#31 | |||
XY Driv3r
When i was approaching a corner in the XR at 90km in 5th gear i put my clutch in and threw the shifter into neutral.. (the corner i was approaching was a 60km corner). I revved the car upto 3500rpm and then put the clutch in and selected 3rd gear (whilst maintaining the same rpm) and then clutched out and stayed on the throttle... Its a lot easier to do it then to explain it thats for sure...
#32 | ||
Back in Black
When I did my MR licence test, changing up and down through every gear was actually a required exercise at some part of the test. Don't think it mattered in the car, but its not a bad idea to do it as has been said before shows control of the vehicle and awareness/judgement of gear changing points. Testers love seeing use of good judgement.
FG XR6 TURBO UTE [Current]
BA MkII XR6 MAGNET UTE [Sold] |
#33 | |||
I get the matching of the rpm speed to the lower gear etc but whats the benefit from shifting into and out of neutral? |
#34 | ||
Back in Black
You need to:
clutch in and take it out of gear clutch out and rev engine to bring flywheel and engine gear up to same speed as the next lower gear so they can mesh clutch in and engage lower gear on falling revs once they match again, just baby the lever into gear and it will slip in once the revs match nicely clutch out and keep on driving... If you just keep clutch in and rev while changing gears, the engine will speed up but the engine gear won't as the clutch has disengaged it... if that makes sense?! So it won't be able to match the lower gear. its necessary for older non-synchromesh gear boxes, but makes gear changing easier for all gearboxes and looks cooler. Even the old man's truck is synchro except for 1st gear, but it makes life easier to double clutch on down changes through all gears
BA MkII XR6 MAGNET UTE [Sold] Last edited by ubute; 27-02-2008 at 03:06 PM. |
#35 | |||
2005 BA MK2 FPV GT - 6 SPEED MANUAL , SILHOUETTE, SWISSVAX, SUNROOF, BILSTEIN AND LOVELLS, FACTORY GENUINE 19'S, X-FORCE STAINLESS QUAD CATBACK, ADVANCE HEADERS, 200 CPSI CATS, BLUEPOWER CAI, HERROD BREATHER KIT, 4:11 DIFF RATIO, MAL WOOD OPT 3+ CLUTCH, BILLET SHIFTER, MELLINGS 10227, NOW WITH REVERSE CAMERA/SENSORS, ALPINE SPEAKERS & SUB - CUSTOM TUNED TO 275 RWKW NOW WITH A NEW ADDITION - 2017 MUSTANG V8 GT FASTBACK - , 6 SPEED AUTO IN PLATINUM WHITE, |
#36 | |||
I was worried i'd forgotten how to drive one before taking it for a test drive, but it's like riding a bike...you never forget.
#37 | |||
When I actually do want to take off fast can I rev it up that high (or even 3000RPM) and take off? OR will that stuff something up?
EB II 1992 Fairmont - koni reds, wade 977b, 2.5inch/4480's and much more to come! |
#38 | |||
I was fairly sure with the basics but there's so many little different things that manuals require hence the question. I've certainly learned a lot from this thread already.
#39 | ||||
i'm baaaack....
also the synchros on the XC with the 4speed arn't the best so it saves the box from grinding.... its funny when i drive mates cars and do it with them in the passenger seat, they look at me like ![]() when you drive a cars with newer gearboxs it really isnt as important unless you think the rears will lock up as it drops into gear. now i think about it the first time i lernt to double clutch was watching dad in the XA taking it for a fang through the hills... damn that thing has a nice note!!!! |
#40 | ||
let it burn
Double clutch is pointless in cars. The technique youre describing I can do without using the clutch at all, its no different to driving with a RoadRanger.
#41 | ||||
_Oo===oO_
#42 | ||
XY Driv3r
And no before any one asks you dont double clutch when you are drag racing
#43 | ||
Back in Black
fmc351 - i know, was just describing what double clutching was. Never tried it without using the clutch at all. So you just pop it out, give it a squirt then pop it in again?
#44 | |||
Cane Farmer
Remember to fan the clutch constantly when you are driving. A few revs here and there won't hurt. =]
1994 ED XR6T - Cobalt Blue. 2009 FG XR6 - Black. Quote:
#45 | ||
whats drag racing
#46 | |||
let it burn
#47 | |||
let it burn
The key is knowing the rev range of the vehicle. What revs it likes the particular gear youre going for, how far it drops when changing through the particular gears. With the RoadRanger, yes basically you dont over rev it in gear and it will pop out of gear no worries, and as the revs fall with your foot half off the tall pedal it will fall into the next gear when the revs match, back on the tall pedal. Gearing down, you let the engine speed drop till you need a lower gear, pop it out of gear, pick the revs up a bit in the neutral gate to match the revs for the revs it would be at if in that lower gear already and it should fall into the lower gear without much effort at all, back off the tall pedal and repeat. Go into the truck thread, theres guys in there who do this all day long. |
#48 | |||||
#49 | ||||
i'm baaaack....
![]() Quote:
double clutching is the only way to shift it quick when its coppin a hiding... back on topic... |
#50 | |||
Cast Iron fan
I have a Corolla |
#51 | ||
Grinder+Welder = Race car
"You almost had me? You never had me - you never had your car... Granny shiftin' not double clutchin' like you should. You're lucky that hundred shot of NOS didn't blow the welds on the intake! You almost had me?"
"No, it will never have enough power until I can spin the wheels at the end of the straightaway in high gear" - Too much power is never enough....Mark Donohue on the Can Am Porsche 917. |
#52 | ||
OK, I have been a Driver Trainer since 1987, long before most of you were born - LOL
My goodness me, what a lot of tripe is written here. Bloody hell. All this talk of double de-clutching, talk about confusing, bloody hell again. ---------------------------------------------------------------------------- Your mate is right, use the brakes to slow you down, then select the correct gear. When stopped, clutrch in, select 1st gear, please remember that when the clutch is 'in', you have actually seperated (put a space between) the clutch plate and flywheel. When you let the clutch out, you are transfering power from the engine to the gearbox, via the clutch, for example, rub your hands together softly, then push them together harder as you are rubbing, that is like what is happening when you let the clutch out. One hand is the flywheel, the other the clutch plate. At a point, generally half way out where the pressure is such that the flywheel and clutch will spin at the same speed, this is friction point, the car will want to move slowly forward, at that point, plus maybe a mill or 2, hold you foot still and the car will move away. All clutch movements when moving should be quicker, but done with feel
I reserve the right to arm bears
#53 | ||||
Can't go around corners
Quote from Jeremy Clarkson in the Top Gear Vietnam special: Quote:
#54 | |||
#55 | ||
Funny to have to think about how I drive manual because it does come naturally with practice.
Sloth puts it quite well to answer your questions. With the gearing down question it depends on your situation, in normal situations generally I would gear down using the engine to break, it puts less strain on the breaks etc... helps with wear on the pads I guess. Get in there drive in light traffic conditions at first and before you know it you will be changing gears and reversing without thinking about it. |
#56 | |||
If a lot of people who have posted in this thread are wrong, then that idiot who trolled this thread at the start has just proven his stupidity. I'll be sure to use your advice.
#57 | |||
i'm baaaack....
puts on flame suit |
#58 | |||
#59 | |||
I was having a bit of Fun at your expense I admit it however it was your original comments saying that your Mates car goes so fast in reverse that you cannot handle it & cannot work out if you use the Clutch Throttle & Footbrake you will be able to control speed it is not me who is the IDIOT! As I said I started driving a manual at the age of 12 on my own with no Help & with no more knowledge than from watching my Father Drive. As many apart from me have said it comes naturally, well unless you are a girl as many Girls seem to have trouble with manuals moreso than Guys. And young people like you with not a clue are Driving Vehicles on the Roads ![]() |
#60 | |||
Some people need more time to come to grips with it. And if you think ridiculing people like that is right, then my son, it is you that has issues. Not everyone is as expert as you appear to be, now be a good "little" boy and bugger off.
