#31 | ||
OzEcruisers PRESIDENT
![]() Join Date: Mar 2005
Soundstream Pumps Hard - Go see the Guy at Garry's Car Radio in Mitcham he has the Commodore "Soundstream Car" with the number plates SHHH, he can advise on what amp you would need.......
To make sure the price is right look up www.bitaudio.com.au and check the prices there, of course they are the US version sold in Aus but it will give you a good idea on what price they can sell the amps for at a Retail Store........ And yes the Chrome Spiders are AWESOME
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan PROEF 13.46 @ 105.78mph Tuned by DYNOMOTIVE 200BUX - AFF Drag Nats 2019 EF Wagon
#32 | |||
The one and only
1992 DC LTDHO 360rwkw built by me Tuned by CVE Performance Going of the rails on a crazy train Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
#33 | |||
Driftin shopping trolleys
ps why cant you say sick without the "c" thats just gay.. well thats wat the*** is
VZ Calais 5.7ltr cammed, stalled, and the rest. 04 BA XR6T ute |
#34 | |||
The one and only
#35 | |||
#36 | |||
The one and only
#37 | ||
Option 1:- Amp 500 rms watts x 1 PLUS Sub 500 rms watts x 1
Option 2:- Amp 500 rms watts x 3 PLUS Sub 500 rms watts x 3 Option 2 may not be 3 x Louder but it will be Louder as 3 x 15" push more air than 1 x 15" and air pressure is SPL (Sound Pressure Level)
#38 | ||
Hey Glenn, three dual 4 ohms is a pretty shiitty combo for amping up man. You end up with a weird load for the amp, either 0.6 ohms which is too low or 2.6 which is a bit high for a mono block. You really need to amp up each sub seperately. Bang for buck, I'd recommend the Jaycar amps. Get 3 of the 800WRMS ones like Sunny has. I've got a trade card so can get em a bit cheaper (although not much), but they still work out pretty good value per watt.
Who's doing the install for you? I'll do it! Guranteed cheaper than anywhere else you'll go :P Back in the day I hit just under 142dB from my two Phoenix Gold 15's in my EA. They were running off an MTX Thunder 2300x amp (900WRMS bridged). The same subs hit over 145dB in my sisters N13 Pulsar off a Cadence 800WRMS (made the rear-view mirror break outta the windscreen!). Imagine what three 15's would do with 2400WRMS!! |
#39 | |||
#40 | |||
#41 | ||
just run em off the head unit itll be fine and youll be able to fade left to right front to rear
#42 | ||
GT-P With An Ego
Personally I'd steer clear of SoundStream subs. I've managed to have 5 of them die on me within the 1 year warranty. Manufacturing faults - cone separation, voice coils coming loose, voice coils misaligned.
1998 DL LTD in Sparkling Burgundy, daily, mild 5.0L, high end stereo, slow'n'thirsty - 138.8rwkw. 2006 BF GT-P in Ego, 5.8L all alloy, Kenne Bell 2.8HLC, Nizpro Stage 2 ZF - 440rwkw. 2008 SY F6X in Silhouette, Ford Performance Club of ACT |
#43 | |||
#44 | ||
http://www.soundstream.com/manuals/2...ASSO%20PCW.pdf
this tells you alot about the subs.. xmax for a 15" is 0.315" jasinex
EA Series 2 now with fast parts added... Stage 1: Buy car. with money. Stage 2: Put in Wade Custom Cam, Crow Double Valve springs, High Flow Head, 3.23 LSD, 2.5" mandrell bent with Mercury muffler and custom made CAT, iridium plugs, nolothane bushes, Koni suspension, CAI.. NOW WITH MPFI....OHHH YEAHHH!! Stage 3: More engine mods.. and a fresh new look... can't wait.. :eclipsee_ ![]() 15.43 @ 89 mph - Willowbank Raceway 07/03/2007
#45 | |||
The one and only
The onll reason you'd want to run 3 x 15" is because you want to tell people that you have 3x15. If you intend to run in SPL comp then fine but pepare to spend big!! Also consider the optimum size the box. Say bye bye to the boot space.
#46 | ||
Boost Cruisin'
oi nik, you could run them in series paralel off one of ur big d class bastards couldn't ya??
1988 EA falcon, 20inch dark agents, cyprus blue, ED XR front, full EF fairmont interior conversion, built AU motor with modded BA turbo pistons, AiResearch T04, Snort manifold & 4inch dump, 50mm Synapse external gate, custom stainless 3inch exhaust & cooler piping, Synapse BOV, SMT8 piggy back, lowered on king sl's and ultima shocks, full noleathane bushings |
#47 | |||
Could mean anything ALL I was stating in this case which was the topic of this thread is that as EDGHIA is matching amps with subs his WILL be LOUDER Anyway MEH lets move on...............and back on topic
#48 | ||||
DFDFDF
Remember when i was running 6 12"s off the 2 d-class.. they were loaded to ~.6 ohm.. ended up in more heat than noise.. I still stick by my original posts.. Cheers, Nik
The Daily : 2012 Ford Territory The Restorer : 1994 Polynesian Green ED XR6 T5 - Completely stock, put away for a few years The Project : 1994 Velocity Blue ED Ford Futura - AU3 220kw XR8 5L V8 5-Speed in progress The Toys : 2003 GasGas EC250 & 2001 Yamaha DT230 |
#49 | ||
Boost Cruisin'
well okay then!!!!!! i want 6 12s!!!!!
#50 | ||
thanks for the replys..... DRHEMI... cant go see that guy at Garrys car audio..... dont have a good past with him... and i have decided to get 4. i did a bit more re-search and pricing and went a bit over the budget.... but if i get 4 i will save $500 bucks..... as for the instalation... it will be done by sphell wen i can afford to get it done.... i still need to get the amps and head unit... so still gotta pay a bit before it will be done.
