#121 | ||
sounds like you have it all figured out
cops could defect any car if they wanted too |
#122 | |||
I hate ricers
I checked the lash a few weeks ago Jamie. They were all pretty much spot on. |
#123 | |||
N/A BOSS 390+
![]() ![]() FPV GT 03 /341 RWKW OF N/A POWER. XB GT 73 /OLD FORD MUSCLE ALL AUSSIE MUSCLE |
#124 | ||
![]() the old old 302W motor back in 1988 had a 3500rpm Dominator i think it was, ran 11.5's, 60' in the 1.6's, daily driven. Norm @ Northmead Auto Centre built the C4 (been building box for all our cars for 20 years now), trans oil was being changed only once or twice a year, was taken out fortnightly to street meets. 302W (around 1998-1999), had a 5500-6000rpm TCE converter, it was daily car for 2 years, was doing 300km+ a week and racing at least every 2-3 weeks. ran mid 10's, didn't miss a beat on the road or strip. required very very minimal maintenance. greencapri408 is correct, sit down have a chat with the gearbox builder and the torque converter guy and work out exactly what you want and were trying to achieve. feed them as much data as u can, and u should come out with the best combo possible. the best thing you can do is surround yourself with people that know their stuff, if you aren't sure of something don't be afraid to ask questions. if he is 60'in 1.56 the converter is doing its job. thats a damn good 60' especially considering its had so few passes. Last edited by prasac; 07-12-2012 at 01:04 AM. |
#125 | |||
Budget Racer
As has been mentioned, it's a little strange to spend pages discussing the "problem" with a street car that runs in the 10's on its second outing! Short answer is you have no problem. You mentioned the weather. There is a reason why so much weather information is given on time slips, and why data loggers contain weather stations. The weather directly affects the power output of your engine. There is often intense discussion on forums about Dyno Vs time slip. Dyno's measure horsepower (work done over time). Time slips measure performance (work done over time). So if they are measuring the same thing, work done over time, they should come up with the same result. They often do, but dynos make "corrections" to the raw data to allow for the weather. Time slips show the power required to run a particular number on a particular day, they do not correct for the weather. That is why people (including me) refer to time slips as "real horse power" as in an actual measure of work done over time. So if we take 602 horsepower your car made on the Dyno. Allow for any changes made when it was raced at the track in your car; different air cleaner, water pump, alternator, mufflers etc. Then we need to reverse engineer the correctional factor for the weather. Plug in the weather conditions from your time slip on a calculator like this http://wahiduddin.net/calc/calc_hp.htm It tells me in those weather conditions you will make about 95% of the power the Dyno showed. So that’s less about 30hp before we add in any short comings in the converter, fuel system, suspension, your driving etc Short answer is you have no problem. ![]()
12.1@112Mph 285rwkw on n2o Cleveland Power Last edited by Work Horse; 07-12-2012 at 11:53 AM. |
#126 | ||
Weezland
Riddle me this fella's,
The moroso calculates average power over a run by terminal speed using weight to come up with a power figure right? So for interests sake lets say a car makes 600hp at 7000rpm, but at 6500 is only making 500hp. This car crosses the finish line at 6500 because of gearing, and top gear is usually around half the track distance give or take. How will the car EVER show the moroso calculated HP, since its NOT using its whole hp over the entire 400m? It CANT, because it throws out the rigid maths calculation used...... Anyone who says it can, is either sandbagging, or doesn't understand how the moroso works.. |
#127 | ||
Workhorse,Brad made 602 engine (wonder if alternator was fitted, I believe the rest is electrically operated) . 438 rear wheel, Brad was that at the end of the"tuning" session for a better word as a few things were changed and tried, maybe that figure is after the XT suffered heat soak? And on a fresh day may make more rear wheel power?
I suppose the unknown in The XT is how much power the convertor/auto, pipes/mufflers are sapping too? We know what the tail pipes are worth. Regrettable as the examples already raised 430rwhp and 455 respectively have run 128/129 pretty consistently but like you say humidity played a part in Brads? Nugget as for the Moroso never seen a street car get close and few super sedans and better have done claimed. But I'm not going to argue with a calculator that has been used by seasoned drag racers for years. My take on it is like any good tool it has it merits and downsides. But it is clear Brad believes it should mph or et better or he wouldn't have asked the question. Like I have already posted a few years 10s were unheard of, the XT is quick
It's my call pizzoff, and I just called it |
#128 | |||
N/A BOSS 390+
![]() There still might be hope.Dont want to hijack Brads efforts but the XT is a weapon nothing comes close ![]()
#129 | |||
Cheers, Steve.B |
#130 | ||
XR 1967
Ok my 2c lol..
There is allways a few things people can do to improve there times but yer 10's second go out, Well done.. Try some front runners if you haven't allready.. (less drag) I have a Gtech because a drag strip is 4 1/2 hrs away lol.. They work out your 1/4 mile times by Gforce.. The same with HP.. One thing I did read was, the HP on the Gtech will show less then the dyno, because one is dyno HP and the other is road HP.. The diffrence is air quality but the big thing was drag of the car (some cars have better drag then others) That can be areo, tyres, head wind or many other things.. Good luck with it .. You should be happy no matter what.. |
#131 | |||
#132 | ||
How much power would a alternator use?
'68 XT Fairmont, 9.48@141.6 '69 Capri '95 triumph speed triple, '10 Fat Bob My XT Fairmont http://www.fordforums.com.au/showthread.php?t=11298079 My capri track car http://www.fordforums.com.au/showthread.php?t=11492523 |
#133 | |||
Copy of the dyno sheet here http://www.fordforums.com.au/showthr...330073&page=11 Unfortunately dyno min starts at 4500 (300rpm below his current stall) but at 4500, it makes 507.4 with a Max of 515.6 at 5450, having a guess it would still make 500ftlbs at 4200, what do you reckon and extra 15-17FTLBS would give to the 60'?
#134 | ||
Do you run a standard fan belt ? You can spin an alternator by hand, depending on belt I wouldn' think more than 5hp? Anyone disconnected one and seen a difference?
#135 | ||||
Weezland
![]() Which would be about right on the moroso at its weight.. Quote:
Brad has said to me, and in this thread he is happy.. Again the intent of you and your cronies is showing... Brad this is what you should do next time, tell NO one what your dyno output was, wait till you race it, then look up the slide rule and claim that was what it made, claim it has a hydro F/T with 8:1 comp, and then you can become an instant internet hero. |
#136 | ||||
#137 | |||
Weezland
"showing" 540 moroso is damn good for a street car like his and about what should be expected, nobody told him that though did they? |
#138 | ||
What ever! again relevance too ME? Bark up the relevant tree and leave me alone , you are making yourself look like the fool...
#139 | |||
Weezland
Do you have the maths calculation to show what a cars output is when it crosses the line at under its max hp rpm by so much and can work it out? Thats the point. |
#140 | |||
N/A BOSS 390+
#141 | |||
Cheers, Steve.B |
#142 | ||
Weezland
2 users like this post: |
#143 | ||
Brad congrats on the times, there was some discussion in a thread a while back about alloy headed cars not showing the track times to match the dyno, my car is the same. I'd be checking the plugs and just making sure you not leaning out and be done with that, I rember a post of yours in your engine build thread that said it's main purpose was street duties and the odd skid at the track, you and Russ have definately achieved that, hats of to you both.
#144 | |||
#145 | ||
So forget the Moroso , what should 602 engine horsepower run? Or the 10.94@123 is right?
#146 | |||
Budget Racer
![]() I've watched him race and shaken his hand. Do you reckon he still talks about me....
12.1@112Mph 285rwkw on n2o Cleveland Power |
#147 | ||
Windsor hasn't started his alcohol rail for 30years I doubt your that old...
#148 | ||
cast iron is real steel!
G,day,
A quick 2 cents worth here Brad, Forget about peak numbers Brad! The moroso numbers are an average hp used for that pass, end of story! You need to dyno the engine at the same rpm rate / 1000 rpm as the car accelerates in top gear , look at average hp on the dyno in the same rpm range that the car will see at the track. ie from start line to finish line. Then you will see numbers that you need to match. It depends on how well the car is set up as to whether it will show those numbers. Race cars should go very close. Street cars it all depends, don't get hung up on it but if it is a streeter. Well done with what you have achieved! Cheers Paul |
#150 | |||
Weezland
I will say this, reading between the lines your questions' just a shifty way of saying YOU dont believe it made 600hp, and belittling Brad and Russ, saying the same thing, in a different way as your mate blocker/windsor/steveB/whoever it is... |
