12-09-2011, 07:37 AM | #31 | |||
12-09-2011, 09:30 AM | #32 | ||
I think its safe to say that Holden have their own problems as well, but I wouldn't go as far to say more so then the Falcon. You only need to look around this forum to see that, but naturally on a Ford forum there will also be more problems reported with Fords, because thats what the majority of members drive.
This thread doesn't need to turn into a Holden has more problems then Ford etc battle.
BF 06 FALCON XR6 |
12-09-2011, 12:06 PM | #33 | |||
My ride: 2007 Falcon Ute BF XR8 Orange, MTO. |
12-09-2011, 12:26 PM | #34 | ||
OzEcruisers PRESIDENT
Prob not a hush up
Just not lil sookies that whinge about everything on their Ford and think EVERYTHING should be covered by a Ford warranty!!!!!!!!!!!!!!!!!!!!! Waiting for a thread with some one complaining after 12 months that their Ford's Tyres has lost Tyre Pressure!!
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan PROEF 13.46 @ 105.78mph Tuned by DYNOMOTIVE 200BUX - AFF Drag Nats 2019 EF Wagon
Last edited by wulos; 24-09-2011 at 11:03 AM. Reason: Removed inappropriate content. |
12-09-2011, 12:43 PM | #35 | ||
Flairs - Truckers Delight
as mentioned, this has been an issue with a number of alloytec motors since they were introduced over 7 years ago.
13-09-2011, 04:14 PM | #36 | ||
my dads ve s1 died after 50000k
13-09-2011, 04:14 PM | #37 | ||
08 model
24-09-2011, 10:05 AM | #38 | |||
[SIGPIC][/SIGPIC]
24-09-2011, 10:43 AM | #39 | ||
BUILT FORD TUFF
Just had a look on Street commodores forums and there are plenty on there with timing chain issues, between $2500 to $4000 depending on how bad it is. Never seen ford 6's with timing chain issues until they have done over 200,000km and usually closer to 300,000 unless they have been thrashed to death. EA on use to use double row timing chain which was nice and strong. I see that the BA on has gone back to single row which is the same as the V6 commodore uses but the Falcons is a wider section single row
2015 FGX XR6 Turbo |
24-09-2011, 11:31 AM | #40 | ||
Cobblers!
The Alloytec engine was Holden's first attempt with OHC V6 engines. Let's not forget that the Buick Boat Anchor was OHV, with no need for camshaft chains or belts.
Ford had to learn this the same way Holden did in the late 80's, when the 250 X-Flow went OHC, however they over engineered that part of the engine, as has been said, with two Camshaft Chains, which acted as redundancy if one failed. It is just a shame they didn't spend the same amount of time engineering the Head Gasket material... I'm quietly impressed with the Di engine of Holden, however for long term reliability, the I6 beats it hands down. I will be interested to see how the Duratec engine goes after 2015.
Ego BFII Ghia Titanium Silver E53 X5 4.4i Gunmetal EF XR6. Now retired from active duty. Roses are red. Violets are blue. OS X rocks. Homage to you. |
24-09-2011, 11:44 AM | #41 | ||
We did the chains on an VE a few months back, it is common but only happens in a small percentage of vehicles are is normally associated with, but not entirely to, oil not being changed regularly.
We've also seen a captive that broke several rocker arms and lifters, which apparantly in also not uncommon. Fords do not get off the list either, We have seen quite several Ford BA/BF/FG's with timing chain/guide issues, got one in the shop at the momment 50k FG that's jumped a tooth on both cams due to a broken guide.
24-09-2011, 12:05 PM | #42 | |||
Right out sideways
2010 FG XR50 Turbo | 2007 FPV BFII GT, BOSS 302 |
24-09-2011, 12:13 PM | #43 | |||
Workshop & Performance
When close is good enough and the 6 MPS in the driveway has FoMoCo written all over the place. Xr5 for sale shortly...just not a hatch guy |
24-09-2011, 05:19 PM | #44 | ||
building the xe...
everything has issues, when i was at nissan/vw dealership there was A LOT of vws coming through with major issues, nissans had their fair share too like the pajero TD30 needing major motor repairs/replacements, so much so that they stopped supplying long motors and started sending rebuild kits only... even for full warranty jobs...
then there was the 350z manuals jumping out of gear and shocking whine, the pulsar cam/crank sensor recall, just to mention a few lol
slowly but surely fixing up the king of the road WANTED P5 ltd/landau taillight centre panel |
24-09-2011, 05:27 PM | #45 | ||
You have to remember also that be it Ford, Holden, or Toyota, you are dealing with a mass produced high numbers engine, not a hand built one-at-a-time masterpiece like a Ferrari engine...of course there's going to be bad ones and good ones. I recall guys many years back going through blocks and cranks and cams trying to measure up journals and bearings surfaces ti find the best combination with as close to "perfect" clearances they could find from factory engines.
They'll be good, but not every engine will possibly be perfect... |
24-09-2011, 05:58 PM | #46 | |||
My sister had the same issue on her Captiva - the V6 in that is from the same family of engines as the bigger motor in the VE. Apparently a special tool is required and she was quoted $2500 by the dealer but got it done for $2100 by her mechanic who took a tool with him when he went to work for himself.
It's expected a timing chain should last 10 years plus on average - even the life of the engine, so it is a bit rich to then slug people $2000 plus for a design flaw so early in the vehicle's life.
24-09-2011, 06:31 PM | #47 | ||
the issues with the alloytec timing chain appeared when holden changed the size of the chain from 9mm to 7.6mm(i think thats right). seen numerous of them. come up with performance codes for either bank 1 or 2. holden stick a camera down there and look at the ratchet for the chain tensioners and count how many teeth the ratches is out. then they can work out how streached it is.
they also have a wonderful design of thermostat. at the back of the motor so the gearbox has to come out to replace it. i personally have seen heaps of holden vz, ve and the crewman and ute variants with major problems when they come in for their first out of warranty service. the holden boys were just clearing engine lights and topping up the coolant and not looking for the problems. dont know it there being told not to look or its first years doing the work but the holden dealer round here, i dont know how they stay in business, there workshop is always empty when i go to pick up parts.
2003 BA XR6 N/A SEDAN IN ACID RUSH CURRENT MODS: PACEMAKER 4490's, 3 INCH HIGH FLOW CAT, F6 CAI, K&N PANEL FILTER FUTURE MODS: CAT BACK EXHAUST, MAG WHEELS |
24-09-2011, 06:33 PM | #48 | ||
and it affects the captiva's too as stated.
24-09-2011, 06:37 PM | #49 | |||
24-09-2011, 07:14 PM | #50 | |||
24-09-2011, 08:09 PM | #51 | |||
Resident F1 Troll
24-09-2011, 08:14 PM | #52 | |||
He was kinda glad someone wrote his car off not long ago so he didnt have to go through Holdens service again.
Seduce BFII XR6T Ute ZF - Optioned interior - Hardlid - Rapidsystems V4.5 kit - GTX3576R - Crow Cams Valve springs - 1000cc KPM injectors - 20" MC Racing Wheels - DashDaq/Cobalt Gauges - 4in dump/3.5in exhaust system - Shockworks Coilovers - 30mm Swaybar - Shockworks 4pot 355mm front brakes - GT R-spec rear brakes
CPV Tuned to 340rwkw |
24-09-2011, 08:24 PM | #53 | ||
BUILT FORD TUFF
Thats why i am still a big fan of timing belts. With the improved manufacturing procedures and better materials used in making them, they can now get up to 150,000 kms out of a belt. They are easy to change and dont rattle on start up. They do make more noise than chains when runing but.
24-09-2011, 09:12 PM | #54 | |||
building the xe...
24-09-2011, 09:43 PM | #55 | ||||
earth flavoured
24-09-2011, 09:55 PM | #56 | |||
Peter Car
25-09-2011, 12:47 AM | #57 | ||
i read somewhere a while ago that the holden commadore is the most recalled car model per sale in aus motoring history. think it was in the racq magazine
25-09-2011, 12:58 AM | #58 | ||
VFII SS UTE
speaking of recalls terry SZ is about a fuel line ploblem..assume petrol jobbie.
and cruze JG seat belt dramas..
I don't often hear the sound of a screaming LSX. But when I do, So do the neighbours.. GO SOUTHS
25-09-2011, 01:08 AM | #59 | ||
yeh yeh yeh but ford have recalls and um there stupid because ford does it to and and um holden isnt that bad yawn give me a break already
25-09-2011, 01:21 AM | #60 | |||
earth flavoured
