#31 | ||
it was quite a while ago when i had mine off , but i don`t remember it being anything other than a push on fitting.
#32 | ||
Thanks Mik your correct it's a push on and carefully prize off
![]() Better to be safe than sorry, my BA XR6 had little tabs to be squeezed as they're removed. The Millennium Fairlane now has a Momo wood grain steering wheel ![]() ![]() ![]() |
#33 | ||
yeah it does`nt hurt to be a bit cautious, i must confess i was a bit nervous mucking around with the air bags, i had it in the back of my mind static electricity could set them off........kept grounding myself every couple of minutes
#34 | ||
XR6T BA 2002
XR6T 2002 BA
#35 | ||
The yellow plug for airbag just pulls off and pushes back on. The red connector has tangs to depress. I believe the Momo options have 5 sided tamper torx T30 and the standard wheels may use the 6 sided. Regardless, Kincrome do a full set of 6 sided Torx and Tamper Torx for under $40 and the 9 piece 5 sided Tamper Torx set is under $30 delivered from ebay. Total of $70 and there is so many uses for them besides the amount of Torx heads used on E and AU series cars. There are also steering wheel pullers for those who's wheel's are really hard to budge and don't want to trash the wheel by twisting it to loosen. With the cost and rarity of Momo wheels, I was happy to buy the correct tools and do it myself with clean hands and plenty of time to stay calm and do it properly.
