08-10-2021, 12:51 PM | #15811 | ||
Chairman & Administrator
Data valid as at 00:00 GMT October 7th 2021.
Note: As not all Australian States report at the same time, the data below is based on the previous full day reporting. 2,127 new cases for Australia and 11 deaths so the CMR is 1.157%. 30 new cases and no deaths for NZ so CMR is 0.603%. The UK had 39,747 cases yesterday and 142 deaths for a CMR of 1.708%. 111,662 new cases in the USA yesterday and 3,316 deaths sees CMR at 1.622%. Other notable points: North America passes 54M cases; The USA passes 45M cases; No countries ... recorded new highs; those in blue for the second consecutive day and those in red for a third or more consecutive day. Germany moves above the 90th percentile for the 10 day period while no countries drop below.
Observatio Facta Rotae
08-10-2021, 12:59 PM | #15812 | |||
If it’s just going to be D2, does the R-number also become R2? |
08-10-2021, 01:06 PM | #15813 | ||
That'd be the phonetic alphabet
Labels are for jars, not for people. Life is a journey, not a destination. ~~~~~~~~~~~~~~ Daily: 2013 FGII EcoLPi in Winter White Play: 2015 FG X XR8 in Emperor Show' N Shine thread Gone, but not forgotten: 2015 SZII petrol Titanium Territory in Emperor |
08-10-2021, 01:13 PM | #15814 | ||
Busy morning on the Covid front! I'll just post this one and then take a break to allow others to chime in for a bit....
ATAGI recommends booster shot for immunocompromised people Australia's expert panel on vaccines has recommended a third dose booster shot of a COVID-19 vaccine for people who are "severely" immunocompromised. The Australian Technical Advisory Group on Immunisation (ATAGI) said people with certain conditions, or who are on immunosuppressive therapies such as chemotherapy, might not be fully protected by the regular two doses of a vaccine. ATAGI advised for those people, an additional shot should be given two to six months after the second dose. It said the Pfizer and Moderna versions of the vaccine were preferred for booster shots. No recommendations on third doses have been made for the general population at this stage.
08-10-2021, 01:48 PM | #15815 | ||
Not many chimers?.....lol.....
08-10-2021, 02:18 PM | #15816 | |||
IT Drone from Sector 7G
2 users like this post: |
08-10-2021, 02:59 PM | #15817 | |||
N/A all the way
That Penhalluriak was quite good, and correct at the time, but it looks like all the missing pieces he identified are being filled in as I first suspected they would be (but not fast enough to make me stop making my own tin foil hat) https://www.dhhs.vic.gov.au/sites/de...directions.pdf
BA GT 5.88 litres of Modular Boss Powered Muscle 300++ RWKW N/A on 98 octane on any dyno, happy or sad, on any day, with any operator you choose - 12.39@115.5 full weight |
08-10-2021, 03:19 PM | #15818 | |||
Whatever the reason, it appears to be the current practice anyway.
08-10-2021, 04:34 PM | #15819 | |||
Experienced Member
08-10-2021, 04:59 PM | #15820 | |||
I see that clause 3 states the validity period for the Direction and states that the Directions end at 11:59:00pm on 21 October 2021. Anyone who is concerned by the requirement to be vaccinated could simply take leave until that time and then return to work after that date. Of course, these Directions can be extended, however that be effected, to apply after that date and you'd run the risk of that happening. Another thing I picked up on was that an employer is not permitted to allow a "worker who is unvaccinated to work for that employer outside the worker’s ordinary place of residence". But 'work' is not defined and I wonder if being on a form of leave may be construed as being 'work', after all, you are still employed by the company.
08-10-2021, 05:02 PM | #15821 | ||
Posted for CB's benefit
08-10-2021, 05:41 PM | #15822 | |||
~~~~~~~~~~~~~~ Rides (past and present) Current: 2004 Ford Falcon 5.4L 3v Barra 220, Manual Past: Mitsubishi Sigma (m), Toyota Seca (m), Toyota Seca SX (m), Toyota Vienta V6 (m), Toyota Soarer 4L v8 (a), BA XR8 ute (m), T3 TE50 (m), BMW Z4 (m) AFF motto - If contrary views trigger, please use ignore button. |
08-10-2021, 07:53 PM | #15823 | |||
Just ask ya GP, he'll tell you the same! |
08-10-2021, 07:58 PM | #15824 | ||
08-10-2021, 09:09 PM | #15825 | |||
N/A all the way
On the "work" one, this is basically saying "work from home only" if you are not vaccinated, and your work cannot get clever by sending you to clients, a cafe or the like saying that you are not in their normal workplace.
08-10-2021, 09:22 PM | #15826 | ||||
https://images.app.goo.gl/ggMdG5bmwLenhqC89 This prevents blood from draining out of the brain and back to the heart. As a result, blood cells may break and leak blood into the brain tissues, forming a hemorrhage. |
09-10-2021, 10:02 AM | #15827 | |||
Thank you kindly for your reply, I feel good now! |
09-10-2021, 10:10 AM | #15828 | ||
So 1,965 new locally acquired cases today and 5 deaths in Victoria, and NSW not too good neither, and a truck driver who tested neg in NSW tests positive in SA, from Ch24 news ABC TV.
09-10-2021, 10:38 AM | #15829 | ||
WT GT
Downward trend in cases, 90% first vaxxed today, opening fully soon, shiny new Premier What bit of NSW is "not too good neither"?
09-10-2021, 10:46 AM | #15830 | |||
There are two main types of stroke: ischemic and hemorrhagic . An ischemic stroke is the most common type, and happens when blood flow is blocked. This may be caused by a clot that formed in a different part of the body which broke off and becomes trapped in another part of the system (and his just happened to be in one of the arteries feeding his cerebellum). The clot could have also formed more locally, or it might have been a small tear instead. A hemorrhagic stroke is caused by a burst blood vessel. Blood pools in the brain, causing a build up of pressure which then slows or stops the flow of blood. Cerebellar stroke is more common in older adults and people with a family history of stroke, and health problems that affect blood vessel health and blood flow can raise the risk. This may not make you feel better, sorry. Jamie |
4 users like this post: |
09-10-2021, 10:52 AM | #15831 | ||
Regional vaccination rates, disability sector vaccination rates, but these apply to other states and territories also.
A David Pope cartoon puts it well for critics of NSW Last edited by cosworthfreak; 09-10-2021 at 10:58 AM. |
7 users like this post: |
09-10-2021, 11:02 AM | #15832 | |||
https://fordforums.com.au/showpost.p...ostcount=14390 "Victoria is very similar to NSW running at "REFF 1.3". What this means is that for every 10 cases, those 10 cases affect another 13 people." "At that current rate, it means the daily cases numbers will DOUBLE every 10 or 11 days." "Let's put some dates to that to visualise the scenario, if that REFF 1.3 continues"... 1/9/21 - 120 cases 11/9/21 - 240 cases 21/9/21 - 480 cases 1/10/21 - 960 cases 11/10/21 - 1,920 cases "I hope I am wrong, and things turn around but things are not looking good". Well, unfortunately we have exceeded that number 2 days ahead of schedule... Not good. |
09-10-2021, 11:34 AM | #15833 | |||
Ch 24 news this morning. |
09-10-2021, 11:39 AM | #15834 | |||
Hello Billy, Sorry I have not written for a while. I hope that everything is going OK for you. Unfortunately, I just spent 8 days in hospital after suffering a stroke. Good news is that I have had lots of scans, blood tests etc., and apart from the stroke my heart condition, sugars, cholesterol, blood pressure, O2 levels are all good for my age. Bad news is that the blood clot in my brain came from somewhere unknown at the moment. I had a pretty rare stroke called a cerebellar, in the cerebellum at the back of the brain. Main problems are balance and coordination, luckily I have no weakness in my limbs or speech problems. Eyesight has been affected slightly but I am told it will improve gradually. I had a physio assessment at home today to check that I can walk, climb stairs etc., no problems at present. I just walk like a drunken sailor but not allowed to drive for a while, maybe forever. Apart from that, life goes on. Hopefully things are stable for you? Cheers Dave Sent from my IPad |
09-10-2021, 12:26 PM | #15835 | ||
NSW/VIC
NSW records 582 cases in the current period and the 10-day average growth rate decreases to 0.9644 (from 0.9746) while the actual line remains above the predictive trend line and based on the 3rd order polynomial, that trend line has a downward curve. VIC records 1,965 cases in the current period (another record high) but the 10-day average growth rate decreases to 1.0989 (from 1.1016) while the actual line is further above the predictive trend.
09-10-2021, 12:53 PM | #15836 | ||
Data valid as at 00:00 GMT October 8th 2021.
Note: As not all Australian States report at the same time, the data below is based on the previous full day reporting. 2,523 new cases for Australia (a new record) and 16 deaths so the CMR is 1.146%. 47 new cases and 1 death for NZ so CMR is 0.612%. That's the first death since September 3rd and only the 3rd this year. The UK had 34,910 cases yesterday and 104 deaths for a CMR of 1.702%. 110,134 new cases in the USA yesterday and 2,043 deaths sees CMR at 1.622%. Other notable points: Global deaths pass 4.85M, the last 50k in 7 days; Europe passes 60M cases; Oceania passes 250k cases' Australia (2,523); Singapore (3,590) ... recorded new highs; those in blue for the second consecutive day and those in red for a third or more consecutive day. Ireland moves above the 90th percentile for the 10 day period while no countries drop below.
3 users like this post: |
09-10-2021, 12:53 PM | #15837 | ||
Surprised that this story, which broke yesterday, has not been covered in here, especially given we have frequenters who are not Dan fans.
Victorian Premier Daniel Andrews fined for COVID rule breaches after being filmed without a mask Victorian police have issued Premier Daniel Andrews with $400 worth of fines for breaching COVID-19 directions after being filmed without a mask before attending Parliament. Mr Andrews had apologised for the incidents, which took place as he walked across the Parliament carpark to speak to journalists on Wednesday and Thursday mornings. https://www.abc.net.au/news/2021-10-...mask/100523614
09-10-2021, 01:00 PM | #15838 | |||
Gees...got up early this morning and headed out for a hike. With the amount of people out and about, would not have guessed we were close to 2000 today.
09-10-2021, 01:01 PM | #15839 | ||
Although NSW avoided reaching the peaks predicted in the early modelling which predicted > 2000 daily cases and actually peaked on day 87 with 1,603 cases before starting to trend (albeit erratically) downward, Victoria is still trending upward at the same stage despite the fact that the initial growth rate was slower.
The predictive model above shows that 2,500 cases a day could be passed in the next 8 days unless the trend starts to reverse quickly.
09-10-2021, 01:11 PM | #15840 | ||
If you are in the public eye then I think you would be wearing it everywhere so you didn't have these gotcha moments.
