#61 | |||
Your armchair assessment of a situation you were nowhere near is totally unprofessional. A professional emergency service worker doesn't assess an incident scene unless they are there. Its just ludicrous and usually ends in an incorrect conclusion as it has here. To me this criticism is similar to sensationalist reporting that is prevalent at these times. Things like reporters standing in flood water saying don't go into the water because its dangerous or standing outside in a cyclone warning people not to go outside etc etc etc. In this case usernametaken is assessing your situation from in front of his computer screen. Its just laughable!!! In my case I have had four large trees in my property fall and do lots of damage around the place. Would you like to assess my situation usernametaken from your computer and use your emergency service experience and advise me of what I should have done to prevent this. I have a long professional career as an emergency service officer and would like to apologise to Lisa for the criticism from this other alleged emergency service worker. It is highly unprofessional I think the car will be written off too. I hope you get a nice new one. Cheers Ken
http://www.fordforums.com.au/showthr...sic+xp+cruiser |
5 users like this post: |
#62 | |||
Sick Puppy
Most stupid bit of advice given ever! Yeah you can drive a manual in gear on the starter motor , but an auto no. Besides the fact that they wont even turn over due to the inhibitor switch when in drive or reverse there is no way a starter motor will get a torque convertor spinning fast enough to drive the pump and make a car move. Don't give dumb advice that one day someone might try and follow and end up dead. |
#63 | ||
Sick Puppy
Just because its been in flood water doesn't make it an automatic write off.
Saltwater or brackish water above the sills yes its a write off. Freshwater is 24 hours submerged for an automatic write off. |
#64 | ||
![]() Join Date: Oct 2006
The worse flash flooding I have seen was in Makati Manila in August 1990 during Typhoon season.
I was in a taxi on a city street and in about 10 seconds we had gone from a dry road to where the water was up to the windows. By the time I had climbed out and got to dry ground (dragging the driver along as he was a non-swimmer about half my height so he was real danger of drowning) the taxi was completely submerged and floating away with only the roof showing. And apparently that wasn't even a bad flood year for Manila. The bad part I anticipated flying back to Perth the next day so put the plastic bag with my sewer smelling wet clothes in my suitcase. The floods meant I missed my connecting flight in Singapore (sat in the aircraft for 3 hours waiting for the rest of the passengers who hadn't allowed a six hour delay to get there) and got stranded in Singapore for three days with no dry non-smelly clothes. My missus said in took a month before I stopped smelling like a sewer. At least the smell got me and my adopted son, who I was in Manila to collect, a row of seats to ourselves on the Qantas fight to Perth and rushed through customs..
regards Blue |
#65 | |||
regards Blue Last edited by aussiblue; 26-04-2015 at 07:38 PM. |
#66 | ||
..and in many cases the water will be above and within the inhibitor switch on the side of the transmission shorting it out so you can turn the starter in any position. Something to try when there are no other alternatives and leaving the car isn't an option. But it seems after mid 80's car it won't work unless that has happened.
regards Blue Last edited by aussiblue; 26-04-2015 at 08:25 PM. |
#67 | ||
Sick Puppy
What a load of crap.
#68 | ||
OK I may have to admit I was wrong (not the first or last time - just ask the missus). Checking the factory workshop manual for the CM Valiant which I still have (the manual not the car) it seems that even it shouldn't have let me start in D even with the key in left in run when it stalls. But it did; so all I can think is that I had a faulty neutral start switch and it does seem these switch were no more reliable than out Ford ones.
What we really need is someone with an old Val to test it on (some how stall the engine and see if it restarts in D when key is left in Run position) though I have a vague recollection of recalls related to Valiant ignition locks but I think that was about being able to lock the wheel with the steering lock while driving. I tested the two Fairlanes and they won't start in drive even if stalled with key in run and not turned back. run position.
regards Blue |
#69 | ||
There were automatic gearboxes that you could push start the car with like clutch starting so its not actually a load of crap. It may be a bit out dated now though in most situations.
#70 | ||
Yes; it was also in the era of low compression motors and 2 and 3 speed automatics.
Nice to know it just that I'm just old and stupid not totally wrong :-)
regards Blue |
#71 | ||
The Humber Super snipe had a rear pump in the tranny which allowed it to be pushed started ( I think ), but there is no chance of moving an auto transmission car from the starter.
#72 | |||
Former BTIKD
![]() Join Date: Mar 2005
2 users like this post: |
#73 | |||
Here's the link to it...... I sent you a message also http://mobile.kinghorn.com.au/view.p...Sedan/9489751/ . Last edited by chrisandsharon; 27-04-2015 at 05:08 PM. |
#74 | ||
Here's the nitro blue one.......50th anniversary one too......same owners.
http://mobile.kinghorn.com.au/view.p..._Sedan/9489797 |
