics and send them off with a query to the Yokohama Technical department and see if I can get an answer. Anyways, the short motor is almost assembled but as I am doing the XD 351 as well, I am not progressing too fast. Will post up more pics on the weekend. |
#207 | ||
I'd be interested to know how you get on Paull. If I'm wrong I'll make sure I give myself an uppercut on your behalf.
Once again she looks a million dollars.... |
#208 | ||
[QUOTE=Paull]The tyres were bought new in about 2003/2004 from my local tyre supplier. I would have to find the receipt to see what the cost was, but they were not cheap. At the same time, I also asked for the 2x265 & 2x295 tyres, of which I had to wait 3 months to get: they had to make them (in Japan) and then send them out. Lastly, I bought 4 new 245 Yokohama's from Bob Jane T marts (circa 2001) for my ZH Fairlane that I had at the time.
All of these tyres (I have just checked - I still have the 245's from the ZH) all have the same ribbing along the upper side wall of the tyre?????? Hey Paul, you know tyres life spans are only recommended for 7 years? I would hate to see one let go and damage your baby! Car is coming along real well, inspiration for me to do mine! If you ever want to go on a coupe cruise, let me know. |
#209 | ||
Just read this thread for the first time.
Bloody awesome. Imagine having your very own brand new Cobra. Of course you wont have to imagine Paull, because you'll be living the dream.
jaydee351 4DV8 |
#210 | |||
P6 LTD
I am not knowing if age alone will perish the tyres??? I know that they will suffer quite badly from UV, that is, being left out in the sun. |
