#91 | |||
Soz I am extremely anti wireless Wireless will compete with wires, and with the atmosphere. I have my home wired Cat6x for a reason. FTTN+10gb cable will kill wireless for a long time - the biggest advances in wireless have been through (IMHO) compression, not actually increasing real throughput. |
#92 | ||
Adapt or perish...
Noted that my area is having NBN being built so I'm guessing that it's FTTP as the house already has that installed...
Carless
#93 | |||
#94 | |||
Has anyone noticed their broadband running slow as late? Could it be related to Netflix being released? It seems that a lot of people now have it and considering how the ADSL exchanges work if your areas all on it then its bound to slow things down?
#95 | ||
Thailand Specials
Yep had serious issues with Telstra, people are putting it down to congestion but it can be happening 3AM in the morning on a weekday.
Started off with issues, wouldn't connect to the internet, 3 days later it started working again, had Telstra tech out to the house, checked exchange and my port was connecting at 24mbps and no issues, did tests on the line into the house and showing 12mbps connection inside the house up to modem, but it would only connect at 7mbps with my modem, so he tried his, same problem. Which has now dropped to 4mbps but I can't watch youtube or download anything from outside of Australia, if I attempt to download from US servers I can only manage 30KB/s download, youtube just stops all the time, need to watch on 240/360p quality. But some days, usually once a week I can connect at a solid 10mbps, and can download from the USA at 1.2MB/s and watch HD youtube without it stopping. It doesn't seem to be related to congestion though like people are pointing out, because if it is why am I copping massive speed loss (4mbps) at 3AM in the morning on a weekday? But once a week getting a rock solid 10mbps connection in peak times? People on Telstra ADSL2+ all over the country are having the same issue as of the last month or two, mine predates Netflix release. I have a feeling there is some fault in something important on Telstra's end which deals with internet outside of Australia. Last edited by Franco Cozzo; 04-05-2015 at 11:19 PM. |
#96 | ||
bitch lasagne
Up until Wednesday morning last week I was syncing at 13100kbps, with resultant downloads of 1.3MB/sec. Wednesday night, that dropped to 2800kbps with zero stability (uptime of an hour tops). This has been the case since. Internode have been advised of the issues but none of their "fixes" have worked.
#97 | |||
Thailand Specials
Telstra techs keep asking if I'm trying to connect via Wifi: https://www.youtube.com/watch?v=UU_GhqVgc9M Want NBN, and want it yesterday. |
#98 | ||
Ich bin ein auslander
I would be happy to just get ADSL2 instead of being stuck with 3G mobile net with no better than 2 bars of service. For that I pay $65/month and have a 8gb download limit which is swallowed up quickly if I update my Macbook and IPhone.
Alas I have to wait until all the areas with ADSL are upgraded to NBN before they will likely install any infrastructure for us to get NBN, not holding my breath for the next 5 years at least. Frustrating as I am approx 40kms from the centre of Brisbane and still in the metro area, newer estates less than 2kms away have NBN.
Growing old is compulsory, growing up is optional! |
#99 | |||
Thailand Specials
#100 | |||
I know your pain, I get so annoyed hearing people whine about their ADSL2.
#101 | ||
Sad, downloading a 1gb update for my IPhone often takes 6hrs and takes a large chunk of my download. I have to carefully ration even watching youtube clips due to my download limit and I probably pay more than you.
#102 | ||
Thailand Specials
#103 | ||
We actually have two mobile net modems at $65/month as that was the cheapest way to get 16gb download. With moderate use we still bust our download nearly every month. I would gladly pay your rate for your download and get you download speeds as I often refresh a forum page and then go make a coffee while it loads with the coverage we get at home.
I am actually loving being at work at the moment as at station I get 4g coverage and it is a Lamborghini compared to the speeds at home. I suspect you also get a fixed line phone and quite generous call limits in your plan, you do not get that with the mobile broadband.
#104 | |||
Thailand Specials
Have you tried an external antenna to improve the speeds? I think Telstra actually sells a 3G antenna to hook up to the modem, might improve your speeds a bit if you can get more signal. NextG coverage out here we get about 4mbps. |
#105 | |||
Amazing to think we live in the Brisbane metro area and we get service below that of many developing countries.
#106 | |||
If you get coverage outside with a handset and poor coverage with an external I'd suggest you have an issue with your antennae setup. Id suggest popping over to telco antennae website and have a read. There is some good advice there. A cel fi smart repeater connected to an external antennae will allow your phone to get coverage as well. You are also well within km range of 4g with grid antennae, obviously subject to tower location, but well worth following the guides to see what is possible. |
#107 | ||
Both my phone and modems are 4G but nil coverage at home although there is a few km's down the road. Phone service is not good at all even outside. The modem certainly gets better reception. We don't want o run our phones off the antenna as with the poor service even having two computer on the internet at a time slows it down to intolerable levels. Antenna was not bought from telstra, it came a from a communications specialist store in Brisbane but the name escapes me right now. We have the best set up we can get.
#108 | |||
Thailand Specials
Especially that 4G tower you are talking about. https://www.telcoantennas.com.au/sit...tennas/outdoor Even things like how long the coax run is into the modem inside the house, you lose signal through that too. Last edited by Franco Cozzo; 05-05-2015 at 02:22 PM. |
#109 | |||
#110 | |||
No line of site, dirty great hill in the way. Can't raise the antenna any further as the length of coax causes a loss of signal. So basically we are screwed, we have the best we can. No just have to wait for all the ADSL2 spoilt brats to get their NBN before we can expect to be lifted from the stoneage.
#111 | ||||
#112 | ||||
Thailand Specials
Others like yourself have found disconnecting and reconnecting fixes it, others change their line profile in the Telstra account configuration page works as well for some reason. With me nothing works I've just gotta wait, got a good connection today. Quote:
#113 | ||
bitch lasagne
My line stats went from bad to worse:
Connection speed down/up: 2393/600 kbps Line attenuation down/up: 26.0/20.4 dB Noise margin down/up: 15.6/16.0 dB There is a heap of audible noise on the phone now. Fault has been logged with Hellstra, they did a test from their end, found a fault but couldn't pinpoint where. The bloke on the phone said he has escalated to a specialist team (whatever that means). |
#114 | |||
Thailand Specials
#115 | ||
bitch lasagne
Just went out into the street where the line meets joins one of their junction boxes; the copper looks like its older than me
#116 | ||
To be honest, I wouldn't be surprised if Telstra still used Telegraph lines to save costs
2006 Build BF XR8 Ute - Lightning Strike ZF Auto. Manaray Sport Vertec VR5 19s, Bluepower CAI |
#117 | ||
bitch lasagne
It sure looks like it Ruination LOL!!!
#118 | ||
bitch lasagne
Telstra tech is coming out Friday to sort this crappy line out.
#119 | |||
Clevo Mafia Inc.
![]() Join Date: Dec 2004
I was one of the first in this area to take up adsl2+ was 17megabit consistently. Now a good day is 10megabit with as low as 3 when really congested. NBN can't come soon enough! |
#120 | |||
Thailand Specials
Buts it doesnt seem to be related to congestion. |
