Old 03-10-2005, 11:26 PM   #31
The MaDDeSTMaN
No longer driving a Ford.
The MaDDeSTMaN's Avatar
Originally Posted by blitzmile
thanks the maddestman. wish me luck, im going to go and pick up the engine this week. and then the fun begins! :
No probs, you shouldn't really need any luck, they're pretty simple engines and can go suprisingly well with the right mods!
Have fun, and take plenty of pictures to share with us all if you can
Originally Posted by russellw
For those who get their jollies attacking other people let me remind you that we will not tolerate this here. If you want to do that then I am sure your presence would be welcomed elsewhere.
The MaDDeSTMaN is offline   Reply With Quote Multi-Quote with this Post
Old 28-10-2005, 03:38 PM   #32
blitzmile
im pleased to say i got my engine on tuesday. its a 2L pinto from a 1973 cortina. ive already started to take it apart. having heaps of trouble though with three of the spline bolts that screw into the head, they wont budge.
blitzmile is offline   Reply With Quote Multi-Quote with this Post
Old 28-10-2005, 08:28 PM   #33
rag top
rag top's Avatar
What are you using to undo the bolts? Have you got the propper splined socket thingo or are you relying on allen keys??
Current Rides:
2000 AU 5L XLS ute; 1970 Mustang project
rag top is offline   Reply With Quote Multi-Quote with this Post
Old 28-10-2005, 09:48 PM   #34
blitzmile
nah im using the correct spline socket bit. ive been using an air drill as well and still no luck. ive tried all different methods but it wont budge. i tried using a socket wrench and attaching a pipe onto the end to turn it (was told it should give more strength behind it). well did it! resulted in a broken wrench. i dont know what to do besides taking it to a mechanic-what a pain in the ****!
Old 29-10-2005, 09:02 AM   #35
rag top
rag top's Avatar
What brand tools are you using?
Current Rides:
Old 29-10-2005, 10:40 PM   #36
blitzmile
not sure what brand the air drill is. ill check tomorrow. only cost me 85 bucks. however i did manage to remove all the other bolts with it, besides these three that are still stuck. i even hired an industrial air drill and that didnt help either.
Old 02-11-2005, 10:38 PM   #37
blitzmile
ok bolts are out and engine is totally dismantled. i finally got those fu%$#n bolts out! just required a small sledgehammer and iron rod and some heavy belting :evil3: . even though i was hoping for everything to be perfect on the engine, i didnt expect it. once i got the head off cylinder 2 had all built up, looked like mud. only explanation is if there was some water jacket leak somehow (i couldnt see any cracks though). ill try to post up some pics of it in its current state.
Old 03-11-2005, 07:09 AM   #38
banarcus
hmm eyebrows
banarcus's Avatar
Originally Posted by The MaDDeSTMaN
The bible when it comes to modding a pinto is a book called "How to modify Fords 2.0L OHC Engine by David Vizard" or something like that, I've got it somewhere. If you can get your hands on this book, although it's a little dated now, it's well worth getting.
Yes I can vouch for that book. In the end my esky was dynoed at 127hp at the rears. I ported the heads myself, I tried the apple port setup without the play dough inside, burtons vernier cam wheel, dave vizard valves etc
1999 Range Rover 4.6 V8. Soon to have a new blue oval bent eight.
banarcus is offline   Reply With Quote Multi-Quote with this Post
