21-07-2021, 06:51 PM | #1 | |||
Noisy diffs generally comes from re-using gear sets after a wear pattern is formed, it’s hard to replicate it. I had no noise in my 3.91 true trac and still don’t after some km. No speedo gear available for the 3.92 gear set; will need a 4 pin 12v speedo corrector that interrupts the VSS signal to cluster yet supplies the unmodified signal to the EECV.
Current Car: 2002 AUII LTD 408ci Windsor, T6 S488, TH400, 2 Piece Shaft, Helicial LSD 3.23 IRS Daily: 1998 Mitsubishi Super VR-4 Legnum |
21-08-2023, 04:42 PM | #2 | ||
5.6L x 2 pilot
Apologies. Thead mine of the decade.
Did any AU XR sedan come with a live axle? I thought the live V IRS was in this thread, but it is not. I am currently planning an upgrade for an AU2 Forte, so 3.08 be gone! Cheers Stu.
2002 AU II LTD 5.6L 342ci T3 Short, AFR165 heads, Comp XE270HR-12 Cam, Brembo 4/4s(355/330), T3 5 spokes, LC-1 wideband, Whiteline HD swaybars, TCE 3K Hi Stall, PWR Auto Trans Cooler, Koni shocks, King Low Springs, Hurricane headers, 100 cpsi cats, Twin 2.5" exhaust. Quarter Mile: 13.73 @ 105.86mph Runner Up NA/DA to BF Fairlane/LTD Geelong AFD 2024 2002 XR8 pursuit 250 Custom twin 2.5" exhaust w Herrod modifed extractors, Tuned with Moates QH
21-08-2023, 09:08 PM | #3 | ||
Sick Puppy
3.45 LSD centre from an IRS will go straight into a solid housing.
21-08-2023, 09:13 PM | #4 | ||
5.6L x 2 pilot
Not into a 3.08 housing which my Forte currently has. They are quite visually different.
So I guess that leads to my next question. Where there any AU sedans with a live axle that was not a 3.08? Stu
22-08-2023, 08:47 AM | #5 | |||
there are lots of factory ford ratios for live axles but all crap 3.08, 3.23, 3.28, 3.45... its not really worth the effort unless you can find a bolt in effort. go a 3.9 ratio, talk to a diff shop i went from 3.08 to 3.45 and i think it was 0.1s quicker to 100kmh
CURRENT RIDES BA GT Mk1 #0009 - Narooma Blue SY Ghia AWD Black VZ LX8 Adventra Holden HX 50th Anniversary AU Saloon Car racecar 1980 GS1000ST - Wes Cooley Rep
23-08-2023, 06:48 PM | #6 | |||
Regular...with metamusal
i have at least three 3.45 ratio AU diffs here that will fit any AU fitted with a solid diff. |
