06-01-2020, 07:14 PM | #31 | ||
The green water pump o-ring from the heater hose?
06-01-2020, 07:40 PM | #32 | ||
Ford screwed the Falcon
Gear at the bottom of the distributor. Still carried over once they got rid of the dizzy. I used to know the part number.
Falcon: 1960 - 2016 My cars Current ride 2016 FG X XR6 - 6 speed manual Previous rides 2009 FG XR6 - 6 speed auto 2006 BF MkII XT ESP - 6 speed auto 2003 BA XT V8 - 5 speed manual 1999 AU Forte - 5 speed manual 1997 EL Fairmont - 4 speed auto 1990 EAII Fairmont Ghia - 4 speed auto |
06-01-2020, 09:34 PM | #33 | ||
Drive'n Cruise'n Live'n
Sway bar bushes, used from earliest falcons to at least AU3 and beyond if utes and wagons had rear bars.Cheers
06-01-2020, 09:52 PM | #34 | ||
and I am glad no one has said anything about rust.
2004 Mercury Silver Falcon XR6T - 5 Speed 2017 Platinum White Mustang GT - 6 Speed 2022 Blue Thai-Special for Daily Duties - Auto |
2 users like this post: |
06-01-2020, 11:04 PM | #35 | ||
Might be interchangeable, but they wouldn't be the exact same part - valving would have changed throughout the years.
06-01-2020, 11:06 PM | #36 | ||
Child anchor point was the same from EB2 to Fgx, the colours changed a few times though.
06-01-2020, 11:16 PM | #37 | ||
FAWD - No Boundaries
Twin filament stop/tail light globe
D (edit) Oops... just saw that this ws mentioned before )
View My Build thread 22 DJR Shell V-Power Mustang Eskymobile (my first EV) 07 BF2 AWD Falcon Wagon (Daily driver) 04 BA Falcon 1Tonner Ute (New Project) 03 BA Falcon Wagon (Spare) 98 NL Fairlane Ghia V8 (Weekend cruiser) 70 VG paddock racer (Cain it til it breaks.. fix it.. Cain it all over again !)
06-01-2020, 11:33 PM | #38 | ||
Yeah it's definitely the oil filter. I had a spare I could use on the AU engine I dropped in my ED. I got a shock trying to change the one on the Soarer, you have to twist your arm in two directions to take that bastard off!
Had: ED Fairmont AU engine 5 speed exhaust extractors, 17" mags, miss the old girl.... Have: 1JZ Soarer dump pipe, exhaust, coilovers , 17" mags |
07-01-2020, 08:55 AM | #39 | |||
The AFL1/Z9 doesn't fit the BA/BF/FG V8s or 6-cyls in BF/FG. Dr Terry |
07-01-2020, 11:21 AM | #40 | ||
Conrod bearings, from start to finish and US models too.
The Silver Bullet - BJ74 Where the actions at Ontrack 4wd Club https://www.facebook.com/ontrack4wdclub |
07-01-2020, 11:42 AM | #42 | ||
But isn't that 6-cyl only ??
I thought we meant all Falcons, but if we are talking longevity only, then the conrod bearing would win. Has anybody checked to see if the FGX has the same festoon dome light globe as the earliest? If it has that would win. Dr Terry Last edited by Dr Terry; 07-01-2020 at 11:58 AM. |
07-01-2020, 11:45 AM | #43 | ||
07-01-2020, 12:14 PM | #44 | ||
I believe that the front crankshaft seal is the same in every six. (I tried to buy one for my XM two years ago but none in stock, but he had one for a BA, it looked the same, it fitted and it worked.
The early starters are too big to fit in later models past XF however the smaller starters from later models will fit any six. If you fit a late model starter to an XD or earlier you must use a relay and extra wiring to bypass the ballast resistor when the starter is operating
Don't try and teach a pig to sing, it just wastes your time and annoys the pig.
07-01-2020, 12:39 PM | #45 | ||
Ciggie lighter/installation
07-01-2020, 01:19 PM | #47 | ||
what bout the steering knuckle that connects the column shaft to the box ??
yes still (as money n time permit) doing the rebuilding the zh fairlane with a clevo 400m 4v heads injected whipple blown with aode 4 speed trans to a 9" ....... we'll get there eventually just remember don't be afraid to try something new. Remember, amateurs built the Ark...Professionals built the Titanic! I have taken up meditation... at least it's better than sitting around doing nothing !! |
07-01-2020, 01:36 PM | #48 | ||
The earliest (prior to XW) steering boxes had a shaft integrated with the input worm.
Re the dome lamps, I remember my XP hardtop had a bayonet fitting of the BA15S type. I used the wrong wattage (too high) and caused a little grief to things. Can’t remember if the XM wagon was festoon or bayonet, the XR definitely was festoon though. |
07-01-2020, 03:15 PM | #49 | ||||
Peter Car
07-01-2020, 04:22 PM | #50 | ||
The distributor gear changed sizes (ID) around time of the crossflow’s introduction. I only remember this because Crow offered both fittings.
07-01-2020, 06:21 PM | #51 | ||
Cabover nut
Weren't the barn doors on the panel vans the same from XA to XH ??
Funny how angular the XD-XH are but have nice curved rear doors.
07-01-2020, 06:23 PM | #52 | ||
XK-XPs used a 5W globe with a 15mm diameter bayonet fitting, not the same as FGX
07-01-2020, 06:27 PM | #53 | ||
Wheel nuts?
Fords I own or have owned: XW UTE, XW FAIRMONT, XT GT, XT Fairmont, EF XR8, XH XR8 UTE, XH XR8 UTE, AU UTE, Renault Scenic, XF UTE, BA XR8 UTE, TERRITORY, Chrysler Voyager, WS FIESTA ZETEC,TERRITORY TITANIUM, BA UTE, Nissan Pathfinder, AU Falcon Forte, BA XR8 UTE. |
07-01-2020, 07:12 PM | #54 | ||
The name..??
07-01-2020, 07:31 PM | #55 | ||
i owned xe , ef , ea , ef, ba. pretty
oh, and the ford falcon stud pattern. Last edited by Raptor; 07-01-2020 at 08:00 PM. Reason: Spelling |
07-01-2020, 07:57 PM | #56 | ||
Changed to Ford AFL101 or Ryco Z516. FG & FGX
07-01-2020, 08:01 PM | #58 | ||
07-01-2020, 08:06 PM | #59 | ||
lance
Definitely not true. I owned an xp and the front crossmember was no the same as an xy or xb.
1971 XY GTHO replica electric blue 4spd black trim Sold 1984 XE Esp Fairmont Ghia 6cyl Sold 1984 Xe Fairmont Ghia 6cyl Efi Sold 1966 Xp deluxe sedan Sold Mk2 escort sedan 1600 Sold Mk3 cortina 2 litre Sold 1975 Xb Falcon 500 250/ column auto 94000 kms Current |
07-01-2020, 08:09 PM | #60 | ||
lance
The interior light from xr up until xg?
