#8671 | ||
Call me 'Al'
Location: On a flattened-out cardboard box out the back behind the wheelie bins.
#8672 | |||
#8673 | ||
#8674 | |||
Petro-sexual
Surely that covers any tyre size/brand/quality issues. I guess what I'm saying here is that the tyres probably do not pose as big of an issue with DSC as it is coming across. Weight wouldn't even play a huge part as it is variable between 'skinny driver only' to '4 fat passengers and a boot full of camping gear'. |
#8675 | |||
![]() Join Date: Jan 2005
He must of read that on the internet, because he's wrong ! |
2 users like this post: |
#8676 | ||
Regulator
Salesmen (and most dealerships) have little clue about the running of Ford and their cars.
Even now, some dealers don't know that cruise control can be enabled via WDS. Hopefully the yank Fords sell poorly and these poor-performing dealers close quickly!
Regards Bobby Current Cars: 2000 AU2 Fairmont (2019-current) 2003 BA1 Falcon Divvy Van (2017-current) 2009 VW Mk6 Golf 118TSi (2020-current) Previous Cars: 2003 MCX10R Avalon VXi (2017-2020) 1995 EF1 Falcon GLi (2016-2019) 1997 XH2 Falcon Van OPT20 (2016-2019) 2006 BF Fairlane Ghia (2013-2018) 2001 AU3 Futura (2010-2013) 1996 EL Fairmont (2008-2010) 2004 BA XR6 (2005-2008) 2001 AU2 Forte (2005-2006) 1988 EA Fairmont Ghia (2003-2005) 1984 AR Telstar TX5 Ghia (2001-2005) |
#8677 | ||
AKA "the other bloke"
Hmmm so I wonder where the nsw r spec is off too?
Her's: 2000 AU II Fairmont Ghia 75th anniversary VCT meteorite & 2014 yaris - white His Toy: 2012 fg II GT-E, emperor red His: VS Ute 5 Litre 5 speed (povo pack) His: 2012 FG II GS, Vanish His: 2003 BA GT-P, Lightening Strike Jnr: 2002 AU III Falcon XR6 ST, 5 speed Blueprint & 1978 XC Fairmont Neptune Blue Previous: 1976 HX 50th Anniversary Kingswood 2014 FGX G6E Turbo 1980 XD Falcon GL 2003 BA Falcon XR6 1991 EB Falcon S 1989 EA Fairmont 1982 XE Fairmont 1968 XT Falcon |
#8678 | |||
Workshop & Performance
Alpine 7909 30th/Alpine 5959/Audison Bitone.1/DLS Ultimate A6+A7/ Focal KRX2/Morel Ultimo 12/AudioEngine B1 A stereo that happens to have a XR5 wrapped around it |
#8679 | ||
#8680 | ||
FPV GTR
NSW RSpec was number 150 to celebrate the 150th anniversary, then tuned to 400rwkw. Off to the museum though.
Amusing that they have used someone else to tinker with the new GT. I look forward to to seeing what DJR do with it.
- FPV GT RSpec - - Chill SZ Territory Titanium -
The Family Bus - Veridian Green PJ Ranger XLT - The Work Truck |
#8681 | ||
#neuteredlyfe
![]() ![]() Join Date: Apr 2012
#8682 | ||
#8683 | ||||
Peter Car
DSC has to be recalibrated for different tyre sizes, and suspension changes. And it doesn't come cheap. R spec has it's own DSC calibration. Quote:
#8684 | ||||
FAWD - No Boundaries
![]() Join Date: Jun 2010
Mathematical equations are calculated by the ABS/TCS/DSC computer based on known parameters which have been programmed in. Should one of those parameters be physically altered (say.. tyre size)... but not in the computer... then the calculations the computer is making won't match the inputs it's receiving... and it will either not act as well as it should.. or shut down until someone tells it what's going on ! So.. If the overall diameter of the tyre has changed (outside of the "known" normal tyre wear parameters programmed in)... then the actual wheel speed, at a given trans output shaft speed, will not match what the computer is expecting to see. Same goes for tyre wall height. For example... a car with say 65 series tyres, will corner differently to a car with 35 series tyres... if the YRS inputs have been programmed in to recognise the amount of Yaw from a 35 series tyre when the car is cornering at "this" speed with "that much" steering angle... and then you go and fit 65 series tyres (same OD for the sake of the eg ![]() You can resolve some of the issues by changing the parameters in the computer. (ie: change your wheel/tyres on the car... also change the settings in the computer to match). This will then allow the computer to make the correct calculations etc. I admit.. these are just a couple of very basic explanations... but I hope it helps you to get your head around it a bit !?? The DSC programming is very complex... and highly skilled Engineers spend many hours writing the programming and then testing to fine tune everything ! Yes they make allowances for things like weight etc... but the computer cant measure the actual weight perse'.... the system can only be programmed to recognise the variance in say Yaw (weight shift) when the car is cornering with one person, empty... or 5 people, fully laden (amongst other things) So tyre size is only one thing amongst many things it takes into account.... as it is constantly monitoring all inputs against all "known" parameters, many many times per second. Make a physical change that stays within all of those parameters... the system should be ok. Make a physical change that can/does step outside them... the system won't be able to calculate for it. Match that physical change by altering the set parameters in the computer also... theoretically, it will work again as it should. Can that be done easily ?? Some things can (they may already be allowed for)... others need the highly skilled Engineers spending many hours writing the programming etc. Hope this made some sense !!?? Dhru
View My Build thread 22 DJR Shell V-Power Mustang Eskymobile (my first EV) 07 BF2 AWD Falcon Wagon (Daily driver) 04 BA Falcon 1Tonner Ute (New Project) 03 BA Falcon Wagon (Spare) 98 NL Fairlane Ghia V8 (Weekend cruiser) 70 VG paddock racer (Cain it til it breaks.. fix it.. Cain it all over again !)
5 users like this post: |
#8685 | ||
If its limited production, and retail demand is high (as I would expect), it would make little business sense to be selling them at a significant discount. I'd be surprised if many of them find their way to HWP.
#8686 | |||
#8687 | |||
DSC can't see if the road is cold or wet etc... it relies on how the car acts, based purely on the calculations from all the input readings matching what is programmed into it. A very simple eg: wheel speed of "this" + steering angle of "that", should = a yaw rate of "this"... Do all these things calculate to match what It's been told to look for? (what's programmed in)... if ans. = "Yep!" and it won't intervene. However if ans. = "Nup!" it will intervene... and if that doesn't work to bring things back to what it knows... it will assume there is a problem with something in the system... and shut down, bringing all the lights up on the dash to let you know it needs something repaired. It's so....o much more complex than this tho... it's a highly sophisticated system ! The Dude's that develop systems like this are Scientists IMPO... and should be applauded for what they do ! D
3 users like this post: |
#8688 | |||
There are also Strategic Marketing Benefits for Ford with a HWP XR8. As incompetent and disconnected as Ford Marketing have been, even they could not fail to recognise the powerful marketing benefits gained by garnering solid Street Credibility from having the XR8 as the HWP "vehicle of choice". |
#8689 | ||
The difference between then and now is Ford are bleeding cash on this car, and with only a relatively short time in the market before its gone forever, there's little to be gained from the exposure. Ultimately, I'm assuming this model will be walking out of showrooms at close to RRP with little/no work by the dealer. Seriously, when was the last time Ford (not FPV/Tickford/etc) made a car this desirable?
#8690 | ||
![]() Join Date: May 2008
[QUOTE=stevefreestyle;5204188]As has been previously stated, XR8s from the AUII 220 have always been limited production ie limited (hand made) production engines in the same way the current 335 is builtQUOTE]
The 335 would be significantly more expensive because of the added componentry (DOHC heads, 32 valves, VCT, that whopping supercharger) compared to the simple OHV Windsor.
PX MK II Ranger FG XR6 FG X XR8 Mustang GT T3 TS50 - gone but not forgotten |
#8691 | |||
[QUOTE=DFB FGXR6;5204350]
#8693 | ||
Pity the fool
National fleet discount and no GST, no luxury car tax either so it might not be too far over the fence for them.
Fords I own or have owned: 1970 XW Falcon GT replica ![]() Proud to buy Australian and support Ford Australia through thick and thin |
#8694 | ||
Put it this way, do the Police use SSV or SSV Redlines for their duties? No they use base spec SS.
FGX XR8 will be SSV Redline price, a premium model with supply constraints that will sell fine all by itself without what some are calling endorsement from the same people who will sting you with a fine for doing 2kph over the limit. Do Ford want that sort of advertising?
#8695 | ||
Guys who want an xr8
From what ive heard id place your order now, numbers being built are so limited, you may miss out. I'm hearing an average allocation of 1 per dealer per month. Future Demand is being ignored, supply of parts for 8s is being predetermined and will not be changed if demand grows. Don't hate on me if you disagree, I dont profess to know and i could be wrong. my source is in the know and I'm only writing this to help fence sitters who may hold out for a LE version or a later build. Would hate fellow forum members to miss out
A lifetime of fast Falcons has made me a happy man |
#8696 | ||
Regulator
Why do/did they use F6 models then in NSW & QLD?
#8697 | ||
Member
They were/are some sort of specialised hoon squad as far as I know, most of them unmarked. I always thought they were a waste, XR6Ts with Brembos (in NSW) are essentially the same thing. I remember one time in Kings Cross, they lined 4 F6s up at an RMS inspection station, then when they left each of them got sideways pulling out and belted up the road. Pretty ironic.
#8698 | ||
I doubt whether there would be any 'bargaining' or discounts on price for any XR8's , even to corporate buyers. Sure there will be some haggling on the other models but the XR8's will all sell at full RRP. Order now or miss out would be my guess.
Fords I own or have owned: XW UTE, XW FAIRMONT, XT GT, XT Fairmont, EF XR8, XH XR8 UTE, XH XR8 UTE, AU UTE, Renault Scenic, XF UTE, BA XR8 UTE, TERRITORY, Chrysler Voyager, WS FIESTA ZETEC,TERRITORY TITANIUM, BA UTE, Nissan Pathfinder, AU Falcon Forte, BA XR8 UTE. |
#8699 | ||
They'll be built to order too I imagine.
#8700 | ||
cross breeder
Someone mentioned a few pages back that zf still list the high torque 6 speed, could this be (heaven forbid) good marketing by ford?
Spread the rumour that there are limited numbers of parts (or simply dont deny anything) and let the hype build.
Like xk-xf's?
http://www.ozfalcon.com.au/ |
