06-01-2006, 09:09 PM | #61 | ||
Thanks, maybe I had some misconceptions about forums, if I had more time I'd like to partticipate more. I see they can be a useful medium. Unfortunatly(not in regards to the current thread) my experiences have been varied, I know of forum users who make untrue claims about vehicles. They claim to have worked on vehicles they have not and spend their spare time big noting themselves and bagging everyone else. I don't see the point so have avoided the situation prefering to get on with things in the real world.
07-01-2006, 02:06 AM | #62 | ||
Boost is only option
good stuff....still dosnt explain were the shot peened and linished rods come from nor the oringing,anyhow,the only linishing done to the rods were at the top near the pin so the forged piston has clearance under the crown to not grab the conrod , if you dont do it it dont fit full stop , i no this cause the next set off rods had to be linished to fit , and then balanced , as for the crank if it was to be balanced than when it was compaired to another stock crank well dam me they were both done in the same machine shop.....so good job on the crank GTPFPV
as for the gear box well time was the teller , had it been serviced a bit more it may have not damaged the front drum and b1 band , oil in the gear box and the sludge in the pan that had been in there for a number off kms , sludge had to be scratchs out off auto pan with a screw driver..hmm ant been off for a while no fuss at all casper (NOT), mystery ....now apart from alot off tyre kickers you carnt tell me it never detonated nor the car used bucket loads off oil before me, as for crankcase breathing no engine should breath like this baby was as for the cars only done one track day here and only one drag meet there......ive seen turbocharged cars do half a ramp on a chassie dyno and be damaged and they dont usually fix them selves let along some badlly melted sparklers , ( anyway i come on this forum to find out a gearbox problem i found it and fixed it lets see what the next epersode brings if its a warning to anyone thats buying another persons project/TIME Bomb , think again buy all means check the link out http://cgi.ebay.com.au/Ford-AU-XR6-T...QQcmdZViewItem how convincing is it , i was convinced 3000kms latter i no its a new car HotRod
RAW Performance QLD |
08-01-2006, 12:49 AM | #63 | |||
Life's a Gas
I feel for you, and I can understand you being severely ИИИИed off. But as has been said above, if you buy a heavily modified car, there are obvious risks. I'm not a mechanic, and my following observations may be completely out of order. But just out of interest, did you actually see this car before you bought it? The big ends were clearly rooted, but did you not here them knocking? If it was breathing smoke all over the joint, was that not also evident? Like I say, I'm not a mechanic. But in my experience a stuffed motor usually sounds pretty stuffed. I can see that the tranny would be an unexpected nasty shock. But it seems obvious that FTPFPV's shop is in the clear with all this stuff. They built a 9psi 250rwkw motor, and arranged a transmission to suit. The motor you bought was something different. It is good to see you're getting this sorted, but the lesson that everybody should already have learnt is to check any used car thoroughly before parting with your hard earned $$$. This particularly applies to a modified vehicle, whose components are necessarily tested far beyond the manufacturers recommended application. |
08-01-2006, 11:34 AM | #64 | ||
justa6
It's all very interesting. When my crank and rod's were balanced they did'nt look to out of the ordinary either, just grind marks here and there. my old man alway's say's "if it's meckanical it's bound to break one day" it's just a shame it happened just when you bought it. nevertheless smick car .
08-01-2006, 03:49 PM | #65 | ||
Re. the gearbox; when you rebuilt it, did it have upgraded parts inside, or is the issue your saying was all the internals were stock? Does it still have a dipstick fitted?
Just trying to find out if the box has really been upgraded, but the issue is it hasn't been done well enough or the lack of maintenance has been the issue, or whether the issue is that the upgrade work was never really done. |
08-01-2006, 05:18 PM | #66 | ||
Raybestos bands and clutchs ,and some valve body work eg line pressures raised etc.. upkeep and maintance was the killer , now my bands are from a BA turbo gearbox,which is a different material again,so ill see how it goes
HotRod
10-05-2006, 09:37 PM | #67 | ||
Hi all long time no speek..short note to say new motor in my AU XR6 turbo going well been tuning engine again after 2000kms off run in and made 457Hp at the tyres on 14 psi boost..and gear box is goin great....just come back from power cruise 1 day power play at willowbank on weekend burnt 70 litres off fuel and a set off 19 inch tyres on the track for the day can check some pics at
http://www.qldstreetcar.com/forum/index.php? showtopic=14983&st=0 also at... http://www.toowoombacarforum.com/php...pic.php?t=5277 scroll to bottom you all no the car i would love to add pics to this post but dunno how... also if Any you guys buy the Ignition DVDs new australian dvd magazine it will be on it..i was carrying there camaera around the track cheers Rod RAW Automotive & Performance Dalby QLD
10-05-2006, 09:49 PM | #68 | ||
the first link may not work but go to http://www.qldstreetcar.com/forum/index.php?
go to events and cruising go to powercruise powerplay pictures forum started buy 'BAXR8' enjoy...cause i did Cheers Rod RAW Automotive & Performance Dalby QLD
10-05-2006, 11:18 PM | #69 | ||
Glad to see you back Hotrod, and its great to hear the car is back to its glory.
FG2 XR6T KIA Cerato 2022 Kawasaki Z900
11-05-2006, 04:59 PM | #70 | ||
Good to hear the car is back to how it was, It looks great in the photos!!
Turbo AU ute ~ Nice legs, shame about the face. 282rwkw at 15psi. |
11-05-2006, 05:40 PM | #71 | ||
Nitrous Junkie
I was at powercruise on the weekend and saw that thing in action and i must say its amazing that thing really boogies, beautiful car mate. I don't know if you heard or not but during one of the cruise sessions the bloke announcing called it an XR8 i found that pretty funny.
11-05-2006, 08:06 PM | #72 | ||
hi dan hi 70caprigt3k yes i got told that one off the dudes on the mic said it was a XR8...little does he no...nar had a great day....cheers Rod...those pics were during the straight line burnout
23-10-2006, 03:14 AM | #73 | |||
EB 4L, 8.4:1, GT3540r, Greenslade Engineering exhaust manifold and plenum chamber, 90mm throttle, 600x300x100 cooler, Surecam custom turbo grind, autronic SM4, siemens 72lb, Crane HI-6, LX-92, Innovate LM-1, Turbosmart Street Reg, bosch 044, turbosmart 48mm w/gate and v-port BOV. 335.8rwkw 1bar |
23-10-2006, 03:09 PM | #74 | |||
With da Warlords
You don't have to be faster than the bear, you just have to be faster than the slowest guy running from the bear. For Sale: Parachute. Only used once, never opened, small stain. Windsor Warlords AU III XR-8220 300+ rwhp of Manual fun XR50T Ute - 300rwkw (give or take depending on the day)
23-10-2006, 07:06 PM | #75 | ||
der... i did say i know the thread is old..
BUT, the more info on these forums the better they are
10-10-2007, 07:38 PM | #76 | ||
LOL ...doh.... abit late myself ...glad to here that ebs_4l...i dont change my mains & big end bearings much ether cause i dont need to rev it
buy the way how is ever one...iv been a bit busy for the forums Cheers Rod Raw Automotive & Performance Dalby QLD
22-10-2007, 09:47 PM | #77 | ||
Mr. Multiple Projects
nice looking car you got there. looks like alot of hassels you have had. have you got a full detailed thread on the car?
1985 KB laser Turbo white lightning 3 door EFI 1927 Model T 1998 GU Patrol 2004 Forester Turbo 2006 Corolla Wagon BLAAAAAAACK |
