#1531 | |||
Cabover nut
Tractors are out of the cheap equation though, to many reseller in this game. Reckon you could stick one of the smaller 10-12ft used pantec on your block which would allow you to lock and store a mower and necessary gear needed. Basically what I did after buying land.
3 users like this post: |
#1532 | ||
These seem to have a modestly good rap. I realise the seller is a trader.
https://www.gumtree.com.au/s-ad/1294186452 With a 500mm cut, after deducting the un-mowable areas (dams, shack etc) it would be an 18km walk to cut it all with this. ![]() |
#1533 | |||
2 users like this post: |
#1534 | ||
Cabover nut
I still use a walk behind Pope I bought years ago to cut an acre. The ride-on project would make me feel a little guilty.
#1535 | |||
Regular...with metamusal
![]() Join Date: Oct 2009
years ago we had a ride on .......... for mowing a house block - front yard [narrow nature strip, front of house was also narrow & short altho split level & a larger side lawn to fence halfway down block - long block]. dunno why he bought it .. but he did ... mowed the school oval next door a coupla times with it ![]() ![]() |
#1536 | |||
Cabover nut
Considering most of large gums now have granite block edged garden beds surrounding them. Certainly solved the non existent grass at their bases and looks kind of perdy.
#1537 | |||
![]() Join Date: May 2008
I would really want to see the discharge shoot, I suspect it might be pretty small. Also note the single bar blade. If you are cutting rough stuff, the chance of bending your crankshaft from hitting debris is higher than for swing back blades. This one is a smaller cut but has a pretty powerful engine - https://www.gumtree.com.au/s-ad/lake...wer/1295320759 https://www.gumtree.com.au/s-ad/dand...ute/1295246877 Or go old school ![]() https://www.gumtree.com.au/s-ad/nort...ine/1295642059
PX MK II Ranger FG XR6 FG X XR8 Mustang GT T3 TS50 - gone but not forgotten |
#1538 | ||
Goats ftw but CB I'd gift you a rideon, but the shipping would be a killer I do have surplus 1 king cat and a Husky
#1539 | ||
There was a goat to mow, taken there because at its prior lodgings (near Beckom) a member of the local footy team would do bad things in the dark. It was later stolen from my paddock.
DFB - thanks for the inside scoop. The MTD is least out of my way (about 120km detour), that’s part of the appeal. I’d seen those others, the newer one at Conjola was the most tempting. |
#1540 | |||
https://www.victa.com/au/en_au/produ...60-725exi.html
#1541 | ||
Oil Change day, as well as an impromptu blade change.
https://www.fordforums.com.au/showth...23#post6713623 ![]() ![]()
#1542 | ||
Cabover nut
Penrite, the good stuff.
#1543 | ||
Gloves, for outdoor work. I’m still struggling to find anything that fits snugly (Velcro cuffed) and is both breathable/tough. Suggestions? The “Mechanix” ones I had three years ago were brilliant, nothing has come close since then.
#1544 | |||
Former BTIKD
![]() Join Date: Mar 2005
![]() If you cant find something among their range you don't need gloves ![]() https://ironclad.com Aust distributors http://www.brightonbest.com.au/the_r...roncladAU.html
#1545 | ||
Typical, you can’t get the serious ones in pink. Plenty of range in there, to the point of it being confusing.
Really wanted to pick up something tomorrow, but looks like an order-in is likely. |
#1546 | |||
Former BTIKD
Sydney tools carry about half a dozen of the more common types.
#1547 | |||
T3/Sprint8
![]() Join Date: Jan 2005
I have found them brilliant for my gardenning and any other use I feel the need using them. The MXStore have a heap to chose from....... https://www.mxstore.com.au/p/100-x-M...yABEgIHEfD_BwE
#1548 | ||
#1549 | |||
Cabover nut
Most truck part or steel suppliers sell them in bulk. The cheaper ones (sold at you know where) have stitching down between the fore finger and thumb which will always pull apart.
#1550 | ||
The telltale sign of a dying engine.............
![]() And no, that is not a two-stroke! This is the Atom edger at work, powered by a 31cc Honda GX31 4-stroke. While it has done a fair amount of work, a staff member ran the poor thing low on oil a few times, it has smoked ever since. Keep in mind these tiny little 4-strokes hold only 100ml of oil, so running it low is really running low! It's on it's last legs now, it smokes at idle and smokes ever more under throttle.
#1551 | |||
RS The Faster Fords
![]() Join Date: Feb 2014
Quality control is down too, our latest one turned up with the fuel draw and return line around the wrong way. It'd run to about 3/4 of a tank and shut down. Didn't take long to work it out but annoying all the same...
Escort RS2000 Restored factory a/c and alloys. TD Cortina Unrestored 35 000km 6cyl manual. Mk1 GT Cortina Project. FG XR50 Daily. |
#1552 | |||
What engine do you have on yours? I actually recommended getting the 48cc Mitsubishi 2-stroke version to remove the oil change/top up factor. https://atomindustries.com/product/5...48cc-2-stroke/ https://atomindustries.com/product-c...y/lawn-edgers/ Anyone ever use one of those evil looking and sounding Victa Tilt-A-Cut's? ![]() ![]()
#1553 | |||
RS The Faster Fords
I was neither here nor there on it but the two stroke does make sense given thats what all of our other hand tools are, keeping the pre-starts and fueling the same. Funny you mention the Victa, I pulled this from the back of the garden shed, for disposal, last weekend. ![]() It was a hand me down from the Father in law. The Mrs says she was terrified of it as a child and after hearing that two stroke howl I can see why ![]() Other than being loud and cumbersome it actually doesn't do a bad job. I was going to take it into work as parts or for an apprentice to pull apart on a rainy day but after looking on gumtree I see people asking a couple of hundred bucks for them. The Escort build is keeping me pretty poor at the moment, I might list it any see if theres any takers.
#1554 | ||
[QUOTE=DFB FGXR6;6715116]That's a shame, they are the best edger available. I actually mentioned replacing the engine but was told it would best just replaced. I also heard something rattling in the transfer case, so it needs too much work.
What engine do you have on yours? I actually recommended getting the 48cc Mitsubishi 2-stroke version to remove the oil change/top up factor. A friend recently gave me a similar machine fitted with a B & S motor. For what ever reason it is locked up, probably not ceased in the traditional sense, but due to corrosion etc. It had never been used for at least 10 years. It is one of those engines where the carburettor is mounted directly on top of the fuel tank. Fortunately I checked the fuel tank first and it is full of rust. If it had been an engine with a conventional gravity feed fuel system I may have investigated the main issue further. Now it's bound for the tip. |
#1555 | ||
[QUOTE=DFB FGXR6;6712188]The Kohler I had was on a Rover. It copped a beating but I never liked that engine. From new it burnt oil, was often harder to start than it should have been and was a noisy engine (the muffler on them is too small). The 173cc Kohler was also weaker than the smaller 163cc Honda that replaced it and just always seemed to lack the grunt/torque to get through the rougher stuff.
As much as it pains me to say this, I would also avoid the two-stroke machines. They have a lot of grunt but are finicky bastards to keep running over time. Absolutely agree with your views/experience re. two stroke engines. Is it just me who sees a remarkable similarity between the Honda motor you pictured and The Sanli engines, eg. the OHV 350 ? |
#1556 | |||
[QUOTE=John 13;6715408]
Kohler - ![]() Loncin - ![]() The "Rover" engines - ![]() ![]() Sanli - ![]() The "Victa" engine - ![]() I could go on and on but you get the idea. What I have found with all of those cheap knock off engines is how loud they are, mainly from the lack decent mufflers. I also know that those Honda GXV160's are made in China too, difference is that they are a Honda design, not a copy.
#1557 | ||
Had this mower repair stand delivered today.
https://www.ebay.com.au/itm/192833938487 ![]() ![]() I wish I would have known something like this existed, like, 20 years ago! ![]()
#1558 | ||
You’ll not be able to resist detailing them now… Have you ordered the Koch Chemie “Klinge-Wachs” yet? :p
Quite a nifty little jigger, my question to myself would be “Will it start/run on the stand?” (I’d feel compelled to try.) |
#1559 | |||
#1560 | ||
I just made it up, that’s German for “blade wax”.
![]() Actually surprised our Nanny Country doesn’t require an A3-sized sticker telling you to remove the stand before starting or using the mower. |
