06-10-2005, 08:14 AM | #31 | ||
Thats weird, I have no doubt in my mind that mine is getting off the line to 100 considerably quicker. Theres been a few people in my car who have said exactly the same thing.
Bring on Heathcote, all will be clear then when I see the 1/8th times. That will tell the tale of 0-100 in my car for sure.
06-10-2005, 09:37 AM | #32 | ||
My guess, is that you'd need some traction. Get a set of 2nd hand 17" rims, with some sticky 235 rubber. And you should be able to put more power to the ground. Is the stall making you smoke em up or...?
AUIII Falcon Forte, with SIX Appeal |
06-10-2005, 05:28 PM | #33 | |||
1965 XP Falcon Deluxe Sedan 1978 XC Falcon Wagon Rallypack 2003 BA Fairlane G220 Windsor Powah!!! http://www.youtube.com/watch?v=m7hT9dxD2hM |
06-10-2005, 06:00 PM | #34 | |||
Back on the road
The GTech may not lie, but it's not telling the full story either...lol Have a little faith, I reckon you'll do pretty well at WSID on the 5th Nov ;)
------------------------------------------------------------------------- AU XR8 Ute 13.90 @ 100mph - http://www.aufalcon.com/xr8ute 5L Windsor, GT40X heads, Crane 2030, Pacey 4-1s, Lukey 3", 3.91:1, auto. Tuned by me w/Quarterhorse and BinaryEditor. Coming Soon: Ported lower intake, Tickford "Premium" Brakes, and a good wash. |
06-10-2005, 07:39 PM | #35 | |||
Smile
I have faith.
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again |
06-10-2005, 08:14 PM | #36 | ||
XB in parts...
If you have the money get some dumpies. Don't kill your road tyres (or just avoid burn outs on the day).
06-10-2005, 08:51 PM | #37 | ||
good advice, nothing better then having tyres that are meant to be sacrificed to the gods of the track.. makes for a VERY fun day.
06-10-2005, 10:38 PM | #38 | |||
Smile
06-10-2005, 10:44 PM | #39 | ||
Well, not sure what your doing Stav but unless I want to my tyres have no grip issues on launch. I have fiddled a bit with pressures and different launch styles (yes, even an auto has different options) and can get it off the line very quickly with little more than a chirp if anything at all.
Get an LSD, I'm sure it will make the world of difference. Hell, I'm considering shorter diff gears now as the launch is still not as hard as it could be and theres plenty of grip left to handle it.
07-10-2005, 02:53 PM | #40 | ||
Casper, how much did you pay for your 3.45 & LSD? Just so I know where I stand when I go shopping.
Stock AU2 EECV is 3.7 yeah? |
07-10-2005, 03:25 PM | #41 | ||
Last warning
caspers car had a 3.45LSD standard.
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer |
07-10-2005, 03:37 PM | #42 | |||
07-10-2005, 05:10 PM | #43 | ||
$1300 max should get you a lsd center and what ever diff gears you want fitted .
i had a lsd and 3.45 gears fitted to our au a few months ago and it cost around $1200 |
07-10-2005, 11:01 PM | #44 | |||
08-10-2005, 12:02 AM | #45 | ||
i might sound dumb.. but what is a hi stall converter and what does it actually do...can there be any downfalls from installing one?
01 AUII XLS Regency Red Ute 4.0L Egas Auto Mods -transcooler, tickford intake, K&N pod filter, Pacemakers, 2.5 inch exhaust, Crow Cam, 1981 XD Fairmont 351 - 351 Cleveland, ARP bolts, flat top pistons, Stage 3 Dynotec cam, ported 2V heads with 4V valves, Roller Rockers, Weiand manifold, Mighty Demon, 1/2" fuel lines with blue Holley fuel pump, Crane hi-6 ignition, B&M megashifter, C4, hi-stall, shift kit, 3.77 Ford 9" LSD. Thanks to: EvilChief and SJW Performance |
08-10-2005, 08:15 AM | #46 | ||
Smile
An automatic transmision is coupled to the crankshaft via the flywheel.When you take off the revs go to about 2000 rpm and the car gets off the line.The stall/torque converter is the device which locks the power to back wheels.
A high stall converter will get you off the line quicker by allowing the revs to go higher before lockup and get more power out. The downside is that fuel economy gets very bad .Going up a hill the car revs much higher.You risk wrecking the transmission because of the excess heat. When you drive the car at 60 kmph you lose the acceleration you had with the standard converter.At 60 I press it to move and it just keeps revving until it hits 2700 rpm and feels doughy.At medium throttle its a different story it takes off harder then feels quite uninspiring because the gears change and must go through the rev range to keep the car going. You have to sum up if having an unresponsive car on the street that uses alot of fuel at normal driving and alot more at freeway speeds is worth it. Couple that with the fact that you need a cooler due to the fact that there is so much slippage from converter cooking the transmission oil. Other guys here get limp home mode from their converters after stalling it up 2 to 3 times.I have been lucky with that.I have no cooler connected yet and do as many stalls as I want have no issues at all. I was incredibly lucky.I know that the more efficient a converter is that it produces less heat.If this is the case with mine then it is working well.A big cooler cannot make up for the innefficiency of a coverter and the resulting heat. I have always tried to be honest in my observations and been shot down a few times but dont give a crap.This is how a stall coverter is.Personally as a ford forums friend get some diff gears first...like 3.7's ..stallie is more a drags orientated mod
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again Last edited by Stav; 08-10-2005 at 08:23 AM. |
08-10-2005, 03:52 PM | #47 | ||
Irregular member
So is the term "lockup" the point at which the shaft to the wheels starts turning from the force of the engine? So the more turning force happening before it locks up, the harder it's going to drive the wheels / accellerate the car when it begins? I guess this is why you have to get the revs higher for it to move like it did before the new one. I hope I'm right?
How does a torque convertor work when reversing the car?
2000 AU II FAIRLANE 75th ANNIVERSARY - big and shiny My hovercraft is full of eels! Movie Car Chase of the Week: Gene Hackman driving a 1971 Pontiac LeMans to chase an elevated train in The French Connection (1971). |
08-10-2005, 03:57 PM | #48 | ||
Irregular member
I wonder if one day you could get a torque convertor that has something like rigid yet variable / selectable vane angles and separation for extra economy or performance modes.
08-10-2005, 05:12 PM | #49 | |||
Smile
08-10-2005, 06:08 PM | #50 | |||
Back on the road
Yep converter works in reverse as well. It's a hydraulic coupling (and the only coupling) between the engine and gearbox, so there is no drive to the rear wheels without it.
08-10-2005, 06:13 PM | #51 | |||
Back on the road
08-10-2005, 06:18 PM | #52 | ||
Irregular member
Useless, I thought that the thing was purely a mechanical fluid drive and reacts to power / torque only. Are you saying that someone can hack the AU to change it to react like a hi-stall one?
XR8Ute, I'm just a bit lost as to how the blades inside the unit can pickup movement going the other way when they are angled in one direction. I think I don't properly understand it - back to school for me.
08-10-2005, 06:23 PM | #53 | ||
Back on the road
The engine, and transmission input shaft (and hence Torque Converter) still turn in the same direction. It's in the middle of the gearbox that things get turned around for Reverse gear...
08-10-2005, 06:29 PM | #54 | ||
Irregular member
Of course, I didn't think to check that little fact - it's before the gearbox.
08-10-2005, 06:35 PM | #55 | |||
08-10-2005, 06:40 PM | #56 | ||
TL40 Wagon?
The transmission solenoids are electronicly controlled by the ecu but the toque converter isn't so other than changing the lock up point there is not much you can do to it.
08-10-2005, 07:04 PM | #57 | ||
Smile
Well my theory in my mind was that the lockup will only occur when line pressure has increased enough for lock up to occur. Low line pressure may allow higher stall speed.How right I am I am not sure.I do know that some research on my side has led me to some interesting theories further on the electronic 4 speed.I will test them on 5 thnovember.If my new mini circuits do not work then there is no need to tell anyone.
08-10-2005, 07:30 PM | #58 | ||
Back on the road
Torque converter lockup is completely electronic (turned on/off by solenoid), and is unaffected by line pressure. Line pressure is hydraulic pressure inside the gearbox, not the converter.
Also, be careful not to confuse the torque converter lockup feature with converter stall, they are two totally different things.
08-10-2005, 07:35 PM | #59 | |||
08-10-2005, 07:43 PM | #60 | ||
Irregular member
I was a little confused by the terms "lockup" and "stall" but now I understand.
Stall occurs when the fluid drive system starts to turn the wheels using the turbine / impellers. Lockup is when the wheels are turning enough (after stall occurs) that it can lockup a clutch to finish with the fluid system and directly connect the engine to the wheels like a manual. Then it goes back into fluid drive mode when coming back to a stop or slow speeds.
